    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 229.9k Views 51 Watching
      The 2D#.rb file is the initial-loader for my 2Dtools.
      It will try to load a file in the 2DTools subfolder that is named 2D#loader.rb.
      This 2D#.rb file and its 2DTools folder must be in the same directory - which is usually Plugins. but as long as it is on the $LOAD_PATH list it should be OK.
      This 2D#loader file in turn loads various 2d tools rb files from the subfolder to make a single submenu and the 2Dtools toolbar.
      Fredo's tool can generate some odd errors, e.g. if you have 'dislocated' a loader rb and its subfolder of scripts.
      This error message bears no resemblance to anything that this particular file does, so either it is this dislocation issue [which I suspect], OR you have somehow corrupted the rb file - perhaps you have opened it in a wordprocessor rather than a plain-text editor, which would have then added formating to the text that will break SketchUp when it tries to load it...
      • irwanwrI Offline
        irwanwr
        I've been using this plugin for long and haven't found any problem yet.
        Until now. I installed SketchUp in this PC of a friend along with the plugin I've been using too in the PC at home.
        But it gave me this message and I don't understand what it means;
        I've tried to reinstall the LibFredo.
        • fredo6F Offline
          @irwanwr
          Which version of LibFredo6 are you installing?
          • mitcorbM Offline
            mitcorb
            @dante: your error message appears to be about VRay, not Additional Plugins Folder by Fredo6. Or, do you mean that your Vray is contained there?
            • irwanwrI Offline
              irwanwr
              It was 4.7a, then last night just downloaded 4.9b.
              Edit:
              Hi, Fredo6
              Everything works fine now with the recent LibFredo 4.9 ๐Ÿ‘ ๐Ÿ˜„
              • fredo6F Offline
                NEW RELEASE 3.2a - 12 Jun 2013
                Minor update giving more detail when errors are encountered during the Plugin load process (exect file and line in the Ruby code)
                Also available on the SCF Plugin Store.
                http://sketchucation.com/resources/pluginstore?pln=000_AdditionalPluginFolders
                See first post of this thread for downloading the script.
                  thanks Fredo
                  • fredo6F Offline
                    NEW RELEASE 4.0 - 30 Aug 2013
                    Important update made necessary for the release LibFredo6 5.2 when it comes
                    This is in relation with the lengthy changes of naming conventions to my plugins (LibFredo6 will now be based on the name Fredo6_!LibFredo6). If you do not upgrade, then you will continue loading the previous version of LibFredo6.
                    • fredo6F Offline
                      NEW RELEASE 4.1 - 01 Sep 2013
                      Change of name of the Plugin file and Important update made necessary for the release LibFredo6 5.2 when it comes
                      the ruby file is now named !AdditionalPluginFolders.rb instead of 000_AdditionalPluginFolders.rb.
                      This should be transparent to you, but it is a good idea to delete the old file 000_AdditionalPluginFolders.rb. If you have LibFredo6 installed, you can do it via the Purge Obsolete Files utility.
                      Sorry for inconvenience with all these name changes, but it is part of the general evolution to have a cleaner footprint of files and folders for scripts.
                      • LanaL Offline
                        Lana
                        Very, very, very thanks. You are good.
                        • fredo6F Offline
                          NEW RELEASE 4.2a - 23 Oct 2013
                          Important update for future Sketchup compatibility. Also necessary for the release LibFredo6 5.3 when it comes
                            If you click the More Info button in the PluginStore in SketchUp you'll see something new for displaying help on Plugins....๐Ÿ˜‰
                              loukas87
                              hi guys, amazing posts, but I can t understand how to download and install this plugins, someone will be so pretty to help me? I m using sketch up 8 pro.
                              Thanks in advance
                              • chonC Offline
                                chon
                                Hello,
                                just click on "!AdditionalPluginFolders.rb" in the first post of this thread and save it in your SU8 plugins folder... ๐Ÿ˜‰
                                • chonC Offline
                                  chon
                                  I've got an issue with the TIG's extrusion Tools and don't find the solution.
                                  Here is the error message :
                                  I've got only four icons in the toolbar :
                                  Here is my AdditionalPluginFolder :
                                  Any idea ?
                                  Many thanks ! ๐Ÿ˜‰
                                    The Extrude tools requires deBabelizer.rb loading [as the message tells you].
                                    It translates text, menus etc into other locales' langauages...
                                    This additional .rb file is supplied inside the main tool's RBZ archive or AutoInstalled version.
                                    BUT if you have never installed it, or later on you have removed it then it will break this and several other plugins that will not load or work without its presence.
                                    If you have Disabled it using the Plugins Manager then you would have been warned about the consequences: in this case permanently Enable it if you want to be able to load/use any of the tools that need it... If not, then reinstall it properly and check that the files are ALL includes in the installation...
                                    Here is a view of the contents of the Extrude tools archive - the same two rb files and subfolder [containing several other files] need to be be in your Plugins folder in the same relative relationships [you can use a custom-plugins folder if desired]
                                    • chonC Offline
                                      chon
                                      Again...
                                      Another issue with... Fredo6's FredoTools ! ๐Ÿ˜ฎ ๐Ÿ˜„
                                      Here is the first error message :
                                      Here is the second error message :
                                      And here is my AdditionalPluginFolder :
                                      Precision : All my plugIns are up to date.
                                      Any help ? ๐Ÿ˜‰
                                      Many thanks
                                        Your plugins are NOT up to date ๐Ÿ˜’
                                        You have an older version of my Extrude tools files shown in the Plugins folder.
                                        The current version is NOT there !
                                        Get and install the latest version.
                                        See my recent post - the tool now installs deBabaleizer.rb and then ExtrudeTools.rb and the matching ExtrudeTools subfolder [neither of which are shown in your list!].
                                        All earlier 'EEby...' rb files are auto-deleted by the newer script's reload ?
                                        You need to restart SketchUp and see what happens...
                                        You also seem to have separate issues with some of Fredo's plugins...
                                        Are you sure you have set your Plugins folder's context-menu > Properties > Security > Edit... to have read/write permissions 'FULL', for every user/group in the list. Also set SketchUp.exe Properties > Compatibility... to 'Always run as Administrator'...
                                        • chonC Offline
                                          chon
                                          @tig said:
                                          The Extrude tools requires deBabelizer.rb...
                                          Many thanks TIG ! ๐Ÿ‘
                                          As you saw it, i didn't have the latest version of the plugin. ๐Ÿ˜•
                                          Shame on me ! ๐Ÿ˜ณ
                                          Every thing is fine with your tools now !
                                          • chonC Offline
                                            chon
                                            When i wrote that my plugins are up to date, i was talking about Fredo6's plugins, not yours... ๐Ÿ˜‰
                                            • 6 / 8
