    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 696.8k Views 121 Watching
    • pbacotP Offline
      😳 I didn't realize it was under the FredoTools submenu... it used to be different right? Or am I imagining?
      Thanks for the help. Now I have this oft-used function again!
      • fredo6F Offline
        @pbacot said:
        :oops: I didn't realize it was under the FredoTools submenu... it used to be different right? Or am I imagining?
        Well! It is like this because the real estate of the contextual menu is precious.
        But of course, it is less efficient.
          AsiaStarArt
          β˜€
          θ°’θ°’δ½
          Thank
            asaavedra
            Hello, I love Freddo plug ins, but I installed SketchUp 13 and these plug ins do not work ... you plan to make it compatible soon??
            • Alan FraserA Offline
              Alan Fraser
              They do work. Update your Fredo6 Library file.
              3D Figures
                ruggero56
                Devo studiare tutto in inglese, Fredo!! Ma la installazione Γ¨ stata perfetta! Complimenti e grazie! πŸ˜„
                  davi
                  thank you very much!
                    jumboojum
                    Thank you so much sir 😍
                      tolson68
                      Fredo,
                      I have installed Sketchup 2013 Make on a Linux instance and it seems to be working well. Unfortunately I have a problem loading FredoTools 1.2a. The error message I receive is:
                      Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rb
                      can't convert nil into String
                      I have tried disabling my other plugins to isolate the cause and then adding them back one at a time and when FredoTools is enabled I start having this problem. I'm happy to assist you in any tracing, since I'm aware that SketchUp itself is not supported on Linux. This is a brand new install and all plugins packages have been downloaded within the past 24 hours.
                      I am also encountering the same problem in Sketchup 8 on the same machine.
                      Kind Regards,
                      Tom
                        @Tom
                        Ensure that the SketchUp Plugins folder AND all of its contents [subfolders/files] have FULL Read/Write security permissions set.
                        On Windows existing contents typically adopt the settings of their parent.
                        Properties > Security > Edit... each user/group in the list > FULL... Apply/OK
                        On a MAC you need to deliberately tell the OS to apply the changes to contents.
                        On Linux it may be the same...
                        Also set Sketchup.exe to 'always run as administrator' [if you can] ...
                        Do you have that .rb file in the named subfolder
                        C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rbIf not, then it suggests you had limited permissions and the have not installed the files as you think you have...
                        • fredo6F Offline
                          @tolson68 said:
                          Fredo,
                          Tom,
                          Strange message. Not sure it is related to your Linux installation.
                          Could you check that the file __loader.rb contains a single line:
                          Traductor::Plugin.myplugin('FredoTools').effective_load
                            tolson68
                            TIG, The __loader.rb does exist in the .../FREDOTOOLS_Dir_12/ folder and has it's permissions set to -rw-r--r-- and all other *.rb files have the same permissions.
                            Fredo, The __loader.rb file does contain the line:
                            ...and nothing else.
                            If I rename the 000_AdditionalPluginFolders.rb file the error appears to go away, which seems like an acceptable workaround. I am unable to use WebDialog for that add-on for somereason. All other WebDialogs are working, but that one just displays raw HTML, but does not generate any exceptions other than when FredoTools is loaded, curious.
                            Thanks,
                            Tom
                              tolson68
                              Fredo,
                              I stand corrected renaming the 000_AdditionalPluginsFolder.rb did not resolve the problem, but it did expose a different/extended message:
                              Error Loading File ZLoader__GhostComp.rb
                                songkran77
                                πŸ‘ πŸ‘ thank you very much
                                  dedmin
                                  http://screencast.com/t/lSl60f8IB
                                  • fredo6F Offline
                                    Very strange.
                                    Can come from 2 possible causes:
                                    1. MaxwellFire modifies the SU model and the texturing (does it?), and then ThruPaint or MaxWellFire script crashes when it is used (could be related to observers)
                                    2. or there is a more traditional plugin conflict
                                    Could you send me a model where you do the rendering, but just before you try to apply the TrhruPaint texturing.
                                      dedmin
                                      There is no model - just a simple rectangle, then push-pull to a 3D box.
                                      • fredo6F Offline
                                        That was just in case MaxwellFire modifies the texture. So just the model after you do the rendering.
                                        Otherwise, this may simply come from a plugin conflict, either at code level, or due to handling of observers in MaxwellFire.
                                          dedmin
                                          The material was just default sketchup material. This file was rendered with Maxwell:
                                          Buro_11.skp
                                          • fredo6F Offline
                                            [attachment=0:2047gaia]<!-- ia0 -->Buro_11.skp<!-- ia0 -->[/attachment:2047gaia]
                                            I get NO crash when using ThurPaint.
                                            So it must be another conflict between scripts (There was one for Vray Beta 1.6).
                                            Maybe some other users have found a similar problem.
                                            fredo
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 21 / 24
