    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 180.9k Views 84 Watching
      It is meant to mean, 'Check [my-plugins] for [available] updates'.
      If you do check it, then it does indeed show any updates that are available for 'my-[your!]-plugins'
      But I know what you mean... Refinements are being looked at anyway... 😒
      The way it displays 'my-plugins' will hopefully get even more helpful soon - perhaps showing every plugin you have ever downloaded [which might include files you have subsequently deleted or perhaps have not yet installed on this current PC], the plugins you currently have 'installed' on this current PC [but enabled and disabled ones, but excluding 'uninstalled' ones] i.e. omitting those you have subsequently deleted etc, and then which of those plugins have updates available for you...
        GĂĄbor
        Text changed to "Check for updates". After cache erase you should see the change.
        • Bob JamesB Offline
          Bob James
            jasonotero247
            After clicking auto install for some plugins, they do not appear under my plugins tab but do appear under my sketchucation store > My plugins. How do I get them to appear/work. Thanks.
            windows 7, SU2013
              Not all plugins are under the Plugins menu. Some are under Edit, Tools, Draw, File, Window....
              It really depends on what you installed.
              Read the 'More Info' page for each tool...
              Also you need to have permissions to write to Plugins folder which is covered ad nauseam in this thread already.
                jackrythm123
                I cant seem to find the INSTALL EXTENSIONS button on the extensions tab in preferences. it just isn't there. I know I can manually install these but is there a follow guide for this?
                • massimoM Offline
                  massimo Moderator
                  You need to upgrade SU version - at least the latest SU8 version - in order to have that button and the additional features like AutoInstall...
                  • cottyC Offline
                    cotty
                    It was introduced in SU 8 M2: http://sketchupdate.blogspot.de/2011/12/another-important-update-for-sketchup-8.html
                    my SketchUp gallery
                    • U Offline
                      user2
                      I'm using SU8 pro (8.0.16846) with Win7x64.
                      Now I can't install any plugin by SUPS v2.0.0 with autoinstall.
                      I check that it could't extended the download file in %TMP%\SCF, Actually there's a "t999" file with 0 byte in the extended folder %TMP%\t.
                      At last I tried to use the old version "v1.2.0", that's works fine.
                      I've never install this plugin and any plugin before
                      I can only provide this information and I really love this work.
                      This is a bug or my problem?
                      • halroachH Offline
                        halroach
                        Is there a way to logout my account from the plugin store through sketchup? I logged in using my credentials on more than one computer and I'd like to logout and have that user use his own account...
                        FlexTools - Super Quick Windows, Doors, Slats...
                        • U Offline
                          user2
                          That's maby clear the cookies of IE under Win.
                            I check that it couldn't extended the download file in %TMP%\SCF, Actually there's a "t999" file with 0 byte in the extended folder %TMP%\t.
                            Do you get any error messages or dialogs referring to this ?
                            If you have the Ruby Console open are there any messages ?
                            Do you have a non-ASCII character in your user...temp path ?
                            Like an 'accented' letter.
                            The folder is:
                            C:\Users\**USERNAME**\AppData\Local\Temp\SCF
                            This will break many Ruby based tools on PCs that will use that folder path [at least until SketchUp starts to use a newer version of Ruby... but we must wait for some future update for that to happen!]
                            To check the 'temp/SCF' folder exists it writes a temp-file (t999) and does a File.exist?(t999) check to see if the folder is writable, but that returns false even if it exists when there's as accent in the folder path!
                            Also please double check that you have FULL security permissions to the ../Local/Temp/SCF/ AND ../Local/SCF/ folders - it should be set automatically, but you never know...
                            So if the issue is that there's an accent in the path try a renamed user-account without it [or wait until SketchUp gets updated...] !?
                              Each User on a computer has their own 'Users' account.
                              Each User logging into the PluginStore through the dialog is asked to login once only [they just have to be a current SCF member and enter a valid password]; subsequent changes to the member's password on the main SCF site will not affect the PluginStore dialog's login, provided they are still an SCF member.
                              Their acceptable login data is stored in an encrypted cookie file.
                              On a PC this is is stored separately for each User:
                              C:\Users\USERNAME\AppData\Local\SCF\cookie.dat
                              Where USERNAME is your PC-user login name...
                              Note that is AppData folder might be hidden from you - but you can change your 'Folder Options' settings so that then you'll see it...
                              If that cookie exists and it is found to be valid, then the user is auto-logged-in to the PluginStore dialog every time they open it.
                              So, if another User has their own Users account they will also be prompted to login once, and your use of the PluginStore dialog will be treated quite separately from theirs - their cookie is stored separately from your cookie.
                              BUT if you must let someone else use your PC's User account [ 😕 why ?] and you want them to be able to login to the PluginStore dialog in their own right as another SCF-memeber, then you will need to 'disable' your own cookie.dat file... go to the 'SCF' folder given above and rename it YFcookie.dat so the dialog's initial check will no longer see it...
                              Now anyone [including you!] who opens the PluginStore dialog will be prompted to login [once], and if the data given is acceptable, then a new encrypted cookie.dat file is made.
                              To revert to your login... just rename the current cookie.dat as XXcookie.dat and rename your old YFcookie.dat as cookie.dat. When you restart the PluginStore dialog you will be logged in again.
                              • halroachH Offline
                                halroach
                                I'll have to take a vacation to go through that explanation... 😉
                                The reason I used my login on another computer was so I could check out which plugins and extensions I have installed on my original computer...
                                Basically I was hoping I'll be able to "sync" all my plugins on all computers I am logged on.
                                Bottom line:
                                1. There should be a login/logout feature for the plugins store.
                                2. Suggest an option to sync plugins in the cloud!? (Apple iCloud style) or at least something similar that will help me install the same plugins on a few computers. (I know of the dropbox option which is not very straightforward for the average user).
                                • U Offline
                                  user2
                                  The folder is:
                                  There's nothing message display in the Ruby console.
                                  My username is CLOUD and there's never a non-ASCII character in my system driver path.
                                  I loggin as the ADMINISTRATOR in my system. And I'm sure the UAC works fine.
                                  NOW I use the old version 1.2.0 instead, It works fine, just without the uninstall option. Did v1.2.0 is the last version before 2.0.0? I will keep it.
                                  I will take some pics and upload them.
                                    @Hal
                                    We have already been discussing the possibility of a way of users keeping their Plugins Sets synced across their PCs.
                                    At the moment it is a 'Local' setup for each PC...
                                    Why would you ever want to log-out of the PluginStore IF you use separate User accounts properly setup on your networked PCs then each User gets there own login.
                                    BUT if you have been on someone else's PC [during their User-login session] and you have then used your own SCF login details in the PluginStore's dialog, then these details will be reused, until that user's applicable 'cookie.dat' file encrypting your info is deleted from that user's own ../Users/XXX/AppData/SCF/SCF/ folder. So all you have to do is find their 'cookie.dat' file in the ..Users/XXX/AppData/Local/SCF/ folder, as I outlined before, and delete or rename it...
                                    BUT it is best to always login as yourself onto any PC, the other user opens a personal security breach - by letting someone else use their session, anything 'bad' done by the other person appears to done by them, when traced back...
                                    This simple IT protocol ensures that the PluginStore login issue never arises because you always run SketchUp 'as yourself' not as some other user...
                                    However, we will consider a 'logout' option for the dialog, but then we'll have an extra button on the dialog which we are trying to keep simple... Perhaps a "Log-out' of the Plugin Store" menu item in the drop-down menu list ?
                                    PS: This string, copy+pasted+<enter> into the Ruby Console, will rename that user's cookie.dat file with a random-prefix, so the next use of the PluginStore dialog will ask for a login and make a new cookie.dat file. I stopped at deleting it as you can then reuse it by renaming without the random-prefix
                                    File.rename(SCF::SCF_Dialog::SCFDIR+"/cookie.dat", SCF::SCF_Dialog::SCFDIR+"/#{rand}+cookie.dat")
                                    To delete the file use:
                                    File.delete(SCF::SCF_Dialog::SCFDIR+"/cookie.dat")
                                      @user2
                                      Being an Administrator does NOT necessarily allow you unrestricted read/write permissions to many folders.
                                      That's why I asked you to recheck the Properties > Security settings for these folders...
                                      The earlier version has a less careful check to see if the folder existed and was writable.
                                      It would sometimes fail.
                                      The new version is just more robust, actually writing a file to check it is as expected.
                                      BUT both that earlier version and the newest version will fail on PCs with accented characters etc in User names...
                                      The latest version should work - there are many thousands of users who have no issues with it, so we need to find what specifically you have setup that is breaking it - yours is the only report like this ?
                                      • U Offline
                                        user2
                                        @tig said:
                                        @user2
                                        THANKS, I find the problem.
                                        I installed sketchup in the default path %PROGRAMFILES% which need Administrator privileges.
                                        SKETCHUP NEED RUN AS ADMINISTRATOR.
                                        But the inside installer runs better than "SketchUcation Archive Installer" without administrator privileges.
                                        I will download plugins from "SketchUcationTool", and install it by inside installer.
                                        THANKS A LOT, THAT"S FINE.
                                          1.2 will probably stop working soon. So figuring out your issue is important.
                                          • halroachH Offline
                                            halroach
                                            @tig said:
                                            @Hal
                                            Hi Tig,
                                            I agree with the premise that each user should login with their own credentials on their own computer. But yeah, there will always be the exception or someone like me, trying to see what happens 😄.
                                            So a little inconspicuous button in the menu would be a good idea.
                                            In my case, it just so happens to be (unfortunately) that the concept of searching for plugins on forums, or searching for plugins period, may be difficult for some of my workers. So it's up to me to keep them up to date on the cutting edge of the sketchup world. That's why syncing plugins would be nice, but it would require (in my case) a syncing option between different users... And then another question arises, how do you sync/manage 'purchased plugins'/'plugins that were downloaded from elsewhere and not from the Sketchucation plugin store'... it can be quite a mess to code and design I imagine.
                                            Thanks Tig.
                                            • 19
                                            • 20
                                            • 4 / 20
