    Cut Openings On Both Sides of Roof Pitch
    11 Posts 5 Posters 1.5k Views 5 Watching
      Do you mean by using an opening-cutting component?
      • spenceS
        spence
        Dave,
        Yes I do. Creating a component that uses the Cut-Opening feature and having it work on both sides of the roof pitch.
        Spence
        • JQLJ
          JQL
          No chance spence... Tried it and failed!
          There is only one plane for hole cutting components. You have a simmetric geometry there so you could create only half component and mirror it if you'd like.
          You had to then hide some edges on the cutting plane, so they wouldn't show on the openning, and also the edges on the sides, so the walls would look continuous.
          Almost no work would be lost...
          Best regards,
          JQL
          www.casca.pt
          Visit us on facebook!
          • P
            pcmoor
            one method is build various cutting planes within a wrapper component, thus activating them and leaving other embedded objects after exploding
            note that the wrapper has its own cutting plane, the axis is also placed for ease of use
            However the outline of the existing edge is left behind (the ridge in this case)
            Philip
            insert @ ridge line then explode
            • JQLJ
              JQL
              pcmoor,
              Yes you could do that and I've considered it once or twice, for standard doors and windows.
              I didn't find it practical though... Why create a more complex component that you have to explode, if it is easier to just have 1 simple component mirrored?
              Have you found other practical uses for that method? I definetly think Sketchup should have multiple hole cutting components. Those, combined with dynamic components, could become interesting...
              Best regards,
              JQL
              www.casca.pt
                I think in this case you'd be better off making the hole[s] in the two roof planes manually, then if you want to relocate a rooflight just select the instance and the geometry of the roof planes forming the hole.
                You can copy/paste geometry that forms the edges of the 'holes', so you need not necessarily have to manually form each hole, once one is hole-set done to your liking...
                • spenceS
                  spence
                  Good suggestions. I tried the mirror one half of the component and that seems to work fine. What I was hoping for is to be able to turn one skylight option off and another on all while both could "Cut-Openings" but this does not seem to work. When I hide the component layer the "Cut-Opening" appears on the roof.
                  Spence
                  • JQLJ
                    JQL
                    I'm not sure I understand your problem, but I think what you need is this:
                    ![Scene 1 - No layers but "Layer 0" are visible](/uploads/imported_attachments/DDqW_Holecutlayers-Scene1.jpg "Scene 1 - No layers but "Layer 0" are visible")
                    Scene 2 - Layer 1 visible
                    Scene 3 - Layer 2 visible
                    Scene 4 - All layers visible
                    So take a look at the model attached.
                    Hole cut layers.skp
                    Best Regards,
                    JQL
                    www.casca.pt
                    • spenceS
                      spence
                      JQL,
                      That's it! So I have exactly that going on and when I hide one skylight option the cut-opening stay on the roof, but I have since found out that they go away after clicking in and out of the group. Thanks for all you help I think I have "Cut-Openings" completely covered.
                      S
                      Spence
                      • JQLJ
                        JQL
                        Glad I could help.
                        Best regards,
                        JQL
                        www.casca.pt
