    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 182.8k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      In my stats, I see some users on Mac OSX using Layers Panel several days in a row. So I'm guessing it's kind of working on OSX. Can someone tell me exactly what's working and what's not ? Thanks 😄
        glro
        @utiler said:
        Hey JBB, one question before I try it out: when you add a layer is that layers' visibility only visible in the current scene? If not can it be???? So tedious when adding a layer to then have to go through all other scenes to turn it off it you only want
        it visible in one scene.
        Vismap does what you are asking for
        http://sketchucation.com/forums/viewtopic.php?t=23029
        • EdsonE Offline
          Edson
          this looks to be a great plugin. I would not want to miss out on it! however, I am a mac user. 😞 any chance of it working on mac os in the near future? 😄
          http://www.mahfuz.arq.br
            jiminy-billy-bob
            There are chances, but it'll need a fair amount of modification, because OSX doesn't handle webdialog the same as Windows (a lot more complicated, actually). Plus, I don't have a mac myself, so debug won't be easy.
            • EdsonE Offline
              Edson
              I hope you do it. why not ask for help from the other authors on this forum? they have been able to port their plugins to mac os.
                jiminy-billy-bob
                I will, but first I'm learning what are the differences between windows and mac.
                  db11
                  Looking forward to a functioning Mac version!
                  A question / suggestion:
                  Any chance that your plugin will work with the TIG's Layer Name Export/Import plug-in in a way that will preserve/establish the layer hierarchy?
                  I would love to have standardized, predefined layer outline sets — depending on the type of model being built: i.e. furniture, cabinetry, architectural, product design — that could be loaded from a .layers file on starting a new model. I do that now, but being able to import an outlined layer structure would be killer!
                    jiminy-billy-bob
                    I'll look into that. In the meantime, you can use templates. They should keep the nested/sorted structure.
                      db11
                      Cool.
                      Given that you report some people apparently using the beta on their macs, maybe I will try it out as-is to help with user testing. Don't have the knowledge to help on the Ruby front, but can at least add my voice through bug reporting (assuming that the current beta works at all on my mac).
                      I'm running SU8 on OSX 10.6.8 (Snow Leopard)... will let you know how it goes.
                        jiminy-billy-bob
                        Great, thanks ! 😄
                          db11
                          OK, after about an hour of playing (and 1 bug splat) around here's what I found on my mac:
                          What works:
                          • installation
                          • toolbar
                          • web dialogue (layers panel window)
                          • add layer
                          • add group
                          • name/rename group/layer
                          • nest / move
                          • import layers through TIGs plugin - fills layer panel
                          • layer visibility toggle
                          Doesn't work:
                          • group visibility (no effect at all)
                          • delete layer (no effect at all)
                          • delete group (deletes group and nested layers from panel, but not Layers window)
                          • purge unused layers
                          Big Problems:
                          • existing layers don't automatically fill layer panel
                          • on save and close / reopen, layer panel loses all layers
                          • on switching focus to a second model window, the layer panel loses all layers
                            ( probably related to the fact that Mac OS allows multiple windows in a single application instance whereas Windows allows only one window per application instance (therefore multiple model windows = multiple SU instances) IIANM.
                          Hope this helps. This is going to be an awesome plugin once it's debugged!
                            jiminy-billy-bob
                            Thanks a lot ! That's very usefull 😄
                            • ToboboT Offline
                              Tobobo
                              This looks like a giant leap forward. Well done 👍
                              I use a lot of models from other people and CAD drawings, this will be great to keep the model organised.
                              Toby
                              Philippians 4:13
                                jiminy-billy-bob
                                New version 0.3 beta !
                                Changelog :
                                • Locking layers (Works only when purging or deleting from the plugin's menu)
                                • Ability to add a layer only visible in the current scene (New pop-up menu when holding the "Add layer" button)
                                • Layers Panel is now a toolwindow, but you can't dock nor collapse it
                                • Two different delete buttons, for better performance (The red cross deletes the layer content, the green arrow moves the content to the default layer)
                                • Several bug fix
                                http://i.imgur.com/5ly9dzl.png
                                Download in the plugin store !
                                • utilerU Offline
                                  utiler
                                  Gee, you do work fast and listen to request, JBB!!!!!!
                                  Have you ever been to Boulder; I hear they're hiring...... 👍
                                  Just Curious...
                                  • bagateloB Offline
                                    bagatelo
                                    Someone already ask for freeze layers content?
                                      jiminy-billy-bob
                                      I'm not sure I could do that. 😕
                                      • I Offline
                                        ivreich
                                        OMGOMGOMGOMGOMGOMG
                                        Layer groups!!! FINALLY. THANK YOU...You are a godsend!
                                        Now if only we can get Trimble to pay you royalties to include this in the next basebuild of SU...It's something they should have had since the very beginning
                                        Well done.
                                        Joel
                                        • cmeedC Offline
                                          cmeed
                                          this looks like a really good addition to sketchup.
                                          but - existing layers don't show up. downloaded plugin mid project.
                                          using latest sketchup and latest version of Layers panel. Windows.
                                          cheers
                                          c
                                          EDIT: I'm not sure what happened but the layers have now appeared - it could have coincided with me importing an image but not sure
                                          • X Offline
                                            xkalvisx
                                            Does not save group names
                                            opening the panel, the group names reappear (Group1, group2, etc.).
                                            More ...
                                            We would like to keep the size of the panel as it was before it was shut down.
                                            Great thanks.
                                            https://www.dropbox.com/s/mw0340kn4nvquja/1.jpg
                                            Dropbox - Error - Simplify your life
                                            (www.dropbox.com)
                                            Before it was listed all the names of the groups.
                                            Thanks.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 30 / 34
