    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 433.3k Views 75 Watching
      πŸ‘ πŸ‘
      • F Offline
        frankleng
        thanks. very nice.
          Soyphrenn
          Just one question : no working with Sketchup MacOS ?
            Works just fine on my Mac (OSX 10.8.4)
            I did this a few minutes ago.
              Yea, should work on OSX. Are you getting errors?
              Did you install TT_Lib2 as well? (it's a required dependency.)
                jjduncs
                256x256 bmp taking 45 minutes to finish. Activity monitor shows Sketchup only using 5% while this is processing.
                • tt_suT Offline
                  tt_su
                  How many cores do you have? Quad core hyper-threaded? SketchUp and Ruby 1.8 only makes use of a single core.
                  256x256 pixels would produce 131072 triangles - so you'd have quite a dense mesh. Ruby is quite slow by itself, but the bottleneck here is SketchUp's speed of adding geometry. The more geometry already in the group you add to the slower it gets.
                    jjduncs
                    Yeah quad core, not sure on the hyper-threading.
                    Ended up just scaling down to 100 x 100 in PS. Still took 20 minutes though. CPU usage only spikes higher for the last maybe 20 seconds after it finishes the generating mesh task.
                    Thanks though.
                    100x100 turned out fine anyway.
                      khancyrus
                      Hello,
                      I had a question. I have tried this plugin and it works brilliant, but I feel I could only make it work for rectangular or planes curved in one plane only. I just wanted to know if it is possible with more organic or bulbous or more bulging surfaces in all x,y,z planes. Please forgive me if I'm using wrong terms or doing it wrong.
                      Btw thanks for all the plugins thomthom!
                      CSK
                      • tt_suT Offline
                        tt_su
                        You mean take a surface mapped with a texture and generate new mesh - like a displacement map would?
                          khancyrus
                          Its sth like that if Im understanding what it is, for example I wish to create a mesh a bulging surface that would have holes in it, taken from Half tone bitmaps.
                          For example, the facades of BIG's Tam Art Cross, but in this case a bulbous one! Im wondering, is it possible in sketchup?
                          http://www.big.dk/#projects-tam
                            cuttingedge
                            Hi everyone, just installed bitmap to mesh. Can anyone show me where I can locate the tool?
                              From the first post of the thread:
                                cuttingedge
                                Thanks Dave, Im so lost in my jungle of plugins..πŸ˜„
                                  Might be time to clean house.
                                    luisto
                                    on a curved surface is possible?
                                    • iichiversiiI Offline
                                      iichiversii
                                      Ok im having an issue here, being playing around with it a few hrs now and getting no where, so heres where im at, i click on mesh from Heightmap button and i select the bitmap image, it asks for weight and i select it, then depth but its failing to allow me to select, i have the red guide line but it just wont click like when i select weight, i have lib installed, so i uninstalled it, re-installed it and now a message pops up saying its in the virtual plugins store and to move it into the plugins folder, so i did that and re-start su but getting the same txt again, im completely lost, any ideas??
                                      Bring on the Rain...
                                        Empty the Plugis folder's VirtualStore.
                                        It's a sign of limited rights to the main Plugins folder...
                                        PC:
                                        As an admin [if you are not one give yourself this ability using the Control Panel > Users..]
                                        Select your Plugins folder.
                                        Right-click > context.menu > Properties > Security > Edit...
                                        Ensure each of the users/groups listed is given FULL read/write permissions...
                                        Apply/OK.
                                        These permissions changes should automatically trickle down to the contents too.
                                        Select the SketchUp.exe file in the same folder as the default Plugins folder.
                                        Right-click > context.menu > Properties > Compatibility
                                        Then tick the box 'Always run as an administrator', Apply/OK
                                        MAC:
                                        Plugins folder [HD one for v8 and User one for v2013] - properties > set FULL read/write permissions AND check the box to trickle the changes to all existing files and subfolders so current files are 'manageable' too...
                                        On a PC also ensure that your main Plugins folder does not have a 'custom-icon' 0 this can restrict even FULL permissions very subtly... AND that your user-name does not include any non-ASCII characters [e.g. accΓ©nted letters] - it's a well known limitation of the Ruby version shipped with PC SketchUp [up to and including v2013 at least], that file-paths containing non-ASCII characters can cause Ruby's 'File' operations to fail - thus preventing some simple download/processing in your ..Users../AppData../Local ../Temp folder-paths...
                                        Also check that you do NOT have an overzealous anti-virus app that stopping the download/processing of file from sketchucation.com...
                                          iichiversii
                                          Thanks TIG, ill try this out tomorrow and get back to you if i get it working πŸ‘
                                            iichiversii
                                            Ok i got the Lib thing sorted but im still running into that issue where "mesh from heightmap" wont allow me to select depth, still confused, anyone else had this issue and solved it?
                                            • 13
                                            • 14
                                            • 2 / 14
