    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.3k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Ok Glenn, I found the issue. You simply have too many layers. It's related to the max length a url can pass between the dialog and SU. I forgot about this... I'll need to rewrite some code.
      • cmeedC Offline
        cmeed
        Thats it- it was an old layer. The reason i was changing it was to give it a capital letter, I started out with non-capitalised layer names......
        • cmeedC Offline
          cmeed
          does that mean theres a limit on layers?
          c
            jiminy-billy-bob
            For now, yes. I had this planned, but completely forgot about it. So I don't know the current limit. But in next version, it should be fixed.
            • gullfoG Offline
              gullfo
              no problem! that's what beta-testing is all about 😄
              Glenn
              http://www.runnel.com
              • gullfoG Offline
                gullfo
                that's the short list 😄 once you start to use ACAD standard architecture layer sets it gets "big"
                Glenn
                  jiminy-billy-bob
                  @bimbalas said:
                  On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. ąžįėš) this letters was changed to unicode codes.
                  I just tested, and it works for me when I rename a layer to "ąžįėš". Which versions of Sketchup, windows, and internet explorer are you using ?
                    jiminy-billy-bob
                    New version 0.3.2 beta !
                    Changelog :
                    • Fix bugsplat when deleteing/purging layers with Outliner opened
                    • New naming conventions (For the Extension Warehouse)
                    Download in the plugin store !
                    At startup, you should get once "Error Loading File layers_panel.rb no such file to load -- layers_panel.rb". This is normal, it's just the plugin deleting the old files.
                    • cmeedC Offline
                      cmeed
                      this is with release 0.3.2
                      same naming issue with names not changing in the LayersPanel - they are changing in the Layers Window though
                      I updated the plugin this morning. The layers were made yesterday. I closed down SU. restarted SU. captured film so its not happening with the layers or folders before the plugin was installed, as all were made yesterday
                      C
                      EDIT: in the time its taken me to write the above the layer has now changed to 'hello' in LayersPanel. just so you know...
                      • tt_suT Offline
                        tt_su
                        Doh! I was just about to look at this.
                        Can you PM me the old version that crashed? I'd like to have a look at it.
                        (Also, what did you do to avoid the crash?)
                        • tt_suT Offline
                          tt_su
                          Is it just the Win32 API dependency that makes this Windows only?
                          • tt_suT Offline
                            tt_su
                            And I just downloaded 0.32 from the Plugin Store but it alerts me about a new version...
                            • cmeedC Offline
                              cmeed
                              hello again,
                              Still can't update layer using a shortcut key with LayersPanel open.
                              works fine when i close LayersPanel.
                              c
                                jiminy-billy-bob
                                C
                                This is really weird. How about renaming a layer, then close the dialog and open it again ? Is the name updated ?
                                @cmeed said:
                                hello again,
                                c
                                Is the dialog focused when you're trying to do that ?
                                Has anyone else the same issue with shortcuts ? It works fine for me, when the dialog is not focused.
                                Nope. A lot of things need rewriting. Pumping, etc...
                                BTW, I think I read somewhere that you work on mac ? Would you be ok with helping me testing on osx ?
                                Yeah, sorry about that, it was a serverside issue. It should be fixed now.
                                • tt_suT Offline
                                  tt_su
                                  Regarding pumping messages, I have a system working quite well in SKUI. https://github.com/thomthom/SKUI
                                  I guess the bridge itself could be an interesting mini-framework to extract from that project. A Ruby class that subclass the UI::WebDialog class, cleaning up some of the cross compatibility issues on the Ruby side, then a JS script, or HTML builderplate that implement the communication with Ruby. That will enable JS to Ruby communication on OSX that doesn't drop messages - and Ruby and JS objects are converted seamlessly. You can even call JS functions from Ruby and get their return value.
                                    jiminy-billy-bob
                                    Whow, sounds great. I'll take a look at that when I have time. Thanks a lot
                                    • tt_suT Offline
                                      tt_su
                                      Do you use GitHub / BitBucket?
                                        jiminy-billy-bob
                                        Nope, but I guess I can start.
                                          jiminy-billy-bob
                                          @xkalvisx said:
                                          We would like to keep the size of the panel as it was before it was shut down.
                                          Sorry, but that's a limitation of the API. Sketchup saves the dialog's size/position between sessions, but not during a session... Dumb, I know, but there's not much I can do.
                                          Actually, there is a workaround. It's done and will be in next version. 😉
                                          (And I fixed the too-many-layers issue)
                                          • jgbJ Offline
                                            jgb
                                            JBB; Very nice job........ 👍 👍 👍
                                            The way SU does Layers have been a big bitch of mine since day 1. I use layers a lot as akin to a work breakdown structure. ALL of my layers are numbered with a name
                                            (ie: 01.00 Main Assembly) then major parts are sub tiered (nested) with the name indented
                                            (ie: 01.10______Sub Assy XX) and so on. (Note: Underscore here, spaces in SU)
                                            Because SU layers cannot indent/nest, this drives me into some weird naming conventions. And some models are long on layers, usually in the 50+ range.
                                            So when I saw you did indenting/nesting, I loaded the Ruby in a flash. I realize it is in an early developmental stage, so these are not critiques, but first use observations.
                                            I have used this Ruby for a total of 3 minutes prior to this note, so I am NOT familiar with all its' nuances.
                                            1) When I first loaded a model with 42 layers, SU's layers panel took about 3/4 screen height, and did not need a vertical scroll bar.
                                            Your panel was longer due to your using a higher row height, and it had a vertical scroll bar. That is not a problem.
                                            The problem was the vertical scroll bar does not work (greyed out), nor does mouse wheel scrolling, so I cannot see the last 7 layers in the list.
                                            2) Since ALL my layers are numbered, in SU they sort properly, either ascending or descending when I click on the header.
                                            They were in seemingly random order in your layer panel, neither numeric nor alphabetic. I had to move them into the numeric order I wanted.
                                            The layer sort order should initially match the SU Layer sort order.
                                            3) I simulate indenting/nesting by variable spacing the name of the layer after the number.
                                            You delete multiple spaces in the name.
                                            4) I noticed that to create a nest of layers, you have to define a new group, then move the layers to be nested under that new group, and rename the group layer.
                                            In my case, this creates a redundant top level layer, and since I have a bunch of components inside that layer, it can't be eliminated.
                                            You should consider the ability to elevate any existing layer to a group header status.
                                            5) I also noticed that when you create a new group, it cannot be renamed until some other layer is nested under it. And, if some other group or layer is highlighted, the new group is placed under it, not at the end of all the layers. Disconcerting if that highlighted group is collapsed. The new group effectively disappears.
                                            More later as I play with it more, but it is a very useful plug-in for me.
                                            jgb
                                            • 33
                                            • 34
                                            • 5 / 34
