    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.5k Views 109 Watching
    • gullfoG Offline
      gullfo
      i've found an issue? i added layers after placing a bunch into groups and when i drag the unassigned layer into a group i get a javascript error. attached is the file and the screenshot. i'm using SU 2013 pro 13.0.4812 on Windows Vista SP2. i have full permission in SU prog dir.
      screenshot of error
      sketchup file
      Glenn
      http://www.runnel.com
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        @cmeed said:
        I didn't see but this isn't the fist time this has happened so will keep a better note next time.
        Ok, thanks.
        I think it's related to Observers watching layers change. I had these kind of issue in the past and resolved a lot of them, but it's possible that some remain. If it's indeed related to observers, it should occur only with old layers created before Layers Panel was installed.
        gullfo > I'll look at your file.
          jiminy-billy-bob
          Ok Glenn, I found the issue. You simply have too many layers. It's related to the max length a url can pass between the dialog and SU. I forgot about this... I'll need to rewrite some code.
          • cmeedC Offline
            cmeed
            Thats it- it was an old layer. The reason i was changing it was to give it a capital letter, I started out with non-capitalised layer names......
            • cmeedC Offline
              cmeed
              does that mean theres a limit on layers?
              c
                jiminy-billy-bob
                For now, yes. I had this planned, but completely forgot about it. So I don't know the current limit. But in next version, it should be fixed.
                • gullfoG Offline
                  gullfo
                  no problem! that's what beta-testing is all about πŸ˜„
                  Glenn
                  • gullfoG Offline
                    gullfo
                    that's the short list πŸ˜„ once you start to use ACAD standard architecture layer sets it gets "big"
                    Glenn
                      jiminy-billy-bob
                      @bimbalas said:
                      On renamaming layers or groups directly on Layers Panel with letters from non ASCII character set (e.g. Δ…ΕΎΔ―Δ—Ε‘) this letters was changed to unicode codes.
                      I just tested, and it works for me when I rename a layer to "Δ…ΕΎΔ―Δ—Ε‘". Which versions of Sketchup, windows, and internet explorer are you using ?
                        jiminy-billy-bob
                        New version 0.3.2 beta !
                        Changelog :
                        • Fix bugsplat when deleteing/purging layers with Outliner opened
                        • New naming conventions (For the Extension Warehouse)
                        Download in the plugin store !
                        At startup, you should get once "Error Loading File layers_panel.rb no such file to load -- layers_panel.rb". This is normal, it's just the plugin deleting the old files.
                        • cmeedC Offline
                          cmeed
                          this is with release 0.3.2
                          same naming issue with names not changing in the LayersPanel - they are changing in the Layers Window though
                          I updated the plugin this morning. The layers were made yesterday. I closed down SU. restarted SU. captured film so its not happening with the layers or folders before the plugin was installed, as all were made yesterday
                          C
                          EDIT: in the time its taken me to write the above the layer has now changed to 'hello' in LayersPanel. just so you know...
                          • tt_suT Offline
                            tt_su
                            Doh! I was just about to look at this.
                            Can you PM me the old version that crashed? I'd like to have a look at it.
                            (Also, what did you do to avoid the crash?)
                            • tt_suT Offline
                              tt_su
                              Is it just the Win32 API dependency that makes this Windows only?
                              • tt_suT Offline
                                tt_su
                                And I just downloaded 0.32 from the Plugin Store but it alerts me about a new version...
                                • cmeedC Offline
                                  cmeed
                                  hello again,
                                  Still can't update layer using a shortcut key with LayersPanel open.
                                  works fine when i close LayersPanel.
                                  c
                                    jiminy-billy-bob
                                    C
                                    This is really weird. How about renaming a layer, then close the dialog and open it again ? Is the name updated ?
                                    @cmeed said:
                                    hello again,
                                    c
                                    Is the dialog focused when you're trying to do that ?
                                    Has anyone else the same issue with shortcuts ? It works fine for me, when the dialog is not focused.
                                    Nope. A lot of things need rewriting. Pumping, etc...
                                    BTW, I think I read somewhere that you work on mac ? Would you be ok with helping me testing on osx ?
                                    Yeah, sorry about that, it was a serverside issue. It should be fixed now.
                                    • tt_suT Offline
                                      tt_su
                                      Regarding pumping messages, I have a system working quite well in SKUI. https://github.com/thomthom/SKUI
                                      I guess the bridge itself could be an interesting mini-framework to extract from that project. A Ruby class that subclass the UI::WebDialog class, cleaning up some of the cross compatibility issues on the Ruby side, then a JS script, or HTML builderplate that implement the communication with Ruby. That will enable JS to Ruby communication on OSX that doesn't drop messages - and Ruby and JS objects are converted seamlessly. You can even call JS functions from Ruby and get their return value.
                                        jiminy-billy-bob
                                        Whow, sounds great. I'll take a look at that when I have time. Thanks a lot
                                        • tt_suT Offline
                                          tt_su
                                          Do you use GitHub / BitBucket?
                                            jiminy-billy-bob
                                            Nope, but I guess I can start.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
