    [Plugin] SketchUcation Tools
    388 Posts 86 Posters 144.5k Views 84 Watching
    • F Offline
      frlic
      @tig said:
      Please empty your 'Internet Explorer' cache and restart the tool...
      In Internet Options set IE NOT to remember your history and clear the cache as it closes.
      You are seeing older css files etc clashing with the newest versions...
      I deleted the complete history in internet explorer, and Chrome. The result is the same as before.The other two cards, you can see well.
      Kreso
      overlapping rows
      FRLIĆ
      http://www.frlic.hr
        SketchUp uses IE on PC and Safari on MAC - so you don't have to worry about Chrome, Firefox etc...
        Are your sure you have completely emptied the cache?
        What version of Windows and IE do you have running ?
        • F Offline
          frlic
          I once deleted a complete history in Internet Explorer, but without result. On the pictures you can see versions of Explorer and Windows.
          Kresimir
          IE
          IE_1
          FRLIĆ
          http://www.frlic.hr
            So XP Pro with IE 8 ?
            Any one with that config having similar issues ?
            • F Offline
              frlic
              Excuse me, but I did not really understand the problem?
              Thank you for your patience.
              Kreso
              FRLIĆ
              http://www.frlic.hr
                It appears to be a css [cascading style sheet] issue.
                It IE is indeed purging properly then perhaps it's an issue with the OS and/or the version of IE.
                Could you consider an upgrade your version of IE ?
                • irwanwrI Offline
                  irwanwr
                  I thought IE 8 is the highest WinXP could use.
                    I know the minions in the SCF back-room will be beavering away right now to fix the css/html so it'll be supportive of these older browsers like IE 8 - please wait till the start of next week... πŸ˜„
                    It'll be server-side fixes, so what you currently have installed should work, but then load the fixed html/css once it's sorted...
                      g_wilson
                      Same Problem - XP HOME - IE8.
                      Internet Options: delete history on exit.
                      CCcleaner checked to analyze=>Temp Internet Files/History/Cookies/Recently typed URLs/Index.dat files/Last Download Loc'n./Autocomplete Form History.
                      Close Chrome - Close IE8 - Running SU8(last rev) + CCcleaner only.
                      Run CCcleaner=> clean history => CCcleaner re-analyze = 0 bytes.
                      Open Store => problem exists as per described => run CCcleaner (Store still open)=> IE - Temp files 126 KB 33 files and IE - Cookies 1 KB 1 files.
                      (DO NOT clean)=>Close Store => run CCcleaner=> analyze => IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                      Repeatedly opening store+closing store + CCcleaner analyze without cleaning = IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
                      Hope this gives a hint as to what is problem.
                      • irwanwrI Offline
                        irwanwr
                        Thank you very very much πŸ˜„
                          Problem possibly identified....
                          Fix will happen without needing to update tool
                            Someone on IE8 please test pluginstore 2 for me?
                            Clear cache beforehand to force new css update
                              More info please....
                              Clicking the toolbar? Clicking the menu entry? What caused the splat?
                              • irwanwrI Offline
                                irwanwr
                                It produced "Bugsplat"
                                Sketchucation Tool 1.1.3 still works fine though.
                                  When you're ready to tell us what you did prior to the splat let us know...
                                  • irwanwrI Offline
                                    irwanwr
                                    It just crashed SketchUp.
                                    Ed: Restarted SketchUp 8 and it works just fine now πŸ˜„
                                      g_wilson
                                      For me - a Eureka moment - works repeatedly open/close Store. Also works after opening IE8 again elsewhere. Also works after closing SU and restarting SU. Thank You for your efforts - This community never ceases to impress.
                                        Can either of your gents please take a screenshot of the PluginStore on your system?
                                        • irwanwrI Offline
                                          irwanwr
                                          Restarted SketchUp 8, with IE 8; all three Sketchucation Tool buttons works just fine.
                                          Thank you very much, Rich πŸ‘ πŸ˜„
                                          Does it really have anything to do with the tool? Or, the html page?
                                            g_wilson
                                            Yor wish is my command.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 19
                                            • 20
                                            • 14 / 20
