    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.8k Views 109 Watching
      tald311
      Awesome. Another very needed plugin to help sort and organize. This will get a ton of use.
      THANK YOU
      Daniel
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Ken > Your first bug was coming from layers created before the plugin installation, this new version 0.2 should fix it : http://sketchucation.com/resources/pluginstore?pln=Layers_Panel
        Not sure about the second... Do you have this problem with every file you're trying to save as template, even a brand new one ?
        • kenK Offline
          ken
          I can save a template files OK. No problems.
          And yes the layers were created before installing your plugin. They are layers I had on my template. Will remove all my layers and try again.
          Thanks for the quick response.
          Ken
            jiminy-billy-bob
            The new version should work ok with old layers. No need to remove them.
              greatoe
              It should with some addition/modification of the code. The main problem is that I don't have a mac, so I'll need a mac user to help me testing.
              I am very much willing to help testing.
                jiminy-billy-bob
                That's kind of you, but do you have any knowledge in ruby/javascript development ?
                • bobpineoB Offline
                  bobpineo
                  Hey this looks promising,thank you!
                  Quick question, can I use the same layer in multiple groups I create?
                  For Instance lets say i wanted group Called "Foundation Plan" and one of the layers in that group was called "CMU Wall"..
                  Could I create another group called "Typical Section" that also had the same "CMU Wall" inside that new group?
                  Also, could this plugin be used to open an existing drawing with Layers, and the layers already created automatically show up in the dialogue box you have created?
                  The Previously created layer names don't show up
                  Best.
                  BP
                  Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                    jiminy-billy-bob
                    Nope. And even if I tried to mkde the plugin to allow that, I already see a number of problems...
                    Best.
                    BP
                    Weird, it should work. Are you using version 0.2 ? What is your windows version, and internet explorer version ? Can you send me the file ?
                    • utilerU Offline
                      utiler
                      Gee I hope a 'trimbler' is lurking here.... so much can be learnt from a user driven solution!!!! And soooo needed for sooo long.....!!!!!!!
                      I've posted here previously about combining Outliner and Layer functionality and here it is!
                      Plugin of the year for sure! Well done mate! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
                      Just Curious...
                      • utilerU Offline
                        utiler
                        Hey JBB, one question before I try it out: when you add a layer is that layers' visibility only visible in the current scene? If not can it be???? So tedious when adding a layer to then have to go through all other scenes to turn it off it you only want it visible in one scene.
                        Just Curious...
                          jiminy-billy-bob
                          Not yet, this option is on my todo list πŸ˜‰
                          In the meantime, you can use another plugin to do that, Layers Panel should work with anything adding layers.
                          • utilerU Offline
                            utiler
                            Thanks mate, look forward to your updates!! πŸ‘
                            Just Curious...
                              jiminy-billy-bob
                              In my stats, I see some users on Mac OSX using Layers Panel several days in a row. So I'm guessing it's kind of working on OSX. Can someone tell me exactly what's working and what's not ? Thanks πŸ˜„
                                glro
                                Vismap does what you are asking for
                                http://sketchucation.com/forums/viewtopic.php?t=23029
                                • EdsonE Offline
                                  Edson
                                  this looks to be a great plugin. I would not want to miss out on it! however, I am a mac user. 😞 any chance of it working on mac os in the near future? πŸ˜„
                                  http://www.mahfuz.arq.br
                                    jiminy-billy-bob
                                    There are chances, but it'll need a fair amount of modification, because OSX doesn't handle webdialog the same as Windows (a lot more complicated, actually). Plus, I don't have a mac myself, so debug won't be easy.
                                    • EdsonE Offline
                                      Edson
                                      I hope you do it. why not ask for help from the other authors on this forum? they have been able to port their plugins to mac os.
                                        jiminy-billy-bob
                                        I will, but first I'm learning what are the differences between windows and mac.
                                          db11
                                          Looking forward to a functioning Mac version!
                                          A question / suggestion:
                                          Any chance that your plugin will work with the TIG's Layer Name Export/Import plug-in in a way that will preserve/establish the layer hierarchy?
                                          I would love to have standardized, predefined layer outline sets β€” depending on the type of model being built: i.e. furniture, cabinetry, architectural, product design β€” that could be loaded from a .layers file on starting a new model. I do that now, but being able to import an outlined layer structure would be killer!
                                            jiminy-billy-bob
                                            I'll look into that. In the meantime, you can use templates. They should keep the nested/sorted structure.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 29 / 34
