    Soften-Edges using by ruby
    23 Posts 7 Posters 6.2k Views 7 Watching
      @tig said:
      Make an array of the selected edges [or of the edges within selected groups etc].
      Iterate through those edges and test it they have >1 face.
      The native soft+smooth tool doesn't soft+smooth any edges that is connected to more or less than 2 faces.
        OK just adjust the code so that it's a edge.faces[1] and not edge.faces[2] test...***
        To work on a group's edges
        ###... add this into the mix...
        groups=[]
        ss.to_a.each{|e|groups << e if e.class==Sketchup;;Group}
        groups.each{|group|
          group.entities.to_a.each{|e|
            if e.class==Sketchup;;Edge and e.faces.length==2 ###***
              e.soft=true
              e.smooth=true
            end#if
        • B
          baldaman
          Dear TIG, I tried to edit you code in order to be able to choose the smooth angle but I didn't succeed.
          WHat am I doing wrong?
          def ss()
          model=Sketchup.active_model
          ss=model.selection
          ### You can assemble any collection of edges
          ### Here it's from the model's current selection
          edges=[]
          ss.to_a.each{|e|
             edges << e if e.class==Sketchup;;Edge
             e.entities.each{|ee|edges << ee if e.class==Sketchup;;Edge}if e.class==Sketchup;;Group
          edges.each{|edge|
             if edge.faces[1]
          ang=edge.faces[0].normal.angle_between(edge.faces[1].normal)
               edge.soft=true if ang.radians >= 45.0
               edge.smooth=true if ang.radians >= 45.0
          end#def
            I haven't tested it but it looks OK - except I'd have used
            edge.soft=true if ang >= 45.degrees edge.smooth=true if ang >= 45.degrees
            rather than
            edge.soft=true if ang.radians >= 45.0 edge.smooth=true if ang.radians >= 45.0
            There's a type in the group part use ee NOT e...
            e.entities.each{|ee|edges << ee if **ee**.class==Sketchup::Edge}if e.class==Sketchup::Group
            But but ought to work ?
            If you get it to 'puts' edges and ang.radians etc as it iterates through what is shown in the Ruby Console ??
            • B
              baldaman
              Here is the code and the result,
              I tried with different angles.
              If I choose 90° nothing is smoothed neither soften.
              • B
                baldaman
                Oups, here is the code
                def ss()
                ss=model.selection
                edges=[]
                ss.to_a.each{|e|
                   e.entities.each{|ee|edges << ee if ee.class==Sketchup;;Edge}if e.class==Sketchup;;Group
                edges.each{|edge|
                   if edge.faces[1]
                end#def
                  The angle between adjacent faces on the cylinder's curve is 360/numsegs = 15 degrees for 24 segements so that is less than 45 degrees so they won't be smoothed !
                  I suspect you want to smooth edges that are NOT >= 45.degrees - so reverse the logic of the test to
                  edge.soft=true if ang < 45.degrees edge.smooth=true if ang < 45.degrees
                  and then 'sharp' edges will be kept 'solid' but edges with faces with similar normals will get smoothed
                  So a right-angle arris stays sharp and a nearly flat surface gets smoothed...
                  • B
                    baldaman
                    ... I am soooo stupid!
                    Thank you very much, it works perfectly.
                    Thank you very much master TIG
                      That's OK 😉
                      I should have spotted the error in your logic earlier too 😮
                      • artmusicstudioA
                        artmusicstudio
                        hello,
                        this piece of code is very helpful.
                        in my case this works:
                        SMOOTH LEFT
                        ss=group20.entities
                        edges=[]
                        ss.to_a.each{|e|
                        edges << e if e.class==Sketchup::Edge
                        e.entities.each{|ee|edges << ee if e.class==Sketchup::Edge}if e.class==Sketchup::Group
                        edges.each{|edge|
                        if edge.faces[1]
                        edge.soft=true
                        edge.smooth=true
                        BUT THIS ONE (smoothing with angle limit)
                        ss=group20.entities
                        edges=[]
                        ss.to_a.each{|e|
                        e.entities.each{|ee|edges << ee if ee.class==Sketchup::Edge}if e.class==Sketchup::Group
                        edges.each{|edge|
                        if edge.faces[1]
                        is quit by following:
                        VAR. 0.1 k
                        load '01.rb'
                        Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1516:in draw_stairs'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in draw_stairs'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:973:in `each'
                        any idea about the "normal" problem?
                        thanx stan
                          Recast:
                          edges.each{|edge|
                          if edge.faces[1]
                          as
                          edges.each{|edge|
                          if edge.faces[1]
                          because in YOUR version you are trying to get the normal of ALL edge's faces even if an edge doesn't have any faces ! Or if the face only has one face YOUR version fails when it can't find the normal of the non-existent second face !
                          • artmusicstudioA
                            artmusicstudio
                            YEAP!
                            smooth like a sup of tea with milk on a sunny afternon......
                            smoothing works perfect , thanx a lot ("again what learned", as we say here in bavaria)
                            lost a ot of time today with fighting again coordinate systems, whatever i do, the elements don't place themselves sometimes , where i expect them to, it seems, that within groups and components the time & space works different sometimes.....
                            stan
                            • G
                              glro
                              > groups=[]
                              > groups.each{|group|
                              >       e.soft=true
                              >       e.smooth=true
                              >     end#if
                              it works for groups, but not for components...
                              is it possible?
                                Assuming ss=Sketchup.active_model.selection...
                                defns=[]
                                ss.grep(Sketchup;;ComponentInstance).each{|e|defns << e.definition}
                                defns.uniq!
                                defns.each{|defn|
                                  defn.entities.grep(Sketchup;;Edge).each{|e|
                                    if e.faces.length==2
                                      e.soft=true
                                      e.smooth=true
                                or something similar...
                                • G
                                  glro
                                  defns=[]
                                  > defns.uniq!
                                  > defns.each{|defn|
                                  >       e.soft=true
                                  >       e.smooth=true
                                  >     end
                                  yes...it works
                                  this will save me time, since i noticed that some components edges come back visible in my models, for unknown reason...
                                  now with just one clic, the problem is solved
                                  thank you
                                    The unexpected reversion of smoothed edges to solid is a known bug.
                                    Never save when in a edit session. Even an auto-save can trigger this, so never stay inside an edit session for longer than you need to...
