    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.7k Views 122 Watching
    • Alan FraserA
      Alan Fraser
      @asaavedra said:
      Hello, I love Freddo plug ins, but I installed SketchUp 13 and these plug ins do not work ... you plan to make it compatible soon??
      They do work. Update your Fredo6 Library file.
      3D Figures
        ruggero56
        Devo studiare tutto in inglese, Fredo!! Ma la installazione Γ¨ stata perfetta! Complimenti e grazie! πŸ˜„
          davi
          thank you very much!
            jumboojum
            Thank you so much sir 😍
            • T
              tolson68
              Fredo,
              I have installed Sketchup 2013 Make on a Linux instance and it seems to be working well. Unfortunately I have a problem loading FredoTools 1.2a. The error message I receive is:
              Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rb
              can't convert nil into String
              I have tried disabling my other plugins to isolate the cause and then adding them back one at a time and when FredoTools is enabled I start having this problem. I'm happy to assist you in any tracing, since I'm aware that SketchUp itself is not supported on Linux. This is a brand new install and all plugins packages have been downloaded within the past 24 hours.
              I am also encountering the same problem in Sketchup 8 on the same machine.
              Kind Regards,
              Tom
                @Tom
                Ensure that the SketchUp Plugins folder AND all of its contents [subfolders/files] have FULL Read/Write security permissions set.
                On Windows existing contents typically adopt the settings of their parent.
                Properties > Security > Edit... each user/group in the list > FULL... Apply/OK
                On a MAC you need to deliberately tell the OS to apply the changes to contents.
                On Linux it may be the same...
                Also set Sketchup.exe to 'always run as administrator' [if you can] ...
                Do you have that .rb file in the named subfolder
                C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rbIf not, then it suggests you had limited permissions and the have not installed the files as you think you have...
                • fredo6F
                  @tolson68 said:
                  Fredo,
                  Tom,
                  Strange message. Not sure it is related to your Linux installation.
                  Could you check that the file __loader.rb contains a single line:
                  Traductor::Plugin.myplugin('FredoTools').effective_load
                  • T
                    tolson68
                    TIG, The __loader.rb does exist in the .../FREDOTOOLS_Dir_12/ folder and has it's permissions set to -rw-r--r-- and all other *.rb files have the same permissions.
                    Fredo, The __loader.rb file does contain the line:
                    ...and nothing else.
                    If I rename the 000_AdditionalPluginFolders.rb file the error appears to go away, which seems like an acceptable workaround. I am unable to use WebDialog for that add-on for somereason. All other WebDialogs are working, but that one just displays raw HTML, but does not generate any exceptions other than when FredoTools is loaded, curious.
                    Thanks,
                    Tom
                    • T
                      tolson68
                      Fredo,
                      I stand corrected renaming the 000_AdditionalPluginsFolder.rb did not resolve the problem, but it did expose a different/extended message:
                      Error Loading File ZLoader__GhostComp.rb
                        songkran77
                        πŸ‘ πŸ‘ thank you very much
                          dedmin
                          (screencast.com)
                          • fredo6F
                            @dedmin said:
                            (screencast.com)
                            Very strange.
                            Can come from 2 possible causes:
                            1. MaxwellFire modifies the SU model and the texturing (does it?), and then ThruPaint or MaxWellFire script crashes when it is used (could be related to observers)
                            2. or there is a more traditional plugin conflict
                            Could you send me a model where you do the rendering, but just before you try to apply the TrhruPaint texturing.
                              dedmin
                              There is no model - just a simple rectangle, then push-pull to a 3D box.
                              • fredo6F
                                That was just in case MaxwellFire modifies the texture. So just the model after you do the rendering.
                                Otherwise, this may simply come from a plugin conflict, either at code level, or due to handling of observers in MaxwellFire.
                                  dedmin
                                  The material was just default sketchup material. This file was rendered with Maxwell:
                                  Buro_11.skp
                                  • fredo6F
                                    [attachment=0:2047gaia]<!-- ia0 -->Buro_11.skp<!-- ia0 -->[/attachment:2047gaia]
                                    I get NO crash when using ThurPaint.
                                    So it must be another conflict between scripts (There was one for Vray Beta 1.6).
                                    Maybe some other users have found a similar problem.
                                    fredo
                                    • B
                                      Bimbalas
                                      @tolson68 said:
                                      Fredo,
                                      Kind Regards,
                                      Tom
                                      Hi, Tom,
                                      I have the same problem on my nature windows machine and on linux/ubuntu machine through wine. The workaround is very simple. I moved all Fredo6 plugins to default sketchup plugins folder and now all they works as expected. Probably problem occurs on AdditionalPluginFolders.rb level.
                                      • T
                                        txusic
                                        Hi fredo.. IΒ΄ms sure you and all around are bored of answering the same questions.. but i read thoroughly and couldn't find an answer....
                                        I work on an old PowerPc G5 (pre-Intel) and SketchUp 7 (7.1.6859)
                                        i copy the plugins in the right place
                                        mac hd >library > application support > google sketchup 7 > sketchip > plugins
                                        tryed to change names, place them in original folders, change the web browser (downloader as safari was giving funny names), change the un-compressor.. every thing to no luck
                                        Here is an image where u see shaded all the info
                                        thanx for any help in advance...
                                        PD congratulations other plugins i tryed, are fantastic!!
                                        error file image
                                        • chonC
                                          chon
                                          Fredo,
                                          I've got an issue using FredoTools with AdditionalPluginFolders.
                                          The problem is related here with shortcuts for illustration.
                                          Many thanks to look at that ! πŸ‘
                                          SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
                                          • fredo6F
                                            @chon said:
                                            Fredo,
                                            It seems the issue is in LibFredo6 actually (error in the logging of errors!!). I don't know why you have FredoTools in error. Possibly you may open the Windows > LibFredo6 Settings > View Trace Files... dialog box and check if there is more info (in red).
                                            Anyway, I would suggest the following
                                            • Upgrade to AdditionalPluginFolders 4.2a
                                            • Upgrade to LibFredo6 5.3g (just published).
                                            Then, if you still get the error, could try to drop and replace the attached file Fredo6_!LibFredo6.rb in the directory where you installed my scripts.
                                            • 23
                                            • 24
                                            • 6 / 24
