    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 258.8k Views 51 Watching
    • fredo6F Offline
      NEW RELEASE 4.0 - 30 Aug 2013
      Important update made necessary for the release LibFredo6 5.2 when it comes
      This is in relation with the lengthy changes of naming conventions to my plugins (LibFredo6 will now be based on the name Fredo6_!LibFredo6). If you do not upgrade, then you will continue loading the previous version of LibFredo6.
      Also available on the SCF Plugin Store.
      http://sketchucation.com/resources/pluginstore?pln=000_AdditionalPluginFolders
      See first post of this thread for downloading the script.
      • fredo6F Offline
        NEW RELEASE 4.1 - 01 Sep 2013
        Change of name of the Plugin file and Important update made necessary for the release LibFredo6 5.2 when it comes
        the ruby file is now named !AdditionalPluginFolders.rb instead of 000_AdditionalPluginFolders.rb.
        This should be transparent to you, but it is a good idea to delete the old file 000_AdditionalPluginFolders.rb. If you have LibFredo6 installed, you can do it via the Purge Obsolete Files utility.
        Sorry for inconvenience with all these name changes, but it is part of the general evolution to have a cleaner footprint of files and folders for scripts.
        • LanaL Offline
          Lana
          Very, very, very thanks. You are good.
          • fredo6F Offline
            NEW RELEASE 4.2a - 23 Oct 2013
            Important update for future Sketchup compatibility. Also necessary for the release LibFredo6 5.3 when it comes
            • Rich O BrienR Online
              If you click the More Info button in the PluginStore in SketchUp you'll see something new for displaying help on Plugins....๐Ÿ˜‰
                loukas87
                hi guys, amazing posts, but I can t understand how to download and install this plugins, someone will be so pretty to help me? I m using sketch up 8 pro.
                Thanks in advance
                • chonC Offline
                  chon
                  Hello,
                  just click on "!AdditionalPluginFolders.rb" in the first post of this thread and save it in your SU8 plugins folder... ๐Ÿ˜‰
                  • chonC Offline
                    chon
                    I've got an issue with the TIG's extrusion Tools and don't find the solution.
                    Here is the error message :
                    I've got only four icons in the toolbar :
                    Here is my AdditionalPluginFolder :
                    Any idea ?
                    Many thanks ! ๐Ÿ˜‰
                    • TIGT Online
                      The Extrude tools requires deBabelizer.rb loading [as the message tells you].
                      It translates text, menus etc into other locales' langauages...
                      This additional .rb file is supplied inside the main tool's RBZ archive or AutoInstalled version.
                      BUT if you have never installed it, or later on you have removed it then it will break this and several other plugins that will not load or work without its presence.
                      If you have Disabled it using the Plugins Manager then you would have been warned about the consequences: in this case permanently Enable it if you want to be able to load/use any of the tools that need it... If not, then reinstall it properly and check that the files are ALL includes in the installation...
                      Here is a view of the contents of the Extrude tools archive - the same two rb files and subfolder [containing several other files] need to be be in your Plugins folder in the same relative relationships [you can use a custom-plugins folder if desired]
                      • chonC Offline
                        chon
                        Again...
                        Another issue with... Fredo6's FredoTools ! ๐Ÿ˜ฎ ๐Ÿ˜„
                        Here is the first error message :
                        Here is the second error message :
                        And here is my AdditionalPluginFolder :
                        Precision : All my plugIns are up to date.
                        Any help ? ๐Ÿ˜‰
                        Many thanks
                        • TIGT Online
                          Your plugins are NOT up to date ๐Ÿ˜’
                          You have an older version of my Extrude tools files shown in the Plugins folder.
                          The current version is NOT there !
                          Get and install the latest version.
                          See my recent post - the tool now installs deBabaleizer.rb and then ExtrudeTools.rb and the matching ExtrudeTools subfolder [neither of which are shown in your list!].
                          All earlier 'EEby...' rb files are auto-deleted by the newer script's reload ?
                          You need to restart SketchUp and see what happens...
                          You also seem to have separate issues with some of Fredo's plugins...
                          Are you sure you have set your Plugins folder's context-menu > Properties > Security > Edit... to have read/write permissions 'FULL', for every user/group in the list. Also set SketchUp.exe Properties > Compatibility... to 'Always run as Administrator'...
                          • chonC Offline
                            chon
                            @tig said:
                            The Extrude tools requires deBabelizer.rb...
                            Many thanks TIG ! ๐Ÿ‘
                            As you saw it, i didn't have the latest version of the plugin. ๐Ÿ˜•
                            Shame on me ! ๐Ÿ˜ณ
                            Every thing is fine with your tools now !
                            • chonC Offline
                              chon
                              When i wrote that my plugins are up to date, i was talking about Fredo6's plugins, not yours... ๐Ÿ˜‰
                              • chonC Offline
                                chon
                                Issue with Shape Bender.
                                It doesn't work when SB files and folder are placed in the AdditionalPluginFolder but works fine when placed in the SU plugins folder.
                                • TIGT Online
                                  It doesn't work when SB files and folder are placed in the AdditionalPluginFolder, but works fine when placed in the SU plugins folder.
                                  This is a known issue in any version using a non-standard Plugins folder.
                                  Reread the ShapeBender thread.
                                  I have recently posted a simple change to the loader script's code that fixes it to load from anywhere in the $LOAD_PATH list...
                                  http://sketchucation.com/forums/viewtopic.php?p=494591#p494591
                                  • chonC Offline
                                    chon
                                    Thanks TIG ! ๐Ÿ‘
                                    • chonC Offline
                                      chon
                                      TIG,
                                      thanks a lot for Shape Bender, works fine now !
                                      I've got the same problem with Didier Bur's Projections.
                                      Do you think you could do something for us if you've got a quiet moment ? ๐Ÿ˜ณ
                                      • TIGT Online
                                        @Chon
                                        Edit the loader ' projection_extension.rb' file
                                        In line#2:
                                        Sketchup::require Sketchup.find_support_file("Plugins") + '/Projection/projection'
                                        add a leading # to disable it:
                                        #Sketchup::require Sketchup.find_support_file("Plugins") + '/Projection/projection'
                                        Then add in a line below it thus:
                                        Sketchup::require(File.join(File.dirname(__FILE__), 'Projection', 'projection'))
                                        It should now work properly from any Plugins folder's location, provided that the loader rb and the folder of other files are in the same Plugins folder... [although the rbs format for the main code file is an perhaps unknown quantity]...
                                        • chonC Offline
                                          chon
                                          I'll try that on monday morning. ๐Ÿ˜‰
                                          • chonC Offline
                                            chon
                                            Works fine ! Thanks TIG ! ๐Ÿ‘
                                            • 5 / 8
