    [Plugin] 3D Text Editor
    202 Posts 50 Posters 219.4k Views 49 Watching
      JuanV.Soler
      thomthom I have done it several times to no avail .
      It remains a mystery to me .
        Just to be sure - if you try this utility: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
        And use "Check Virtual Store" - what happens then?
        Also, what is the output of TT::Lib::VERSION if you type it into the Ruby Console?
          But you still get the warning? Did you use the VirtualStore check utility?
            JuanV.Soler
            now that´s funny , it says :
            so I do have installed the latest version after all
            I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
              JuanV.Soler
              no more warnings no . I think that the trick was to ignore the first warning after installed
              As I edited my latest post : I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
                ? Really? No menu under the Plugins menu?
                  JuanV.Soler
                  no , no menu under the Plugins menu
                    what happens if you type this into the ruby console: TT::Plugins::VirtualStore.check_virtualstore
                      JuanV.Soler
                      The **Text Editor**still works with the same workaround of unticking the extrude function to get the heights modified
                        What does TT::Plugins::Editor3dText::PLUGIN_VERSION report.
                        And what version of Internet Explorer do you have installed?
                        (Lots of questions here - but I'm baffled by what is going on here. It should be working... :s )
                          JuanV.Soler
                          it reports :
                          about Internet Explorer :
                          now those are all my credentials 😄
                            Your 3d Text Editor is out of date. It should be 1.1.3 - if you install the version from EW.
                              JuanV.Soler
                              ............finally.............succeeded
                              .......tyuuuu....... 👍
                                  matt.gordon320
                                  Hi Thomthom, thanks again for an awesome plugin. I have an idea for a feature that some might find useful if they're doing visualization work - vertically stacked text (like the following, perhaps).
                                  http://2.bp.blogspot.com/_nswHPYi_dEw/SoWP9m4sr6I/AAAAAAAAH_4/BUtChw6LSK8/s400/P1000262.JPG
                                  Any way, just a thought! Thanks for creating so many awesome tools, it's inspiring. I'm slowly learning code, and it's great to see what you've written.
                                  Matt
                                    FWIW, you can already make vertically stacked text. It would be nice to be able to control things like leading and kerning, though.
                                      glro
                                      i downloaded and installed you plugin an TT_Lib_v2.8.3.rbz
                                      but then, when sketchup was launched, a message said i have to download TT_Lib2-2.8.0.rbz
                                      so i uninstalled TT_Lib_v2.8.3.rbz and installed TT_Lib2-2.8.0.rbz
                                      and then it worked
                                      you did a great job
                                      you managed to make a multilines editor...
                                      would it be possible to ...? 😛
                                      have the 3d text in a red/blue plan, instead of red/green?
                                      i would like to use your plugin to add comments to a scene, one comment per scene; usually, the camera is oriented so that vertical objects appear vertical
                                      So, it would be easier to read if the text was in the red/blue plan.
                                        glro
                                        and then it worked
                                        you did a great job
                                        no, i just realised that you can change the plan by writing on a face of the model; so to write vertically, you just have to find a vertical face in the model
                                        • tt_suT Offline
                                          tt_su
                                          Whaaat? 😕
                                          You shouldn't need to downgrade. Are you on Windows by any chance?
                                          Maybe you ended up with some files in VirtualStore...
                                          How did you install it?
                                            glro
                                            Whaaat? 😕
                                            windows 7 64 bits
                                            installed using preferences > extensions
                                            downloaded vers 2.8.3 here
                                            http://sketchucation.com/resources/pluginstore?pln=TT_Lib
                                            but it didn't work so i downloaded the previous version using the link that appeared on my screen
                                            but it's OK now;works great
                                            • 11
                                            • 5 / 11
