    Soften-Edges using by ruby
    23 Posts 7 Posters 5.0k Views 7 Watching
      Andreas
      I want to use the menu command "Soften Edges" from the "Window"-menu by ruby.
      Can someone tell me how does it work?
      With best regards from Germany
      Andreas
        No sure if you can - you might have to do it manually.
          Jim
          I don't think it is available through an API method; you will need to write your own soften method.
            Andreas
            @jim said:
            ... you will need to write your own soften method.
            How does it work? Do you have an idea?
            Andreas
              Compare the angle_between of the face's normal, soft and smooth if they are within the threshold.
              • TIGT Online
                Make an array of the selected edges [or of the edges within selected groups etc].
                Iterate through those edges and test it they have >1 face.
                Soft/Smooth them...
                def makesoftsmooth()
                 model=Sketchup.active_model
                 ss=model.selection
                 ### You can assemble any collection of edges
                 ### Here it's from the model's current selection
                 edges=[]
                 ss.to_a.each{|e|
                   edges << e if e.class==Sketchup;;Edge
                   e.entities.each{|ee|edges << ee if e.class==Sketchup;;Edge}if e.class==Sketchup;;Group
                 edges.each{|edge|
                   if edge.faces[1]
                     edge.soft=true
                     edge.smooth=true
                end#def
                Save code as makesoftsmooth.rb or use the def as part of a broader tool.
                Execute it as makesoftsmooth()
                This softens ALL edges that have at least 2 faces - but if you want to soften edges based on angle between its two faces use something like ang=edge.faces[0].normal.angle_between(edge.faces[1].normal) and then use edge.soft=true if ang.radians >= 45.0 etc or whatever the angle you desire [here it's 45 degrees]
                  Andreas
                  Soft/Smooth them...
                  >  ss=model.selection
                  >  edges=[]
                  >  ss.to_a.each{|e|
                  >  edges.each{|edge|
                  >    if edge.faces[1]
                  >      edge.soft=true
                  >      edge.smooth=true
                  >    end
                  > end#def
                  Thank you!
                  That works well, if the edges not in a group.
                  But on edges in a group it doesn´t work.
                  What should I do so that it acts on the edges in a group?
                  Andreas
                    The native soft+smooth tool doesn't soft+smooth any edges that is connected to more or less than 2 faces.
                    • TIGT Online
                      OK just adjust the code so that it's a edge.faces[1] and not edge.faces[2] test...***
                      To work on a group's edges
                      ###... add this into the mix...
                      groups=[]
                      ss.to_a.each{|e|groups << e if e.class==Sketchup;;Group}
                      groups.each{|group|
                        group.entities.to_a.each{|e|
                          if e.class==Sketchup;;Edge and e.faces.length==2 ###***
                            e.soft=true
                            e.smooth=true
                          end#if
                        baldaman
                        Dear TIG, I tried to edit you code in order to be able to choose the smooth angle but I didn't succeed.
                        WHat am I doing wrong?
                        def ss()
                        ss=model.selection
                        edges=[]
                        ss.to_a.each{|e|
                        edges.each{|edge|
                           if edge.faces[1]
                             edge.smooth=true if ang.radians >= 45.0
                        end#def
                        • TIGT Online
                          I haven't tested it but it looks OK - except I'd have used
                          edge.soft=true if ang >= 45.degrees edge.smooth=true if ang >= 45.degrees
                          rather than
                          edge.soft=true if ang.radians >= 45.0 edge.smooth=true if ang.radians >= 45.0
                          There's a type in the group part use ee NOT e...
                          e.entities.each{|ee|edges << ee if **ee**.class==Sketchup::Edge}if e.class==Sketchup::Group
                          But but ought to work ?
                          If you get it to 'puts' edges and ang.radians etc as it iterates through what is shown in the Ruby Console ??
                            baldaman
                            Here is the code and the result,
                            I tried with different angles.
                            If I choose 90° nothing is smoothed neither soften.
                              baldaman
                              Oups, here is the code
                              def ss()
                              ss=model.selection
                              edges=[]
                              ss.to_a.each{|e|
                                 e.entities.each{|ee|edges << ee if ee.class==Sketchup;;Edge}if e.class==Sketchup;;Group
                              edges.each{|edge|
                                 if edge.faces[1]
                              end#def
                              • TIGT Online
                                The angle between adjacent faces on the cylinder's curve is 360/numsegs = 15 degrees for 24 segements so that is less than 45 degrees so they won't be smoothed !
                                I suspect you want to smooth edges that are NOT >= 45.degrees - so reverse the logic of the test to
                                edge.soft=true if ang < 45.degrees edge.smooth=true if ang < 45.degrees
                                and then 'sharp' edges will be kept 'solid' but edges with faces with similar normals will get smoothed
                                So a right-angle arris stays sharp and a nearly flat surface gets smoothed...
                                  baldaman
                                  ... I am soooo stupid!
                                  Thank you very much, it works perfectly.
                                  Thank you very much master TIG
                                  • TIGT Online
                                    That's OK 😉
                                    I should have spotted the error in your logic earlier too 😮
                                    • artmusicstudioA Offline
                                      artmusicstudio
                                      hello,
                                      this piece of code is very helpful.
                                      in my case this works:
                                      SMOOTH LEFT
                                      ss=group20.entities
                                      edges=[]
                                      ss.to_a.each{|e|
                                      edges << e if e.class==Sketchup::Edge
                                      e.entities.each{|ee|edges << ee if e.class==Sketchup::Edge}if e.class==Sketchup::Group
                                      edges.each{|edge|
                                      if edge.faces[1]
                                      edge.soft=true
                                      edge.smooth=true
                                      BUT THIS ONE (smoothing with angle limit)
                                      ss=group20.entities
                                      edges=[]
                                      ss.to_a.each{|e|
                                      e.entities.each{|ee|edges << ee if ee.class==Sketchup::Edge}if e.class==Sketchup::Group
                                      edges.each{|edge|
                                      if edge.faces[1]
                                      is quit by following:
                                      VAR. 0.1 k
                                      load '01.rb'
                                      Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1516:in draw_stairs'
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in draw_stairs'
                                      C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:973:in `each'
                                      any idea about the "normal" problem?
                                      thanx stan
                                      • TIGT Online
                                        Recast:
                                        edges.each{|edge|
                                        if edge.faces[1]
                                        as
                                        edges.each{|edge|
                                        if edge.faces[1]
                                        because in YOUR version you are trying to get the normal of ALL edge's faces even if an edge doesn't have any faces ! Or if the face only has one face YOUR version fails when it can't find the normal of the non-existent second face !
                                          artmusicstudio
                                          YEAP!
                                          smooth like a sup of tea with milk on a sunny afternon......
                                          smoothing works perfect , thanx a lot ("again what learned", as we say here in bavaria)
                                          lost a ot of time today with fighting again coordinate systems, whatever i do, the elements don't place themselves sometimes , where i expect them to, it seems, that within groups and components the time & space works different sometimes.....
                                          stan
                                            glro
                                            > groups=[]
                                            > groups.each{|group|
                                            >       e.soft=true
                                            >       e.smooth=true
                                            >     end#if
                                            it works for groups, but not for components...
                                            is it possible?
