    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.2k Views 110 Watching
    • cmeedC Offline
      cmeed
      I didn't see but this isn't the fist time this has happened so will keep a better note next time.
      • gullfoG Offline
        gullfo
        i've found an issue? i added layers after placing a bunch into groups and when i drag the unassigned layer into a group i get a javascript error. attached is the file and the screenshot. i'm using SU 2013 pro 13.0.4812 on Windows Vista SP2. i have full permission in SU prog dir.
        screenshot of error
        sketchup file
        Glenn
        http://www.runnel.com
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          Ok, thanks.
          I think it's related to Observers watching layers change. I had these kind of issue in the past and resolved a lot of them, but it's possible that some remain. If it's indeed related to observers, it should occur only with old layers created before Layers Panel was installed.
          gullfo > I'll look at your file.
            jiminy-billy-bob
            Ok Glenn, I found the issue. You simply have too many layers. It's related to the max length a url can pass between the dialog and SU. I forgot about this... I'll need to rewrite some code.
            • cmeedC Offline
              cmeed
              Thats it- it was an old layer. The reason i was changing it was to give it a capital letter, I started out with non-capitalised layer names......
              • cmeedC Offline
                cmeed
                does that mean theres a limit on layers?
                c
                  jiminy-billy-bob
                  For now, yes. I had this planned, but completely forgot about it. So I don't know the current limit. But in next version, it should be fixed.
                  • gullfoG Offline
                    gullfo
                    no problem! that's what beta-testing is all about 😄
                    Glenn
                    • gullfoG Offline
                      gullfo
                      that's the short list 😄 once you start to use ACAD standard architecture layer sets it gets "big"
                      Glenn
                        jiminy-billy-bob
                        @bimbalas said:
                        On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. ąžįėš) this letters was changed to unicode codes.
                        I just tested, and it works for me when I rename a layer to "ąžįėš". Which versions of Sketchup, windows, and internet explorer are you using ?
                          jiminy-billy-bob
                          New version 0.3.2 beta !
                          Changelog :
                          • Fix bugsplat when deleteing/purging layers with Outliner opened
                          • New naming conventions (For the Extension Warehouse)
                          Download in the plugin store !
                          At startup, you should get once "Error Loading File layers_panel.rb no such file to load -- layers_panel.rb". This is normal, it's just the plugin deleting the old files.
                          • cmeedC Offline
                            cmeed
                            this is with release 0.3.2
                            same naming issue with names not changing in the LayersPanel - they are changing in the Layers Window though
                            I updated the plugin this morning. The layers were made yesterday. I closed down SU. restarted SU. captured film so its not happening with the layers or folders before the plugin was installed, as all were made yesterday
                            C
                            EDIT: in the time its taken me to write the above the layer has now changed to 'hello' in LayersPanel. just so you know...
                            • tt_suT Offline
                              tt_su
                              Doh! I was just about to look at this.
                              Can you PM me the old version that crashed? I'd like to have a look at it.
                              (Also, what did you do to avoid the crash?)
                              • tt_suT Offline
                                tt_su
                                Is it just the Win32 API dependency that makes this Windows only?
                                • tt_suT Offline
                                  tt_su
                                  And I just downloaded 0.32 from the Plugin Store but it alerts me about a new version...
                                  • cmeedC Offline
                                    cmeed
                                    hello again,
                                    Still can't update layer using a shortcut key with LayersPanel open.
                                    works fine when i close LayersPanel.
                                    c
                                      jiminy-billy-bob
                                      C
                                      This is really weird. How about renaming a layer, then close the dialog and open it again ? Is the name updated ?
                                      @cmeed said:
                                      hello again,
                                      c
                                      Is the dialog focused when you're trying to do that ?
                                      Has anyone else the same issue with shortcuts ? It works fine for me, when the dialog is not focused.
                                      Nope. A lot of things need rewriting. Pumping, etc...
                                      BTW, I think I read somewhere that you work on mac ? Would you be ok with helping me testing on osx ?
                                      Yeah, sorry about that, it was a serverside issue. It should be fixed now.
                                      • tt_suT Offline
                                        tt_su
                                        Regarding pumping messages, I have a system working quite well in SKUI. https://github.com/thomthom/SKUI
                                        I guess the bridge itself could be an interesting mini-framework to extract from that project. A Ruby class that subclass the UI::WebDialog class, cleaning up some of the cross compatibility issues on the Ruby side, then a JS script, or HTML builderplate that implement the communication with Ruby. That will enable JS to Ruby communication on OSX that doesn't drop messages - and Ruby and JS objects are converted seamlessly. You can even call JS functions from Ruby and get their return value.
                                          jiminy-billy-bob
                                          Whow, sounds great. I'll take a look at that when I have time. Thanks a lot
                                          • tt_suT Offline
                                            tt_su
                                            Do you use GitHub / BitBucket?
                                            • 33
                                            • 34
                                            • 5 / 34
