    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
      JuanV.Soler
      The **Text Editor**still works with the same workaround of unticking the extrude function to get the heights modified
        What does TT::Plugins::Editor3dText::PLUGIN_VERSION report.
        And what version of Internet Explorer do you have installed?
        (Lots of questions here - but I'm baffled by what is going on here. It should be working... :s )
          JuanV.Soler
          it reports :
          about Internet Explorer :
          now those are all my credentials 😄
            Your 3d Text Editor is out of date. It should be 1.1.3 - if you install the version from EW.
              JuanV.Soler
              ............finally.............succeeded
              .......tyuuuu....... 👍
                  matt.gordon320
                  Hi Thomthom, thanks again for an awesome plugin. I have an idea for a feature that some might find useful if they're doing visualization work - vertically stacked text (like the following, perhaps).
                  http://2.bp.blogspot.com/_nswHPYi_dEw/SoWP9m4sr6I/AAAAAAAAH_4/BUtChw6LSK8/s400/P1000262.JPG
                  Any way, just a thought! Thanks for creating so many awesome tools, it's inspiring. I'm slowly learning code, and it's great to see what you've written.
                  Matt
                    FWIW, you can already make vertically stacked text. It would be nice to be able to control things like leading and kerning, though.
                    • G
                      glro
                      i downloaded and installed you plugin an TT_Lib_v2.8.3.rbz
                      but then, when sketchup was launched, a message said i have to download TT_Lib2-2.8.0.rbz
                      so i uninstalled TT_Lib_v2.8.3.rbz and installed TT_Lib2-2.8.0.rbz
                      and then it worked
                      you did a great job
                      you managed to make a multilines editor...
                      would it be possible to ...? 😛
                      have the 3d text in a red/blue plan, instead of red/green?
                      i would like to use your plugin to add comments to a scene, one comment per scene; usually, the camera is oriented so that vertical objects appear vertical
                      So, it would be easier to read if the text was in the red/blue plan.
                      • G
                        glro
                        and then it worked
                        you did a great job
                        no, i just realised that you can change the plan by writing on a face of the model; so to write vertically, you just have to find a vertical face in the model
                        • tt_suT
                          tt_su
                          Whaaat? 😕
                          You shouldn't need to downgrade. Are you on Windows by any chance?
                          Maybe you ended up with some files in VirtualStore...
                          How did you install it?
                          • G
                            glro
                            Whaaat? 😕
                            windows 7 64 bits
                            installed using preferences > extensions
                            downloaded vers 2.8.3 here
                            http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                            but it didn't work so i downloaded the previous version using the link that appeared on my screen
                            but it's OK now;works great
                            • tt_suT
                              tt_su
                              That is strange. I need to look into that.
                                matt.gordon320
                                @dave r said:
                                [attachment=0:38jz7em6]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:38jz7em6]
                                http://s23.postimg.org/pu5me6ejb/3d_text_editor.jpg
                                Dave/TT - I'm glad to hear it's already capable, but here's the embarrassing part:I can't figure out how to do it 😳 . I've updated to the most recent version, but maybe I have an older version floating around in Virtual Store or something?
                                EDIT - Ok I'm stupid. I just realized what you meant @Dave.
                                http://s24.postimg.org/x152egbj9/I_m_Stupid.jpg
                                download screenshot
                                  Matt, I hope this doesn't embarrass you further. Try using Enter between typing the letters. 😉 I setting Align to Center. You may need to play with the leading (spacing) between the letters after you've created the text but that will depend upon the font you choose.
                                  Edit: You edited your post while I was typing. 😄 Now you've got it and if anyone asked, it was a great day because you learned something. 👍
                                    matt.gordon320
                                    Haha no worries Dave. I've frequently found that publicly making a fool of myself is the best way to learn, and I'm ok with that 😄 I'm sure you experienced programmers will have a good laugh when I finally get around to releasing an actual plugin.
                                    • tt_suT
                                      tt_su
                                      Don't be shy - it'll be great! Dig into it! Only way to learn. I make myself look silly every day. (Trust me!)
                                      • ntxdaveN
                                        ntxdave
                                        I really like the plugin but have a couple of things I would like for it to do (if possible):
                                        1. I would like for it to remember my selections (font, size, alignment, etc.) so that I do not have to go through the selections everytime.
                                        2. I would like to be able to specify the color (both face and outline if possible). In fact, it would be great if there was a way to eliminate the outline. I have a lot of text to enter in my model and it is a pain to go eliminate the outline all of the time.
                                        Press F1...thank me later
                                        • tt_suT
                                          tt_su
                                          "Outline"?
                                            I suppose he means he's hiding the edges.
                                            @ntxdave, how is it that you current "eliminate the outline" on 3D text?
