    Follow me tool pls
    41 Posts 8 Posters 4.0k Views 8 Watching
    • E
      erzane
      do you mean orbiting, the ''O'' key ?
      if yes I knew it already, but I tought I saw a different designed tool..
      oh ok I see now, I think you have a different sketchup version than me , that's why follow me tool and orbiting looks different, they have different design, (I use sketchup 8.0)
      • BoxB
        Yes, it's orbit and follow me in 2013.
        It would help if you updated your profile because answers can vary depending on operating system and Sketchup version.
          There oughta be a "Like" button.
          • BoxB
            One little pipe led to another little pipe which led to I got carried away...... 😲
            • BoxB
              Cheers Dave, perhaps it's a steampunk borg cube.
              • JQLJ
                JQL
                Nah Box! It's a box! And a nice one might I had!
                JQL
                www.casca.pt
                Visit us on facebook!
                • E
                  erzane
                  here is guys
                  thanks for your help 😄
                  • BoxB
                    Erzane, I'm not sure if you want all the "sections" in your pipes but if you "weld" the path before you use follow me you won't get all those joints.
                      I believe that "weld" path's curves can't be made without plugin! 😉
                      So try this one Recurve by Diggsey
                        Or TIG-weld 😉
                        • E
                          erzane
                          what is ''weld'' ?
                            Look up 'weld' in a dictionary...
                            It means to join separate pieces together to form a single object.
                            In English it usually refers to metal things, but by extension in SketchUp it is used in the sense of joining several edges [lines] that touch each other end-to-end into a 'curve'.
                            A curve in SketchUp is rather like a CAD 'polyline'.
                            Although it consists of separate pieces, these are bound together in a 'curve' object.
                            When you click-on and select a curve all of the edges get included in the selection.
                            When you use a curve as a path for a FollowMe the result has a smooth surface.
                            If you use the equivalent edges [lines] that are not welded you get edges at the changes in direction.
                            Curves that you already use are Arcs: if you extrude around an Arc you will get a smooth surface, but undo and Explode that Arc, then extrude using the selected edges you be visible lines at the changes in direction. A Circle is just a special Arc in a loop. If you Scale an Arc then Entity Info no longer reports it as an Arc, but rather as a Curve. Because it's still a curve an extruded form that uses it will be smooth.
                            Now... any collection of connected edges [lines] can be welded into a curve [this can be in 3d too, but no 'branches' are allowed, because these break the continuity of the curve just as will happen if you add a line across an arc and it is then in separate parts].
                            So if you have a complex 3d pipe or wire that you want to look smooth then weld the pieces of the path into a curve [suitable edges [lines] and arcs/curves can be selected, and they will all get welded into one new curve]. That curve will extrude making a smooth surface...
                            • BoxB
                              To see one version of it being used, go back to the video I posted.
                              You will see at 1 min that I select one section of the path line, then there is a slight pause and the whole path turns blue. This was me hitting my keyboard shortcut for Recurve. Or more specifically, Select Curve and Recurve. Which does what it says, it selects all the segments until the path branches and welds the segments back into a curve.
                              • E
                                erzane
                                I see
                                thanks for the info
                                I will try it and give you news soon
                                • E
                                  erzane
                                  I m trying to recurve my selection but since I have skp in french I dont find the option ''recourber'' or any other which looks like.
                                  Must I right clic on the selection to find the ''recurve'' option, or must I go into the top menu ?
                                  pls could you show me which option to choose on a screen capture ?
                                  or if there is any key shortcut for that which key is that ?
                                    You need to select a segment that is attached to other segments in the curve. Then you right click and choose Recurve in the Context menu.
                                    You would probably find it very useful to go to the thread for the plugin and read how it works.
                                    • E
                                      erzane
                                      need I ''recurve 1,5'' plugin ?
                                        I'm not sure how you would expect to use Recurve if you don't have the plugin.
                                        • E
                                          erzane
                                          ok, now I see better why I didn't find it on the skp menu
                                          so, I downloaded the plugin
                                          but when I >select curve >right clic >recurve edges
                                          it give me this strange result
                                          it change the form of my curve
                                          I select and recurve edges
                                          strange result
                                          • E
                                            erzane
                                            now I have a good result enough
                                            after recurve and recurve, and modify my paths a bit
                                            but I still don't understand why have I 3 pipes with horizontal lines all along them.
                                            all the other pipes are ok, only those 3 as you can see are stranges (2 on the very left, and the 3rd on the very right side)
                                            • 2 / 3
