    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.2k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @cmeed said:
      I didn't see but this isn't the fist time this has happened so will keep a better note next time.
      Ok, thanks.
      I think it's related to Observers watching layers change. I had these kind of issue in the past and resolved a lot of them, but it's possible that some remain. If it's indeed related to observers, it should occur only with old layers created before Layers Panel was installed.
      gullfo > I'll look at your file.
        jiminy-billy-bob
        Ok Glenn, I found the issue. You simply have too many layers. It's related to the max length a url can pass between the dialog and SU. I forgot about this... I'll need to rewrite some code.
        • cmeedC Offline
          cmeed
          Thats it- it was an old layer. The reason i was changing it was to give it a capital letter, I started out with non-capitalised layer names......
          • cmeedC Offline
            cmeed
            does that mean theres a limit on layers?
            c
              jiminy-billy-bob
              For now, yes. I had this planned, but completely forgot about it. So I don't know the current limit. But in next version, it should be fixed.
              • gullfoG Offline
                gullfo
                no problem! that's what beta-testing is all about 😄
                Glenn
                http://www.runnel.com
                • gullfoG Offline
                  gullfo
                  that's the short list 😄 once you start to use ACAD standard architecture layer sets it gets "big"
                  Glenn
                    jiminy-billy-bob
                    @bimbalas said:
                    On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. ąžįėš) this letters was changed to unicode codes.
                    I just tested, and it works for me when I rename a layer to "ąžįėš". Which versions of Sketchup, windows, and internet explorer are you using ?
                      jiminy-billy-bob
                      New version 0.3.2 beta !
                      Changelog :
                      • Fix bugsplat when deleteing/purging layers with Outliner opened
                      • New naming conventions (For the Extension Warehouse)
                      Download in the plugin store !
                      At startup, you should get once "Error Loading File layers_panel.rb no such file to load -- layers_panel.rb". This is normal, it's just the plugin deleting the old files.
                      • cmeedC Offline
                        cmeed
                        this is with release 0.3.2
                        same naming issue with names not changing in the LayersPanel - they are changing in the Layers Window though
                        I updated the plugin this morning. The layers were made yesterday. I closed down SU. restarted SU. captured film so its not happening with the layers or folders before the plugin was installed, as all were made yesterday
                        C
                        EDIT: in the time its taken me to write the above the layer has now changed to 'hello' in LayersPanel. just so you know...
                        • tt_suT Offline
                          tt_su
                          Doh! I was just about to look at this.
                          Can you PM me the old version that crashed? I'd like to have a look at it.
                          (Also, what did you do to avoid the crash?)
                          • tt_suT Offline
                            tt_su
                            Is it just the Win32 API dependency that makes this Windows only?
                            • tt_suT Offline
                              tt_su
                              And I just downloaded 0.32 from the Plugin Store but it alerts me about a new version...
                              • cmeedC Offline
                                cmeed
                                hello again,
                                Still can't update layer using a shortcut key with LayersPanel open.
                                works fine when i close LayersPanel.
                                c
                                  jiminy-billy-bob
                                  C
                                  This is really weird. How about renaming a layer, then close the dialog and open it again ? Is the name updated ?
                                  @cmeed said:
                                  hello again,
                                  c
                                  Is the dialog focused when you're trying to do that ?
                                  Has anyone else the same issue with shortcuts ? It works fine for me, when the dialog is not focused.
                                  Nope. A lot of things need rewriting. Pumping, etc...
                                  BTW, I think I read somewhere that you work on mac ? Would you be ok with helping me testing on osx ?
                                  Yeah, sorry about that, it was a serverside issue. It should be fixed now.
                                  • tt_suT Offline
                                    tt_su
                                    Regarding pumping messages, I have a system working quite well in SKUI. https://github.com/thomthom/SKUI
                                    I guess the bridge itself could be an interesting mini-framework to extract from that project. A Ruby class that subclass the UI::WebDialog class, cleaning up some of the cross compatibility issues on the Ruby side, then a JS script, or HTML builderplate that implement the communication with Ruby. That will enable JS to Ruby communication on OSX that doesn't drop messages - and Ruby and JS objects are converted seamlessly. You can even call JS functions from Ruby and get their return value.
                                      jiminy-billy-bob
                                      Whow, sounds great. I'll take a look at that when I have time. Thanks a lot
                                      • tt_suT Offline
                                        tt_su
                                        Do you use GitHub / BitBucket?
                                          jiminy-billy-bob
                                          Nope, but I guess I can start.
                                            jiminy-billy-bob
                                            @xkalvisx said:
                                            We would like to keep the size of the panel as it was before it was shut down.
                                            Sorry, but that's a limitation of the API. Sketchup saves the dialog's size/position between sessions, but not during a session... Dumb, I know, but there's not much I can do.
                                            Actually, there is a workaround. It's done and will be in next version. 😉
                                            (And I fixed the too-many-layers issue)
                                            • 33
                                            • 34
                                            • 5 / 34
