    Soften-Edges using by ruby
    23 Posts 7 Posters 5.3k Views 7 Watching
      Make an array of the selected edges [or of the edges within selected groups etc].
      Iterate through those edges and test it they have >1 face.
      Soft/Smooth them...
      def makesoftsmooth()
       model=Sketchup.active_model
       ss=model.selection
       ### You can assemble any collection of edges
       ### Here it's from the model's current selection
       edges=[]
       ss.to_a.each{|e|
         edges << e if e.class==Sketchup;;Edge
         e.entities.each{|ee|edges << ee if e.class==Sketchup;;Edge}if e.class==Sketchup;;Group
       edges.each{|edge|
         if edge.faces[1]
           edge.soft=true
           edge.smooth=true
      end#def
      Save code as makesoftsmooth.rb or use the def as part of a broader tool.
      Execute it as makesoftsmooth()
      This softens ALL edges that have at least 2 faces - but if you want to soften edges based on angle between its two faces use something like ang=edge.faces[0].normal.angle_between(edge.faces[1].normal) and then use edge.soft=true if ang.radians >= 45.0 etc or whatever the angle you desire [here it's 45 degrees]
        Andreas
        Soft/Smooth them...
        >  ss=model.selection
        >  edges=[]
        >  ss.to_a.each{|e|
        >  edges.each{|edge|
        >    if edge.faces[1]
        >      edge.soft=true
        >      edge.smooth=true
        >    end
        > end#def
        Thank you!
        That works well, if the edges not in a group.
        But on edges in a group it doesn´t work.
        What should I do so that it acts on the edges in a group?
        With best regards from Germany
        Andreas
          The native soft+smooth tool doesn't soft+smooth any edges that is connected to more or less than 2 faces.
            OK just adjust the code so that it's a edge.faces[1] and not edge.faces[2] test...***
            To work on a group's edges
            ###... add this into the mix...
            groups=[]
            ss.to_a.each{|e|groups << e if e.class==Sketchup;;Group}
            groups.each{|group|
              group.entities.to_a.each{|e|
                if e.class==Sketchup;;Edge and e.faces.length==2 ###***
                  e.soft=true
                  e.smooth=true
                end#if
              baldaman
              Dear TIG, I tried to edit you code in order to be able to choose the smooth angle but I didn't succeed.
              WHat am I doing wrong?
              def ss()
              ss=model.selection
              edges=[]
              ss.to_a.each{|e|
              edges.each{|edge|
                 if edge.faces[1]
                   edge.smooth=true if ang.radians >= 45.0
              end#def
                I haven't tested it but it looks OK - except I'd have used
                edge.soft=true if ang >= 45.degrees edge.smooth=true if ang >= 45.degrees
                rather than
                edge.soft=true if ang.radians >= 45.0 edge.smooth=true if ang.radians >= 45.0
                There's a type in the group part use ee NOT e...
                e.entities.each{|ee|edges << ee if **ee**.class==Sketchup::Edge}if e.class==Sketchup::Group
                But but ought to work ?
                If you get it to 'puts' edges and ang.radians etc as it iterates through what is shown in the Ruby Console ??
                  baldaman
                  Here is the code and the result,
                  I tried with different angles.
                  If I choose 90° nothing is smoothed neither soften.
                    baldaman
                    Oups, here is the code
                    def ss()
                    ss=model.selection
                    edges=[]
                    ss.to_a.each{|e|
                       e.entities.each{|ee|edges << ee if ee.class==Sketchup;;Edge}if e.class==Sketchup;;Group
                    edges.each{|edge|
                       if edge.faces[1]
                    end#def
                      The angle between adjacent faces on the cylinder's curve is 360/numsegs = 15 degrees for 24 segements so that is less than 45 degrees so they won't be smoothed !
                      I suspect you want to smooth edges that are NOT >= 45.degrees - so reverse the logic of the test to
                      edge.soft=true if ang < 45.degrees edge.smooth=true if ang < 45.degrees
                      and then 'sharp' edges will be kept 'solid' but edges with faces with similar normals will get smoothed
                      So a right-angle arris stays sharp and a nearly flat surface gets smoothed...
                        baldaman
                        ... I am soooo stupid!
                        Thank you very much, it works perfectly.
                        Thank you very much master TIG
                          That's OK 😉
                          I should have spotted the error in your logic earlier too 😮
                          • artmusicstudioA Offline
                            artmusicstudio
                            hello,
                            this piece of code is very helpful.
                            in my case this works:
                            SMOOTH LEFT
                            ss=group20.entities
                            edges=[]
                            ss.to_a.each{|e|
                            edges << e if e.class==Sketchup::Edge
                            e.entities.each{|ee|edges << ee if e.class==Sketchup::Edge}if e.class==Sketchup::Group
                            edges.each{|edge|
                            if edge.faces[1]
                            edge.soft=true
                            edge.smooth=true
                            BUT THIS ONE (smoothing with angle limit)
                            ss=group20.entities
                            edges=[]
                            ss.to_a.each{|e|
                            e.entities.each{|ee|edges << ee if ee.class==Sketchup::Edge}if e.class==Sketchup::Group
                            edges.each{|edge|
                            if edge.faces[1]
                            is quit by following:
                            VAR. 0.1 k
                            load '01.rb'
                            Error: #<NoMethodError: undefined method normal' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1516:in draw_stairs'
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:1515:in draw_stairs'
                            C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:973:in `each'
                            any idea about the "normal" problem?
                            thanx stan
                              Recast:
                              edges.each{|edge|
                              if edge.faces[1]
                              as
                              edges.each{|edge|
                              if edge.faces[1]
                              because in YOUR version you are trying to get the normal of ALL edge's faces even if an edge doesn't have any faces ! Or if the face only has one face YOUR version fails when it can't find the normal of the non-existent second face !
                                artmusicstudio
                                YEAP!
                                smooth like a sup of tea with milk on a sunny afternon......
                                smoothing works perfect , thanx a lot ("again what learned", as we say here in bavaria)
                                lost a ot of time today with fighting again coordinate systems, whatever i do, the elements don't place themselves sometimes , where i expect them to, it seems, that within groups and components the time & space works different sometimes.....
                                stan
                                  glro
                                  > groups=[]
                                  > groups.each{|group|
                                  >       e.soft=true
                                  >       e.smooth=true
                                  >     end#if
                                  it works for groups, but not for components...
                                  is it possible?
                                    Assuming ss=Sketchup.active_model.selection...
                                    defns=[]
                                    ss.grep(Sketchup;;ComponentInstance).each{|e|defns << e.definition}
                                    defns.uniq!
                                    defns.each{|defn|
                                      defn.entities.grep(Sketchup;;Edge).each{|e|
                                        if e.faces.length==2
                                          e.soft=true
                                          e.smooth=true
                                    or something similar...
                                      glro
                                      defns=[]
                                      > defns.uniq!
                                      > defns.each{|defn|
                                      >       e.soft=true
                                      >       e.smooth=true
                                      >     end
                                      yes...it works
                                      this will save me time, since i noticed that some components edges come back visible in my models, for unknown reason...
                                      now with just one clic, the problem is solved
                                      thank you
                                        The unexpected reversion of smoothed edges to solid is a known bug.
                                        Never save when in a edit session. Even an auto-save can trigger this, so never stay inside an edit session for longer than you need to...
