    [Plugin] UVTools v0.1
    180 Posts 71 Posters 128.3k Views 71 Watching
      pdwyer
      Does this still work with SU8 on windows?
      The plugin doesn't start, no menu is created. 😞
        It works perfectly you must have installed it incorrectly.
        I use it everyday on v7, v7.1 and v8
        • massimoM Offline
          massimo Moderator
          Hi pdwyer, I don't have SU 8 so I cannot test it. Anyway the plugin only appears in the context menu so right click on a texture-->UV tools.
            pdwyer
            Ignore me, it is working, just not the UI I was expecting πŸ˜„
            all good
              burningman
              I'm using Sk 8-0-11751 on a mac book pro. Can you point me to the download for the uv tools plugin? Thanks so much.
                It's attached to the first post with a
                http://forums.sketchucation.com/images/upload_icons/ruby.gif
                icon.
                Generally this is the way authors publish and keep their plugins updated here so always look in the first post.
                  burningman
                  BIGthanks mate!
                  • E Offline
                    Eric5150
                    I have a problem using UVTools. I am new to UV texturing. My current project is a sketchup version of Spaceship Earth from EPCOT. The link to the sketchup file is below. I need to know how to get the texture located in front of the sphere to wrap around the sphere.
                    Please give me a tutorial as I would like to know how to do this in the future. Any help would be appreciated as I tried looking through this post but Sketchup kept crashing everytime I tried to do it.
                    Eric
                    http://www.ejlmusic.com/sketchup/Spaceship Earth Final 12C.skp
                    Thanks in advance
                    (would love a youtube video tutorial if anyone has time...it would help us noobs out immensely)
                      jumpjack
                      I don't understand how to use the plugin.
                      I installed it,I get the new context menu.
                      I create a cylynder/sphere, then... what? I create a wall close to it, apply a texture to the wall and use the UV right menu on it?
                      Nothing happens.
                      • FrederikF Offline
                        Frederik
                        Why would you install a plugin if you don't know what it is...?
                        Take a look at some of the posts on page 1 and 2... There's a good tutorial by Alan Fraser...
                        Try applying a bitmap texture to a sphere or a cylinder...
                        It's important that it's not just a color but a bitmap texture...
                        You'll see that the texture looks odd on such shapes...
                        Now click the sphere to select it...
                        Right-click it an from the submenu select UV tools and then select i.e. spherical...
                        You'll see that the texture looks correct now...
                        Cheers
                        Kim Frederik
                          demigamer
                          Thanks A lot !
                          Downloading. . . . πŸ˜‰
                          • HornOxxH Offline
                            HornOxx
                            Hi All,
                            Since I use Artisan, I have the need to improve my uv-texturing skills ❗
                            I want to use the UV-Tools plugin but I donΒ΄t get it to run on SketchUp 2013 - IΒ΄m certainly
                            doing anything wrong. The only footprint is the "UVtools.rb"-file (?) but inside SketchUp
                            I dontΒ΄t get any icons or any context menu
                            I appreciate any help
                            never trust a skinny cook
                            • N Offline
                              numerobis
                              you could try ThruPaint
                              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
                              or SketchUV
                              http://extensions.sketchup.com/en/content/sketchuv
                                thegoodguy
                                Thanks for this awesome plugin Whaat!
                                • N Offline
                                  nlipovac
                                  I use SketchUV and Roadkill, and it works great. πŸ˜„
                                  WrapR is in development and it will make unwraping inside SU.
                                  • 5 / 9
