    [Plugin] Geodesic Dome Creator 0.2.0
    15 Posts 12 Posters 22.2k Views 12 Watching
    • s_k_e_t_c_h_yS Offline
      s_k_e_t_c_h_y
      Just finished an update and thought I'd share
      https://sites.google.com/site/sugeodesic/home
      New Features
      • Spherical Hubs
      • Cylindrical Struts Point option for Hub Centers (Platonic solid vertices)
      • Improved Menu System
      • Material Selector for faces, struts and hubs (requires SKMTools)
      Fixes
      • Tetrahedron fix (Issue ๐Ÿ˜Ž
      • Duplicate Hub/Struts (Issue 1)
      • Resulted in approximately 6.5% speed improvement of generation time
      • Fraction option now works (Issue 9)
      Improvements
      • Sphere hubs are now components (still need to do cylindrical hubs)
      I tested it on older versions of SketchUp, but I'm still curious to see how the new menu system works for people that use older setups.
      Regards, Sketchy...
      • Rich O BrienR Online
        Nice if you share it on the PluginStore too....
        • GubermenschG Offline
          Gubermensch
          Thanks again. The vertices display alone makes this plugin awesome. I was pulling my hair out a few months ago trying to model what you've enabled in a plugin.
          I'm sure you know, but the 'strut' radius option doesn't work. It'd be nice to see the settings previously input within the menu upon returning, not sure if this is doable.
          Just starting some test renders now of my geodesic's interior!
          http://i.imgur.com/cc1UiRe.jpg
          http://i.imgur.com/eKaknTd.jpg
          http://i.imgur.com/8UDYhTD.jpg
          http://i.imgur.com/q08ZsGt.jpg
          http://www.jacobgubler.com/
            kelisiqing
            It semms like a great tool
              davidtsang348
              Thx for sharing & it is quite crucial for me!
                Jehornilla
                Help. Pressing generate doesn't do anything. I tried using sketchup 2013 pro, 2014 pro, and 2015 pro. Still doesn't work. Please help. Thank you.
                  Jehornilla
                  Pressing generate doesn't do anything. I tried using sketchup 2013 pro, 2014, and 2015 pro, no luck. Please help. ๐Ÿ˜ž Much appreciated.
                    The plugin's home page https://sites.google.com/site/sugeodesic/download
                    says it's been tested for v2015 compatibility.
                    Have you installed the latest version ?
                    I did [in v2015] and tested it...
                    It has a number of issues.
                    It must be installed in the default Plugins folder - it uses Sketchup.find_support_file... inappropriately and prevents a custom install...
                    It also requires [my] SKMtools to be installed, if you are adding materials to the geometry...
                    But it doesn't work even if it is there !
                    With the Ruby Console open it says it's doing things but makes nothing !
                    Stops at ' platonic handler... about to send' ??
                    On looking into the coding...
                    It has unbelievably convoluted Ruby and HTML/JS callbacks, and although I neither have the time or will to debug it properly I can see it has some errors in the call_ruby("create_geodesic", 1); calls in the JS etc.
                    I have managed to hack the code to force it to 'draw' something, but this is silly...
                    Many pieces are made 'inside-out', some are not made and the Materials are all 'black' and corrupted/un-editable [screenshot is with all 3 materials deleted!]... ๐Ÿ˜’
                    Can I suggest you pester the author directly through his web-site...
                    It ought to work a lot easier than it does right now...
                    It has a lot of potential...
                    ๐Ÿ˜•
                      Jehornilla
                      It doesn't even work at all. Press generate, nothing happens. It's a bit frustrating. I'll try contacting the author. Thank you for the reply.
                        Look at this guy TaffGoch ๐Ÿ˜‰
                          christ0s
                          I just run the plugin in SU 2014 and works good
                            dacsol
                            where can i download? its not available ๐Ÿ˜ž i also tried with wayback mashine but didnt work ๐Ÿ˜ž can you send it to my email?
                              The author hasn't logged into Sketchucation since 2016. I expect they haven't updated their plugin to work with newer versions of SketchUp. You'd probably be time and effort ahead to use an alternative.
                              Speaking of versions, what version of SketchUp are you using. You put 2018 Free/Make in your forum profile but there is no such version.
                              • Gus RG Offline
                                Gus R
                                You can still get it from the Wayback Machine (archive) at this link.
                                Whether or not he still wants it shared is unknown to me. I just tested it on SU 2022 Pro and it works.
                                www.instagram.com/gusrobatto/
                                www.facebook.com/gusrobatto
                                • Gus RG Offline
                                  Gus R
                                  Getting it to make faces for the glass may prove difficult. You can try it if you're using an older version of Sketchup since the SKM plugin is 13 years old. Didn't work for me. You can get that here: click on Tรฉlรฉchargement.
