    Soften-Edges using by ruby
    23 Posts 7 Posters 6.2k Views 7 Watching
      I haven't tested it but it looks OK - except I'd have used
      edge.soft=true if ang >= 45.degrees edge.smooth=true if ang >= 45.degrees
      rather than
      edge.soft=true if ang.radians >= 45.0 edge.smooth=true if ang.radians >= 45.0
      There's a type in the group part use ee NOT e...
      e.entities.each{|ee|edges << ee if **ee**.class==Sketchup::Edge}if e.class==Sketchup::Group
      But but ought to work ?
      If you get it to 'puts' edges and ang.radians etc as it iterates through what is shown in the Ruby Console ??
      • B
        baldaman
        Here is the code and the result,
        I tried with different angles.
        If I choose 90° nothing is smoothed neither soften.
        • B
          baldaman
          Oups, here is the code
          def ss()
          model=Sketchup.active_model
          ss=model.selection
          ### You can assemble any collection of edges
          ### Here it's from the model's current selection
          edges=[]
          ss.to_a.each{|e|
             edges << e if e.class==Sketchup;;Edge
             e.entities.each{|ee|edges << ee if ee.class==Sketchup;;Edge}if e.class==Sketchup;;Group
          edges.each{|edge|
          ang=edge.faces[0].normal.angle_between(edge.faces[1].normal)
             if edge.faces[1]
          end#def
            The angle between adjacent faces on the cylinder's curve is 360/numsegs = 15 degrees for 24 segements so that is less than 45 degrees so they won't be smoothed !
            I suspect you want to smooth edges that are NOT >= 45.degrees - so reverse the logic of the test to
            edge.soft=true if ang < 45.degrees edge.smooth=true if ang < 45.degrees
            and then 'sharp' edges will be kept 'solid' but edges with faces with similar normals will get smoothed
            So a right-angle arris stays sharp and a nearly flat surface gets smoothed...
            • B
              baldaman
              ... I am soooo stupid!
              Thank you very much, it works perfectly.
              Thank you very much master TIG
                That's OK 😉
                I should have spotted the error in your logic earlier too 😮
                • artmusicstudioA
                  artmusicstudio
                  hello,
                  this piece of code is very helpful.
                  in my case this works:
                  SMOOTH LEFT
                  ss=group20.entities
                  edges=[]
                  ss.to_a.each{|e|
                  edges << e if e.class==Sketchup::Edge
                  e.entities.each{|ee|edges << ee if e.class==Sketchup::Edge}if e.class==Sketchup::Group
                  edges.each{|edge|
                  if edge.faces[1]
                  edge.soft=true
                  edge.smooth=true
                  BUT THIS ONE (smoothing with angle limit)
                  ss=group20.entities
                  edges=[]
                  ss.to_a.each{|e|
                  e.entities.each{|ee|edges << ee if ee.class==Sketchup::Edge}if e.class==Sketchup::Group
                  edges.each{|edge|
                  if edge.faces[1]
                  is quit by following:
                  VAR. 0.1 k
                  load '01.rb'
                  Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1516:in draw_stairs'
                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in draw_stairs'
                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:973:in `each'
                  any idea about the "normal" problem?
                  thanx stan
                    Recast:
                    edges.each{|edge|
                    if edge.faces[1]
                    as
                    edges.each{|edge|
                    if edge.faces[1]
                    because in YOUR version you are trying to get the normal of ALL edge's faces even if an edge doesn't have any faces ! Or if the face only has one face YOUR version fails when it can't find the normal of the non-existent second face !
                    • artmusicstudioA
                      artmusicstudio
                      YEAP!
                      smooth like a sup of tea with milk on a sunny afternon......
                      smoothing works perfect , thanx a lot ("again what learned", as we say here in bavaria)
                      lost a ot of time today with fighting again coordinate systems, whatever i do, the elements don't place themselves sometimes , where i expect them to, it seems, that within groups and components the time & space works different sometimes.....
                      stan
                      • G
                        glro
                        @tig said:
                        @thomthom said:
                        @tig said:
                        Make an array of the selected edges [or of the edges within selected groups etc].
                        Iterate through those edges and test it they have >1 face.
                        The native soft+smooth tool doesn't soft+smooth any edges that is connected to more or less than 2 faces.
                        OK just adjust the code so that it's a edge.faces[1] and not edge.faces[2] test...***
                        To work on a group's edges
                        > ###... add this into the mix...
                        > groups=[]
                        > ss.to_a.each{|e|groups << e if e.class==Sketchup;;Group}
                        > groups.each{|group|
                        >   group.entities.to_a.each{|e|
                        >     if e.class==Sketchup;;Edge and e.faces.length==2 ###***
                        >       e.soft=true
                        >       e.smooth=true
                        >     end#if
                        it works for groups, but not for components...
                        is it possible?
                          Assuming ss=Sketchup.active_model.selection...
                          defns=[]
                          ss.grep(Sketchup;;ComponentInstance).each{|e|defns << e.definition}
                          defns.uniq!
                          defns.each{|defn|
                            defn.entities.grep(Sketchup;;Edge).each{|e|
                              if e.faces.length==2
                                e.soft=true
                                e.smooth=true
                          or something similar...
                          • G
                            glro
                            defns=[]
                            > defns.uniq!
                            > defns.each{|defn|
                            >       e.soft=true
                            >       e.smooth=true
                            >     end
                            yes...it works
                            this will save me time, since i noticed that some components edges come back visible in my models, for unknown reason...
                            now with just one clic, the problem is solved
                            thank you
                              The unexpected reversion of smoothed edges to solid is a known bug.
                              Never save when in a edit session. Even an auto-save can trigger this, so never stay inside an edit session for longer than you need to...
