    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      @kashkasha said:
      @mdm said:
      man this plugin is awesome 😍 πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰
      for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🀣 will be available
      great stuff I love it, and it's so much fun πŸ˜„
      where can i download it also? its seems everyone is "make-furing" except me... πŸ˜•
      Go to the start of the tools thread OR... please learn to use the SCF PluginStore... which can be accessed from the Resources menu above... πŸ˜’
        tak2hata
        Hi,Walt.
        I create the test_dialog.html
        test_dialog.html.zip
        please copy this file to fur_en folder.
        test_dialog copy to there
        And open the html file on browser.
        I will modify fur_en to create html file if the html file show sliders
        Hi,Davor.
        Nicely rendered image! 😍
        Architecture need the beautiful grass like this.
        Hi,kashkasha.
        Please get install files on the top of this thread.
        And Enjoy fur_en!
        Hi,TIG.
        Thank you very much for your advice.
        Thanks All.
        by TAK2HATA
          leaosenzala
          @thkian92 said:
          Thanks for the plugin! But I have a problem. It seems that I can't get v2.0.6 to work on the new Sketchup 2013. Am i doing something wrong? As usual I've placed the plugin in C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins.
          what i did was change the extension rbz to zip then extract to plugin folder
            Are they really in the folder?
            Do you have full security access rights to your Plugins folder?
            Were all files left in the same relationship [subfolders etc] as in the RBZ [ZIP]?
            Because you didn't bother to complete your User-Info we don't know your OS [although we can guess 64bit PC] or your SUp Version.
            If you have SUp v8 or v2013 you could far more easily install RBZ files etc in several ways... avoiding any of the complications you outlined...
            This kind of issue has been discussed many times, in many threads...
              ChEBaNaNa
              This Plugin is probably the best Plugin i've ever seen....
              Big Thanks from Switzerland!!!!! πŸ˜ƒ
              • plot-parisP Offline
                plot-paris
                Hey tak2hata,
                excellent plugin! It is fun to use and a great enhancement for SketchUp.
                However, sometimes I find it a bit difficult to master. Therefore I have two ideas:
                1. Some of the settings use units that are not very intuitive. The stiffness for example is measured in a undefined number. Or while the jitter options use percent, the direction and force options use meters (which can be difficult, so that one has to test a lot before achieving the right result).
                  I think it might be better to have those as a percentage as well (0% no effect, 100% full effect). Like that one can see a linear increase of the effect, which makes it easier to understand.
                2. Some of the settings are not self-explanatory. Do you think it would be possible to add tooltips that show up, when you hover over the setting with your cursor for some time? You know, with a short description of what the setting does...
                Would be great to hear your opinion on this...
                  bb6
                  谒谒!hebeijianke
                    Sharkyzero
                    I don't seem to be getting the results everybody else is. I make a grass square and make it a component, then I try to use the crowd maker and it puts the grass everywhere else other than what I have selected. Anybody else have this problem? Also, how do you get so much grass? My comp is no slouch and it virtually crashes whenever I try to get more than a little bit in view.
                      tak2hata
                      Hi,Sharkyzero.
                      I need to know your detail to help the problems.
                      Please upload screenshot of your model and crownd maker dialog.
                      crowdmaker
                      Thanks.
                      by TAK2HATA
                        Sharkyzero
                        I just realized something, Tak. I think the fact that I'm not using instances of the grass components is screwing with everything. Let me fiddle around with it some more and I'll see if I can't get it working the way I think it should.
                          tak2hata
                          Hi,Sharkyzero.
                          Good luck for fiddle around with it.
                          Please ask me when you didn't get it working fine.
                          Thanks.
                          by TAK2HATA
                            chillotti
                            Hi everybody, I have a problem, I can’t install the plugin Fur Maker, I put the file http://sketchucation.com/resources/pluginstore?pln=fur_en
                            And also the new icons
                            http://sketchucation.com/forums/viewtopic.php?f=323&t=28092&start=480
                            in the
                            Can you help me? Please
                            Carlo
                              tak2hata
                              in the
                              Carlo
                              Hi,chillotti.
                              I guess you didn't use autoinstall from sketchupucation store tool.
                              You must unzip the rbz file when you manually install it.
                              Change the extenstion name "rbz" to "zip".and unzip it.
                              "fur_en.rb" and "fur_en" folder will be shown.
                              Copy both to plugin folder.
                              And New Icon file "fur_en.rar" must unzip ,also.
                              Copy the created png file to "fur_en" folder in plugins folder.
                              Thanks.
                              by TAK2HATA
                                SuperJesus
                                This was working previously for me but there are certain components that dont seem to want to constrain the surface I select. The preview shows everything in the right place but then they appear randomly spread out in mid air over a huge area when I do it. Its only certain components with the same settings so I don't get it. Has anybody had this issue before?
                                  tak2hata
                                  Hi,SuperJesus.
                                  I guess your problem of fur.
                                  watch video
                                  Please Check the axis origin of the component.
                                  Thanks.
                                  by TAK2HATA
                                  • bulbaB Offline
                                    bulba
                                    thanks tak2hata..
                                    this plugin is very useful
                                    • Y Offline
                                      Yoshi Ikeda
                                      Hy,
                                      The fur plug in work for sketch up 8 Pro BUT it doesnot work in sketch up 2013 Pro,
                                      Any advice?
                                      Regards,
                                      Yoshi Ikeda
                                        It should work.
                                        What is the problem ?
                                        We need help here πŸ˜•
                                        How can we help you, if you don't try to help us πŸ˜’
                                          mjursevs
                                          Hi, wondering if someone could please help me.
                                          I've been using make fur fine for the last while, but it has suddenly stopped working completely.
                                          I know how to use it, but now when I push the Make Fur button, nothing happens. No collecting faces, nothing. I'm at a loss. Has anyone ever experienced something like this?
                                          Any insights would be greatly appreciated.
                                            Have you recently installed any new plugins that might be messing with this one? Maybe the Vray plugin or Sketchy Physics?
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 31 / 33
