    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 227.1k Views 109 Watching
    • utilerU Offline
      utiler
      Gee, you do work fast and listen to request, JBB!!!!!!
      Have you ever been to Boulder; I hear they're hiring...... 👍
      Just Curious...
      • bagateloB Offline
        bagatelo
        Someone already ask for freeze layers content?
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          I'm not sure I could do that. 😕
          • I Offline
            ivreich
            OMGOMGOMGOMGOMGOMG
            Layer groups!!! FINALLY. THANK YOU...You are a godsend!
            Now if only we can get Trimble to pay you royalties to include this in the next basebuild of SU...It's something they should have had since the very beginning
            Well done.
            Joel
            • cmeedC Offline
              cmeed
              this looks like a really good addition to sketchup.
              but - existing layers don't show up. downloaded plugin mid project.
              using latest sketchup and latest version of Layers panel. Windows.
              cheers
              c
              EDIT: I'm not sure what happened but the layers have now appeared - it could have coincided with me importing an image but not sure
              • X Offline
                xkalvisx
                Does not save group names
                opening the panel, the group names reappear (Group1, group2, etc.).
                More ...
                We would like to keep the size of the panel as it was before it was shut down.
                Great thanks.
                https://www.dropbox.com/s/mw0340kn4nvquja/1.jpg
                Dropbox - Error - Simplify your life
                (www.dropbox.com)
                Before it was listed all the names of the groups.
                Thanks.
                • bagateloB Offline
                  bagatelo
                  Maybe you can add this function?
                  http://sketchucation.com/forums/viewtopic.php?f=323&t=54108&p=490389#p490389
                  • cmeedC Offline
                    cmeed
                    This plugin is really good. And intuitive. maybe because its so familiar (pShop)
                    I am losing my group names. no data lost but its happened a couple of times.
                    I'm looking out for the next time and will report ..
                    cheers
                    c
                    EDIT: every time i use "undo" the layer Group Name reverts back to the "Group1"- its original default name.
                    Anybody confirm this???
                    (all layer names within group stay the same)
                      jiminy-billy-bob
                      Sorry guys about the group names, I'll look into it.
                      When you had the problem, did you restart sketchup after installing the plugin ?
                      If you manage to reproduce the bug, I would be glad if you gave me the intructions.
                      Sorry, but that's a limitation of the API. Sketchup saves the dialog's size/position between sessions, but not during a session... Dumb, I know, but there's not much I can do.
                      That's not really the purpose of the plugin, which is to manage layers, not the model's entities. Maybe one day I'll add this kind of features, but for now that's not my priority.
                        jiminy-billy-bob
                        When you undo, the Layers Panel dialog reloads its content. So what you're seeing is related to the same bug everybody is having with group names.
                        • cmeedC Offline
                          cmeed
                          Yes i restarted - they didn't appear right away! they appeared after i'd worked on the model for a bit. then i noticed. I'll keep my eyes open when next time the occasion crops up.
                          Great to see this Plugin. especially the "add layer visible only in this scene" - touch!!
                          c
                            jiminy-billy-bob
                            If you have an old copy of the file that you didn't open after you installed Layers Panel, it would be great if you could PM it to me 😄
                            • cmeedC Offline
                              cmeed
                              I've just had a bugsplat - was it from this plugin? its new on my computer..... also new, the latest version of su was downloaded this morning
                              the major thing is i can't open the file now. "unexpected file format"!!!! Any Help?
                              arrgh
                              c
                                jiminy-billy-bob
                                Did you try disabling/uninstalling the plugin ?
                                • cmeedC Offline
                                  cmeed
                                  everything was working well (the group names was the only thing) I was working inside a group outliner was open and then i got the bugsplat. I dont normally get bugsplats so its funny.
                                  I didn't uninstall or do anything witht the plugin.
                                  did you mean to uninstall it and try opening the files? as I've tried opening themon my Mac (no "Layers {abel" plugin) and still not luck - It happened on my pc
                                  opening .skb and .skp result with Unexpected file format.
                                  • kenK Offline
                                    ken
                                    I have had the same problem as cmeed. The unexpected file format. Luckily for me I had a backup or I would have lost the file.
                                    Note, I have the plugin TIG: Archiver v2.0 which is a life saver.
                                    http://sketchucation.com/forums/viewtopic.php?p=149749#p149749
                                    Thanks for your plugin.
                                    Ken
                                      jiminy-billy-bob
                                      Holy sh...
                                      I'll try to reproduce the bug. That's a big problem if it corrupts files... 😕 I'm so sorry, I hope you didn't lose your work.
                                      I'll add a warning in the first post.
                                        jiminy-billy-bob
                                        cmeed, can you check if you still have the dump/log files produced by the bugsplat ?
                                        • cmeedC Offline
                                          cmeed
                                          I have started again (this time with archiver as cover)
                                          c
                                          • ElibjrE Offline
                                            Elibjr
                                            Oh wow, this is truly a nice plugin. I wished that the standard layers toolbar worked this way. Now I want to install in on both my laptop and the desktop machine. This is one of the cleanest plugins I have used. Great work Jiminy. My top 10 now.
                                            Elibjr
                                            • 33
                                            • 34
                                            • 3 / 34
