    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.7k Views 122 Watching
      @Tom
      Ensure that the SketchUp Plugins folder AND all of its contents [subfolders/files] have FULL Read/Write security permissions set.
      On Windows existing contents typically adopt the settings of their parent.
      Properties > Security > Edit... each user/group in the list > FULL... Apply/OK
      On a MAC you need to deliberately tell the OS to apply the changes to contents.
      On Linux it may be the same...
      Also set Sketchup.exe to 'always run as administrator' [if you can] ...
      Do you have that .rb file in the named subfolder
      C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rbIf not, then it suggests you had limited permissions and the have not installed the files as you think you have...
      • fredo6F
        @tolson68 said:
        Fredo,
        I have installed Sketchup 2013 Make on a Linux instance and it seems to be working well. Unfortunately I have a problem loading FredoTools 1.2a. The error message I receive is:
        Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rb
        can't convert nil into String
        Tom,
        Strange message. Not sure it is related to your Linux installation.
        Could you check that the file __loader.rb contains a single line:
        Traductor::Plugin.myplugin('FredoTools').effective_load
        • T
          tolson68
          TIG, The __loader.rb does exist in the .../FREDOTOOLS_Dir_12/ folder and has it's permissions set to -rw-r--r-- and all other *.rb files have the same permissions.
          Fredo, The __loader.rb file does contain the line:
          ...and nothing else.
          If I rename the 000_AdditionalPluginFolders.rb file the error appears to go away, which seems like an acceptable workaround. I am unable to use WebDialog for that add-on for somereason. All other WebDialogs are working, but that one just displays raw HTML, but does not generate any exceptions other than when FredoTools is loaded, curious.
          Thanks,
          Tom
          • T
            tolson68
            Fredo,
            I stand corrected renaming the 000_AdditionalPluginsFolder.rb did not resolve the problem, but it did expose a different/extended message:
            Error Loading File ZLoader__GhostComp.rb
              songkran77
              πŸ‘ πŸ‘ thank you very much
                dedmin
                (screencast.com)
                • fredo6F
                  @dedmin said:
                  (screencast.com)
                  Very strange.
                  Can come from 2 possible causes:
                  1. MaxwellFire modifies the SU model and the texturing (does it?), and then ThruPaint or MaxWellFire script crashes when it is used (could be related to observers)
                  2. or there is a more traditional plugin conflict
                  Could you send me a model where you do the rendering, but just before you try to apply the TrhruPaint texturing.
                    dedmin
                    There is no model - just a simple rectangle, then push-pull to a 3D box.
                    • fredo6F
                      That was just in case MaxwellFire modifies the texture. So just the model after you do the rendering.
                      Otherwise, this may simply come from a plugin conflict, either at code level, or due to handling of observers in MaxwellFire.
                        dedmin
                        The material was just default sketchup material. This file was rendered with Maxwell:
                        Buro_11.skp
                        • fredo6F
                          [attachment=0:2047gaia]<!-- ia0 -->Buro_11.skp<!-- ia0 -->[/attachment:2047gaia]
                          I get NO crash when using ThurPaint.
                          So it must be another conflict between scripts (There was one for Vray Beta 1.6).
                          Maybe some other users have found a similar problem.
                          fredo
                          • B
                            Bimbalas
                            @tolson68 said:
                            Fredo,
                            I have tried disabling my other plugins to isolate the cause and then adding them back one at a time and when FredoTools is enabled I start having this problem. I'm happy to assist you in any tracing, since I'm aware that SketchUp itself is not supported on Linux. This is a brand new install and all plugins packages have been downloaded within the past 24 hours.
                            I am also encountering the same problem in Sketchup 8 on the same machine.
                            Kind Regards,
                            Tom
                            Hi, Tom,
                            I have the same problem on my nature windows machine and on linux/ubuntu machine through wine. The workaround is very simple. I moved all Fredo6 plugins to default sketchup plugins folder and now all they works as expected. Probably problem occurs on AdditionalPluginFolders.rb level.
                            • T
                              txusic
                              Hi fredo.. IΒ΄ms sure you and all around are bored of answering the same questions.. but i read thoroughly and couldn't find an answer....
                              I work on an old PowerPc G5 (pre-Intel) and SketchUp 7 (7.1.6859)
                              i copy the plugins in the right place
                              mac hd >library > application support > google sketchup 7 > sketchip > plugins
                              tryed to change names, place them in original folders, change the web browser (downloader as safari was giving funny names), change the un-compressor.. every thing to no luck
                              Here is an image where u see shaded all the info
                              thanx for any help in advance...
                              PD congratulations other plugins i tryed, are fantastic!!
                              error file image
                              • chonC
                                chon
                                Fredo,
                                I've got an issue using FredoTools with AdditionalPluginFolders.
                                The problem is related here with shortcuts for illustration.
                                Many thanks to look at that ! πŸ‘
                                SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                                • fredo6F
                                  @chon said:
                                  Fredo,
                                  It seems the issue is in LibFredo6 actually (error in the logging of errors!!). I don't know why you have FredoTools in error. Possibly you may open the Windows > LibFredo6 Settings > View Trace Files... dialog box and check if there is more info (in red).
                                  Anyway, I would suggest the following
                                  • Upgrade to AdditionalPluginFolders 4.2a
                                  • Upgrade to LibFredo6 5.3g (just published).
                                  Then, if you still get the error, could try to drop and replace the attached file Fredo6_!LibFredo6.rb in the directory where you installed my scripts.
                                  • chonC
                                    chon
                                    Thanks for help Fredo ! πŸ‘
                                    Here is the "View trace files" :
                                    As you can see, my Fredo6 tools are up to date... πŸ˜‰
                                    Another question : Fredo6 has created a default parameters folder on the first level of C:/ (visible on the 4th line of the "View trace files").
                                    Is it possible to locate this folder at another place ?
                                    • chonC
                                      chon
                                      Fredo,
                                      update of Libfredo6 solved part of the problem but not all :
                                      Here is the message error :
                                      Here is the trace log (only error items) :
                                      >>>> 1383119187.795;Lib6Core.rb;649;  in `load_full_rubies'
                                      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ThruPaint.rb
                                      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ThruPaint.rb;34
                                      >>>> 1383119187.824;Lib6Core.rb;649;  in `load_full_rubies'
                                      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__RemoveLonelyVertices.rb
                                      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__RemoveLonelyVertices.rb;36
                                      >>>> 1383119187.853;Lib6Core.rb;649;  in `load_full_rubies'
                                      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__MarkVertices.rb
                                      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__MarkVertices.rb;36
                                      >>>> 1383119187.877;Lib6Core.rb;649;  in `load_full_rubies'
                                      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__CountFacesBySides.rb
                                      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__CountFacesBySides.rb;34
                                      >>>> 1383119187.892;Lib6Core.rb;649;  in `load_full_rubies'
                                      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReverseOrientFaces.rb
                                      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReverseOrientFaces.rb;34
                                      >>>> 1383119187.942;Lib6Core.rb;649;  in `load_full_rubies'
                                      ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReportLabelArea.rb
                                      undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReportLabelArea.rb;34
                                      ConstructFaceNormal, CurviShear and RevertCurve seem to work fine ! πŸ‘
                                      • fredo6F
                                        Very very strange.
                                        I would expect that none works or all work.
                                        I'll have a closer look
                                        Could you show me the content of the subfolder FREDOTOOLS_Dir_12 (files and dates)
                                        • chonC
                                          chon
                                          • LAGRARI2012L
                                            LAGRARI2012
                                            very good contribution πŸ‘ πŸ‘ πŸ‘
                                            • 23
                                            • 24
                                            • 6 / 24
