    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 368.9k Views 110 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      @utiler said:
      Hey JBB, one question before I try it out: when you add a layer is that layers' visibility only visible in the current scene? If not can it be???? So tedious when adding a layer to then have to go through all other scenes to turn it off it you only want it visible in one scene.
      Not yet, this option is on my todo list ๐Ÿ˜‰
      In the meantime, you can use another plugin to do that, Layers Panel should work with anything adding layers.
      • utilerU
        utiler
        Thanks mate, look forward to your updates!! ๐Ÿ‘
        Just Curious...
        • jiminy-billy-bobJ
          jiminy-billy-bob
          In my stats, I see some users on Mac OSX using Layers Panel several days in a row. So I'm guessing it's kind of working on OSX. Can someone tell me exactly what's working and what's not ? Thanks ๐Ÿ˜„
          • G
            glro
            Vismap does what you are asking for
            404 Not Found
            (sketchucation.com)
            • EdsonE
              Edson
              this looks to be a great plugin. I would not want to miss out on it! however, I am a mac user. ๐Ÿ˜ž any chance of it working on mac os in the near future? ๐Ÿ˜„
              edson mahfuz, architect| porto alegre โ€ข brasil
              http://www.mahfuz.arq.br
              • jiminy-billy-bobJ
                jiminy-billy-bob
                There are chances, but it'll need a fair amount of modification, because OSX doesn't handle webdialog the same as Windows (a lot more complicated, actually). Plus, I don't have a mac myself, so debug won't be easy.
                • EdsonE
                  Edson
                  I hope you do it. why not ask for help from the other authors on this forum? they have been able to port their plugins to mac os.
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    I will, but first I'm learning what are the differences between windows and mac.
                      db11
                      Looking forward to a functioning Mac version!
                      A question / suggestion:
                      Any chance that your plugin will work with the TIG's Layer Name Export/Import plug-in in a way that will preserve/establish the layer hierarchy?
                      I would love to have standardized, predefined layer outline sets โ€” depending on the type of model being built: i.e. furniture, cabinetry, architectural, product design โ€” that could be loaded from a .layers file on starting a new model. I do that now, but being able to import an outlined layer structure would be killer!
                      • jiminy-billy-bobJ
                        jiminy-billy-bob
                        I'll look into that. In the meantime, you can use templates. They should keep the nested/sorted structure.
                          db11
                          Cool.
                          Given that you report some people apparently using the beta on their macs, maybe I will try it out as-is to help with user testing. Don't have the knowledge to help on the Ruby front, but can at least add my voice through bug reporting (assuming that the current beta works at all on my mac).
                          I'm running SU8 on OSX 10.6.8 (Snow Leopard)... will let you know how it goes.
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            Great, thanks ! ๐Ÿ˜„
                              db11
                              OK, after about an hour of playing (and 1 bug splat) around here's what I found on my mac:
                              What works:
                              • installation
                              • toolbar
                              • web dialogue (layers panel window)
                              • add layer
                              • add group
                              • name/rename group/layer
                              • nest / move
                              • import layers through TIGs plugin - fills layer panel
                              • layer visibility toggle
                              Doesn't work:
                              • group visibility (no effect at all)
                              • delete layer (no effect at all)
                              • delete group (deletes group and nested layers from panel, but not Layers window)
                              • purge unused layers
                              Big Problems:
                              • existing layers don't automatically fill layer panel
                              • on save and close / reopen, layer panel loses all layers
                              • on switching focus to a second model window, the layer panel loses all layers
                                ( probably related to the fact that Mac OS allows multiple windows in a single application instance whereas Windows allows only one window per application instance (therefore multiple model windows = multiple SU instances) IIANM.
                              Hope this helps. This is going to be an awesome plugin once it's debugged!
                              • jiminy-billy-bobJ
                                jiminy-billy-bob
                                Thanks a lot ! That's very usefull ๐Ÿ˜„
                                • ToboboT
                                  Tobobo
                                  This looks like a giant leap forward. Well done ๐Ÿ‘
                                  I use a lot of models from other people and CAD drawings, this will be great to keep the model organised.
                                  Toby
                                  Philippians 4:13
                                  • jiminy-billy-bobJ
                                    jiminy-billy-bob
                                    New version 0.3 beta !
                                    Changelog :
                                    • Locking layers (Works only when purging or deleting from the plugin's menu)
                                    • Ability to add a layer only visible in the current scene (New pop-up menu when holding the "Add layer" button)
                                    • Layers Panel is now a toolwindow, but you can't dock nor collapse it
                                    • Two different delete buttons, for better performance (The red cross deletes the layer content, the green arrow moves the content to the default layer)
                                    • Several bug fix
                                    http://i.imgur.com/5ly9dzl.png
                                    Download in the plugin store !
                                    • utilerU
                                      utiler
                                      Gee, you do work fast and listen to request, JBB!!!!!!
                                      Have you ever been to Boulder; I hear they're hiring...... ๐Ÿ‘
                                      Just Curious...
                                      • bagateloB
                                        bagatelo
                                        Someone already ask for freeze layers content?
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          I'm not sure I could do that. ๐Ÿ˜•
                                          • I
                                            ivreich
                                            OMGOMGOMGOMGOMGOMG
                                            Layer groups!!! FINALLY. THANK YOU...You are a godsend!
                                            Now if only we can get Trimble to pay you royalties to include this in the next basebuild of SU...It's something they should have had since the very beginning
                                            Well done.
                                            Joel
                                            • 33
                                            • 34
                                            • 2 / 34
