    [Plugin] 3D Text Editor
    204 Posts 51 Posters 231.0k Views 50 Watching
      ? Really? No menu under the Plugins menu?
        JuanV.Soler
        no , no menu under the Plugins menu
          what happens if you type this into the ruby console: TT::Plugins::VirtualStore.check_virtualstore
            JuanV.Soler
            The **Text Editor**still works with the same workaround of unticking the extrude function to get the heights modified
              What does TT::Plugins::Editor3dText::PLUGIN_VERSION report.
              And what version of Internet Explorer do you have installed?
              (Lots of questions here - but I'm baffled by what is going on here. It should be working... :s )
                JuanV.Soler
                it reports :
                about Internet Explorer :
                now those are all my credentials 😄
                  Your 3d Text Editor is out of date. It should be 1.1.3 - if you install the version from EW.
                    JuanV.Soler
                    ............finally.............succeeded
                    .......tyuuuu....... 👍
                        matt.gordon320
                        Hi Thomthom, thanks again for an awesome plugin. I have an idea for a feature that some might find useful if they're doing visualization work - vertically stacked text (like the following, perhaps).
                        http://2.bp.blogspot.com/_nswHPYi_dEw/SoWP9m4sr6I/AAAAAAAAH_4/BUtChw6LSK8/s400/P1000262.JPG
                        Any way, just a thought! Thanks for creating so many awesome tools, it's inspiring. I'm slowly learning code, and it's great to see what you've written.
                        Matt
                          FWIW, you can already make vertically stacked text. It would be nice to be able to control things like leading and kerning, though.
                          • G
                            glro
                            i downloaded and installed you plugin an TT_Lib_v2.8.3.rbz
                            but then, when sketchup was launched, a message said i have to download TT_Lib2-2.8.0.rbz
                            so i uninstalled TT_Lib_v2.8.3.rbz and installed TT_Lib2-2.8.0.rbz
                            and then it worked
                            you did a great job
                            you managed to make a multilines editor...
                            would it be possible to ...? 😛
                            have the 3d text in a red/blue plan, instead of red/green?
                            i would like to use your plugin to add comments to a scene, one comment per scene; usually, the camera is oriented so that vertical objects appear vertical
                            So, it would be easier to read if the text was in the red/blue plan.
                            • G
                              glro
                              and then it worked
                              you did a great job
                              no, i just realised that you can change the plan by writing on a face of the model; so to write vertically, you just have to find a vertical face in the model
                              • tt_suT
                                tt_su
                                Whaaat? 😕
                                You shouldn't need to downgrade. Are you on Windows by any chance?
                                Maybe you ended up with some files in VirtualStore...
                                How did you install it?
                                • G
                                  glro
                                  Whaaat? 😕
                                  windows 7 64 bits
                                  installed using preferences > extensions
                                  downloaded vers 2.8.3 here
                                  http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                                  but it didn't work so i downloaded the previous version using the link that appeared on my screen
                                  but it's OK now;works great
                                  • tt_suT
                                    tt_su
                                    That is strange. I need to look into that.
                                      matt.gordon320
                                      @dave r said:
                                      [attachment=0:38jz7em6]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:38jz7em6]
                                      http://s23.postimg.org/pu5me6ejb/3d_text_editor.jpg
                                      Dave/TT - I'm glad to hear it's already capable, but here's the embarrassing part:I can't figure out how to do it 😳 . I've updated to the most recent version, but maybe I have an older version floating around in Virtual Store or something?
                                      EDIT - Ok I'm stupid. I just realized what you meant @Dave.
                                      http://s24.postimg.org/x152egbj9/I_m_Stupid.jpg
                                      download screenshot
                                        Matt, I hope this doesn't embarrass you further. Try using Enter between typing the letters. 😉 I setting Align to Center. You may need to play with the leading (spacing) between the letters after you've created the text but that will depend upon the font you choose.
                                        Edit: You edited your post while I was typing. 😄 Now you've got it and if anyone asked, it was a great day because you learned something. 👍
                                          matt.gordon320
                                          Haha no worries Dave. I've frequently found that publicly making a fool of myself is the best way to learn, and I'm ok with that 😄 I'm sure you experienced programmers will have a good laugh when I finally get around to releasing an actual plugin.
                                          • tt_suT
                                            tt_su
                                            Don't be shy - it'll be great! Dig into it! Only way to learn. I make myself look silly every day. (Trust me!)
                                            • 11
                                            • 5 / 11
