    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.2k Views 110 Watching
      glro
      @utiler said:
      Hey JBB, one question before I try it out: when you add a layer is that layers' visibility only visible in the current scene? If not can it be???? So tedious when adding a layer to then have to go through all other scenes to turn it off it you only want
      it visible in one scene.
      Vismap does what you are asking for
      404 Not Found
      (sketchucation.com)
      • EdsonE Offline
        Edson
        this looks to be a great plugin. I would not want to miss out on it! however, I am a mac user. 😞 any chance of it working on mac os in the near future? 😄
        http://www.mahfuz.arq.br
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          There are chances, but it'll need a fair amount of modification, because OSX doesn't handle webdialog the same as Windows (a lot more complicated, actually). Plus, I don't have a mac myself, so debug won't be easy.
          • EdsonE Offline
            Edson
            I hope you do it. why not ask for help from the other authors on this forum? they have been able to port their plugins to mac os.
              jiminy-billy-bob
              I will, but first I'm learning what are the differences between windows and mac.
                db11
                Looking forward to a functioning Mac version!
                A question / suggestion:
                Any chance that your plugin will work with the TIG's Layer Name Export/Import plug-in in a way that will preserve/establish the layer hierarchy?
                I would love to have standardized, predefined layer outline sets — depending on the type of model being built: i.e. furniture, cabinetry, architectural, product design — that could be loaded from a .layers file on starting a new model. I do that now, but being able to import an outlined layer structure would be killer!
                  jiminy-billy-bob
                  I'll look into that. In the meantime, you can use templates. They should keep the nested/sorted structure.
                    db11
                    Cool.
                    Given that you report some people apparently using the beta on their macs, maybe I will try it out as-is to help with user testing. Don't have the knowledge to help on the Ruby front, but can at least add my voice through bug reporting (assuming that the current beta works at all on my mac).
                    I'm running SU8 on OSX 10.6.8 (Snow Leopard)... will let you know how it goes.
                      jiminy-billy-bob
                      Great, thanks ! 😄
                        db11
                        OK, after about an hour of playing (and 1 bug splat) around here's what I found on my mac:
                        What works:
                        • installation
                        • toolbar
                        • web dialogue (layers panel window)
                        • add layer
                        • add group
                        • name/rename group/layer
                        • nest / move
                        • import layers through TIGs plugin - fills layer panel
                        • layer visibility toggle
                        Doesn't work:
                        • group visibility (no effect at all)
                        • delete layer (no effect at all)
                        • delete group (deletes group and nested layers from panel, but not Layers window)
                        • purge unused layers
                        Big Problems:
                        • existing layers don't automatically fill layer panel
                        • on save and close / reopen, layer panel loses all layers
                        • on switching focus to a second model window, the layer panel loses all layers
                          ( probably related to the fact that Mac OS allows multiple windows in a single application instance whereas Windows allows only one window per application instance (therefore multiple model windows = multiple SU instances) IIANM.
                        Hope this helps. This is going to be an awesome plugin once it's debugged!
                          jiminy-billy-bob
                          Thanks a lot ! That's very usefull 😄
                          • ToboboT Offline
                            Tobobo
                            This looks like a giant leap forward. Well done 👍
                            I use a lot of models from other people and CAD drawings, this will be great to keep the model organised.
                            Toby
                            Philippians 4:13
                              jiminy-billy-bob
                              New version 0.3 beta !
                              Changelog :
                              • Locking layers (Works only when purging or deleting from the plugin's menu)
                              • Ability to add a layer only visible in the current scene (New pop-up menu when holding the "Add layer" button)
                              • Layers Panel is now a toolwindow, but you can't dock nor collapse it
                              • Two different delete buttons, for better performance (The red cross deletes the layer content, the green arrow moves the content to the default layer)
                              • Several bug fix
                              http://i.imgur.com/5ly9dzl.png
                              Download in the plugin store !
                              • utilerU Offline
                                utiler
                                Gee, you do work fast and listen to request, JBB!!!!!!
                                Have you ever been to Boulder; I hear they're hiring...... 👍
                                Just Curious...
                                • bagateloB Offline
                                  bagatelo
                                  Someone already ask for freeze layers content?
                                    jiminy-billy-bob
                                    I'm not sure I could do that. 😕
                                    • I Offline
                                      ivreich
                                      OMGOMGOMGOMGOMGOMG
                                      Layer groups!!! FINALLY. THANK YOU...You are a godsend!
                                      Now if only we can get Trimble to pay you royalties to include this in the next basebuild of SU...It's something they should have had since the very beginning
                                      Well done.
                                      Joel
                                      • cmeedC Offline
                                        cmeed
                                        this looks like a really good addition to sketchup.
                                        but - existing layers don't show up. downloaded plugin mid project.
                                        using latest sketchup and latest version of Layers panel. Windows.
                                        cheers
                                        c
                                        EDIT: I'm not sure what happened but the layers have now appeared - it could have coincided with me importing an image but not sure
                                        • X Offline
                                          xkalvisx
                                          Does not save group names
                                          opening the panel, the group names reappear (Group1, group2, etc.).
                                          More ...
                                          We would like to keep the size of the panel as it was before it was shut down.
                                          Great thanks.
                                          https://www.dropbox.com/s/mw0340kn4nvquja/1.jpg
                                          Before it was listed all the names of the groups.
                                          Thanks.
                                          • bagateloB Offline
                                            bagatelo
                                            Maybe you can add this function?
                                            http://sketchucation.com/forums/viewtopic.php?f=323&t=54108&p=490389#p490389
                                            • 33
                                            • 34
                                            • 2 / 34
