    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      leaosenzala
      @thkian92 said:
      Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
      what i did was change the extension rbz to zip then extract to plugin folder
        Are they really in the folder?
        Do you have full security access rights to your Plugins folder?
        Were all files left in the same relationship [subfolders etc] as in the RBZ [ZIP]?
        Because you didn't bother to complete your User-Info we don't know your OS [although we can guess 64bit PC] or your SUp Version.
        If you have SUp v8 or v2013 you could far more easily install RBZ files etc in several ways... avoiding any of the complications you outlined...
        This kind of issue has been discussed many times, in many threads...
          ChEBaNaNa
          This Plugin is probably the best Plugin i've ever seen....
          Big Thanks from Switzerland!!!!! 😃
          • plot-parisP Offline
            plot-paris
            Hey tak2hata,
            excellent plugin! It is fun to use and a great enhancement for SketchUp.
            However, sometimes I find it a bit difficult to master. Therefore I have two ideas:
            1. Some of the settings use units that are not very intuitive. The stiffness for example is measured in a undefined number. Or while the jitter options use percent, the direction and force options use meters (which can be difficult, so that one has to test a lot before achieving the right result).
              I think it might be better to have those as a percentage as well (0% no effect, 100% full effect). Like that one can see a linear increase of the effect, which makes it easier to understand.
            2. Some of the settings are not self-explanatory. Do you think it would be possible to add tooltips that show up, when you hover over the setting with your cursor for some time? You know, with a short description of what the setting does...
            Would be great to hear your opinion on this...
              bb6
              谢谢!hebeijianke
                Sharkyzero
                I don't seem to be getting the results everybody else is. I make a grass square and make it a component, then I try to use the crowd maker and it puts the grass everywhere else other than what I have selected. Anybody else have this problem? Also, how do you get so much grass? My comp is no slouch and it virtually crashes whenever I try to get more than a little bit in view.
                  tak2hata
                  Hi,Sharkyzero.
                  I need to know your detail to help the problems.
                  Please upload screenshot of your model and crownd maker dialog.
                  crowdmaker
                  Thanks.
                  by TAK2HATA
                    Sharkyzero
                    I just realized something, Tak. I think the fact that I'm not using instances of the grass components is screwing with everything. Let me fiddle around with it some more and I'll see if I can't get it working the way I think it should.
                      tak2hata
                      Hi,Sharkyzero.
                      Good luck for fiddle around with it.
                      Please ask me when you didn't get it working fine.
                      Thanks.
                      by TAK2HATA
                        chillotti
                        Hi everybody, I have a problem, I can’t install the plugin Fur Maker, I put the file http://sketchucation.com/resources/pluginstore?pln=fur_en
                        And also the new icons
                        http://sketchucation.com/forums/viewtopic.php?f=323&t=28092&start=480
                        in the
                        Can you help me? Please
                        Carlo
                          tak2hata
                          in the
                          Carlo
                          Hi,chillotti.
                          I guess you didn't use autoinstall from sketchupucation store tool.
                          You must unzip the rbz file when you manually install it.
                          Change the extenstion name "rbz" to "zip".and unzip it.
                          "fur_en.rb" and "fur_en" folder will be shown.
                          Copy both to plugin folder.
                          And New Icon file "fur_en.rar" must unzip ,also.
                          Copy the created png file to "fur_en" folder in plugins folder.
                          Thanks.
                          by TAK2HATA
                            SuperJesus
                            This was working previously for me but there are certain components that dont seem to want to constrain the surface I select. The preview shows everything in the right place but then they appear randomly spread out in mid air over a huge area when I do it. Its only certain components with the same settings so I don't get it. Has anybody had this issue before?
                              tak2hata
                              Hi,SuperJesus.
                              I guess your problem of fur.
                              watch video
                              Please Check the axis origin of the component.
                              Thanks.
                              by TAK2HATA
                              • bulbaB Offline
                                bulba
                                thanks tak2hata..
                                this plugin is very useful
                                • Y Offline
                                  Yoshi Ikeda
                                  Hy,
                                  The fur plug in work for sketch up 8 Pro BUT it doesnot work in sketch up 2013 Pro,
                                  Any advice?
                                  Regards,
                                  Yoshi Ikeda
                                    It should work.
                                    What is the problem ?
                                    We need help here 😕
                                    How can we help you, if you don't try to help us 😒
                                      mjursevs
                                      Hi, wondering if someone could please help me.
                                      I've been using make fur fine for the last while, but it has suddenly stopped working completely.
                                      I know how to use it, but now when I push the Make Fur button, nothing happens. No collecting faces, nothing. I'm at a loss. Has anyone ever experienced something like this?
                                      Any insights would be greatly appreciated.
                                        Have you recently installed any new plugins that might be messing with this one? Maybe the Vray plugin or Sketchy Physics?
                                          mjursevs
                                          Nope, no new plugins as of late.
                                          Was working earlier this week, now won't work whatsoever, no new plugins installed since.
                                          Have tried everything I feel. Played with all the options, components, new sketchup files, restarting computer, blah.
                                          Any other suggestions?
                                            If you try using it with the Ruby Console open are there any error messages ?
                                            Have you recently changed things that might have affected your Plugins folder's security permissions?
                                            Select its icon, right-click > context-menu > Properties > Security > Edit... make sure every user/group listed has FULL read/write permissions ticked.
                                            Apply/OK
                                            Also select the SketchUp.exe icon and similarly: right-click > context-menu > Properties > Compatibility > Check the box 'Always run as administrator' > Apply/OK...
                                            Restart SketchUp...
                                            If it still fails to work...
                                            In the ../Plugins/fur_en folder there's a file called fur_param3.ini, edit it with Notepad and delete all of the entries, then save it: now 'fur' should start on a SketchUp restart with its default settings...
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 32
                                            • 33
                                            • 23 / 33
