    Bend Stairs to Curved Wall
    22 Posts 6 Posters 2.3k Views 6 Watching
      So your real data for the tank indicates the number of sides you must use to draw a cylinder? Well, then make the steps longer so they extend inside the cylinder and cut them off at the wall of the tank after you've placed them.
      Why do you keep trotting out new details with each post? We have no way of knowing all these things unless you tell us.
        ryangarnett
        Here is a sample of the tankers I need to model. So the "building" or tank with height will be provided, but I have to add the detail (stairs). And as you can see in the picture, the stairs "snap" to the side of the tank and do not overlap.
          ryangarnett
          I'm not trotting out new detail, its in the post "to curved wall". You are proposing changing my wall, so I am providing you the information as to why that won't work.
            [screenr:2fyym52b]fwXH[/screenr:2fyym52b]
            • jeff hammondJ Offline
              @rich o brien said:
              fwXH
              πŸ˜†
              i found fault with that.
              (j/k)
                spreadcore
                Just asking is this close to what your trying to do?
                I used shape bender.
                http://s5.postimg.org/hr2p2wvyf/fueltank.jpg
                  ryangarnett
                  Yes that is exactly what I am hoping to achieve. When I have used Shape Bender it lines the stairs up wrong. Would you mind sharing your steps, etc...
                  Thanks...
                    spreadcore
                    Thanks...
                    I assume your referring to me.
                    Okay I made a tutorial, I hope I did it right first time making one.
                    FYI: I used TIGs ArcBy plugin to make the arc.
                    TIGs ArcBy Plugin here...
                    http://sketchucation.com/resources/pluginstore?pln=TIG_arcBYtools
                    TIGs ArcBy...
                    I used the "Radius+Length"
                    • Type in radius of the cylinder
                    • Type in length of the arc
                    • Change number of segments
                    tank_stairs_tut.skp
                      ryangarnett
                      Thanks Spreadcore...I will try that for sure....Thanks again...
                        ryangarnett
                        Thank you spreadcore...that tutorial was perfect. I didn't know that you had to have the stairs the same height, and that the straight line needed to be the same length as the rise. These were then things I was missing.
                        Thanks again....really helped!
                          spreadcore
                          Your welcome, glad it worked for you.
                          FYI:
                          The straight line needs to be the same length as the "Run" of the stairs.
                          The "Rise" is the height of the stairs.
                            ryangarnett
                            Thanks again...
