    [Plugin] !AdditionalPluginFolders - v5.4a - 27 Sep 20
    156 Posts 51 Posters 266.6k Views 51 Watching
    • W
      water520
      thank you
      • Z
        Zonicn2t
        Thank you
          dante115
          what is this error ?
          https://lh6.googleusercontent.com/-dOZUFuLXLfU/UXGSl-DA0JI/AAAAAAAAAZI/hBaTZFLedC4/s1361/Untitled.jpg
            scott216
            I have a plugin that doesn't run if I put it in the additional plugin folder. This is the plugin: http://code.google.com/p/sketchup-svg-outline-plugin/downloads/list
            Attached is a screenshot of the errors I get.
            I'd appreciate any suggestions that will get this to work.
            • fredo6F
              Scott,
              Never heard of these plugins.
              Anyway, they may not be able to run in another directory than the native Sketchup Plugins folder.
              Or they may have bug. Keep in mind that 000_AdditionalPluginFolders just reports in clear what Ruby would find as an error at startup time, but without showing it to the user. And also, trapping the errors, avoid that the whole load process stops.
                The 2D#.rb file is the initial-loader for my 2Dtools.
                It will try to load a file in the 2DTools subfolder that is named 2D#loader.rb.
                This 2D#.rb file and its 2DTools folder must be in the same directory - which is usually Plugins. but as long as it is on the $LOAD_PATH list it should be OK.
                This 2D#loader file in turn loads various 2d tools rb files from the subfolder to make a single submenu and the 2Dtools toolbar.
                Fredo's tool can generate some odd errors, e.g. if you have 'dislocated' a loader rb and its subfolder of scripts.
                This error message bears no resemblance to anything that this particular file does, so either it is this dislocation issue [which I suspect], OR you have somehow corrupted the rb file - perhaps you have opened it in a wordprocessor rather than a plain-text editor, which would have then added formating to the text that will break SketchUp when it tries to load it...
                • irwanwrI
                  irwanwr
                  I've been using this plugin for long and haven't found any problem yet.
                  Until now. I installed SketchUp in this PC of a friend along with the plugin I've been using too in the PC at home.
                  But it gave me this message and I don't understand what it means;
                  I've tried to reinstall the LibFredo.
                  • fredo6F
                    @irwanwr
                    Which version of LibFredo6 are you installing?
                    • mitcorbM
                      mitcorb
                      @dante: your error message appears to be about VRay, not Additional Plugins Folder by Fredo6. Or, do you mean that your Vray is contained there?
                      • irwanwrI
                        irwanwr
                        It was 4.7a, then last night just downloaded 4.9b.
                        Edit:
                        Hi, Fredo6
                        Everything works fine now with the recent LibFredo 4.9 ๐Ÿ‘ ๐Ÿ˜„
                        • fredo6F
                          NEW RELEASE 3.2a - 12 Jun 2013
                          Minor update giving more detail when errors are encountered during the Plugin load process (exect file and line in the Ruby code)
                          Also available on the SCF Plugin Store.
                          http://sketchucation.com/resources/pluginstore?pln=000_AdditionalPluginFolders
                          See first post of this thread for downloading the script.
                            thanks Fredo
                            • fredo6F
                              NEW RELEASE 4.0 - 30 Aug 2013
                              Important update made necessary for the release LibFredo6 5.2 when it comes
                              This is in relation with the lengthy changes of naming conventions to my plugins (LibFredo6 will now be based on the name Fredo6_!LibFredo6). If you do not upgrade, then you will continue loading the previous version of LibFredo6.
                              • fredo6F
                                NEW RELEASE 4.1 - 01 Sep 2013
                                Change of name of the Plugin file and Important update made necessary for the release LibFredo6 5.2 when it comes
                                the ruby file is now named !AdditionalPluginFolders.rb instead of 000_AdditionalPluginFolders.rb.
                                This should be transparent to you, but it is a good idea to delete the old file 000_AdditionalPluginFolders.rb. If you have LibFredo6 installed, you can do it via the Purge Obsolete Files utility.
                                Sorry for inconvenience with all these name changes, but it is part of the general evolution to have a cleaner footprint of files and folders for scripts.
                                • LanaL
                                  Lana
                                  Very, very, very thanks. You are good.
                                  • fredo6F
                                    NEW RELEASE 4.2a - 23 Oct 2013
                                    Important update for future Sketchup compatibility. Also necessary for the release LibFredo6 5.3 when it comes
                                      If you click the More Info button in the PluginStore in SketchUp you'll see something new for displaying help on Plugins....๐Ÿ˜‰
                                      • L
                                        loukas87
                                        hi guys, amazing posts, but I can t understand how to download and install this plugins, someone will be so pretty to help me? I m using sketch up 8 pro.
                                        Thanks in advance
                                        • chonC
                                          chon
                                          Hello,
                                          just click on "!AdditionalPluginFolders.rb" in the first post of this thread and save it in your SU8 plugins folder... ๐Ÿ˜‰
                                          SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                                          • chonC
                                            chon
                                            I've got an issue with the TIG's extrusion Tools and don't find the solution.
                                            Here is the error message :
                                            I've got only four icons in the toolbar :
                                            Here is my AdditionalPluginFolder :
                                            Any idea ?
                                            Many thanks ! ๐Ÿ˜‰
                                            • 4 / 8
