    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.8m Views 589 Watching
      @thomthom said:
      Martin: Install RBZ files from within SketchUp, Window > Preferences > Extensions > Install Extension
      For more information on installing plugins check out this article:
      http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
      Sendt from my Xperia Z Tabled using Tapatalk
      On Mac that would be SketchUp>Preferences>Extensions. Left of the File menu.
      If you don't see an Install Extensions button there, you still have the first release of V8 and need to update to a later version of SU8.
        rempeyeks
        thanks brother this update works on my new sketchup 2013
        • fredo6F
          NEW RELEASE: LibFredo6 v5.1a - 22 Aug 13
          LibFredo6 5.1 is a follow up technical release that implements naming conventions for files and folders to be compliant with EWH requirements.
          For LibFredo6, the footprint is based on one file and one subfolder:
          For my scripts, new naming conventions are also based on one file and one subfolder. I will progressively re-release the scripts with the new naming conventions. For instance, FredoScale v2.4 footprint is now :
          For convenience, LibFredo6 5.1 is compatible with the old and new naming conventions. So if you have CURVILOFT_Dir_12 folder, it will be loaded normally (until I publish the new version based on Fredo6_Curviloft and Fredo6_Curviloft).
          It is also a good idea to clean up your plugin directory and remove the older versions.
          In the menu Windows > LibFRedo6 Settings...> Purge Obsolete Files, you will find a dialog box allowing to remove all or some of these older versions.
            dedmin
            SU 2013 Pro, Win 7 64 SP1
            After latest update of the LibFredo and FredoScale I get this error when using "Check for Update":
            Error; #<NoMethodError; undefined method `>=' for nil;NilClass>
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;428;in `prepare_plugin_table'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Traductor.rb;155;in `each_with_index'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;405;in `each'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;405;in `each_with_index'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;405;in `prepare_plugin_table'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;214;in `refresh_dialog_top'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;519;in `create_dialog_top'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;167;in `initialize'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;79;in `new'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;79;in `top_dialog'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6PluginDialogs.rb;657;in `topdialog_callback'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6WebWdlg.rb;501;in `call'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6WebWdlg.rb;501;in `j_action'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6WebWdlg.rb;436;in `j_callback'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6WebWdlg.rb;426;in `j_dispatch'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6WebWdlg.rb;418;in `each'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6WebWdlg.rb;418;in `j_dispatch'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6WebWdlg.rb;159;in `create_dialog'
            C;/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LibFredo6/Lib6Upgrade.rb;428;in `call'
              I do, too.
                Upgrading thru the PluginStore doesn't give errors on my PC Win8
                Nice work Fredo and thanks for sharing it here
                • fredo6F
                  Thanks very much for signaling. Actually a mispelling in my file LibFredo6.plugin (version is 5.1.a and should be 5.1a).
                  I will republish
                    dedmin
                    πŸ‘ πŸ‘
                    • fredo6F
                      NEW RELEASE: LibFredo6 v5.1b - 22 Aug 13
                      LibFredo6 5.1b fixes a bug in v5.1a which prevented the display of the Check For Update dialog box.
                      So you should re-install 5.1b if you had installed 5.1a. Sorry for inconvenience.
                      • kenK
                        ken
                        I have installed LibFredo6 - V5.1b by the store, by extracting and I get the below error box as I load Sketchup 13.
                        Thanks for you help.
                        Ken
                          @Ken
                          Do you have both the latest version of the LibFredo.. and his updated Plugin installed ?
                          After that you do need to restart SketchUp to effect the changes...
                          • esteromxE
                            esteromx
                            I have the same problem that has ken, and install updates for fredoscale and libfredo
                              I have just installed both updates with no problems ??
                              Have you downloaded the two RBZ files and installed those or have you AutoInstalled them from the dialog in SUp itself ?
                              Both ways should work ?
                              Can you recheck your Plugins folder's Properties > Security > Edit is set to FULL for each user/group on the list ?
                              • fredo6F
                                Ken
                                My mistake. In republishing, I have posted a version of 5.0 inadvertedly. (These EWH naming conventions with no version in the folder is a problem).
                                I republished version 5.1c on the Plugin Store and will soon update the main post on SCF.
                                • fredo6F
                                  NEW RELEASE: LibFredo6 v5.1c - 22 Aug 13
                                  LibFredo6 5.1b was wrongly publishing.
                                  So you should re-install 5.1c if you had installed 5.1a. Sorry again for inconvenience.
                                  • kenK
                                    ken
                                    Fredo6
                                    Thanks for the quick reply. I just had a feeling it was "fast fingers".
                                    Ken
                                    • fredo6F
                                      Fredo6
                                      Ken
                                      On top o that, the keyboard was slippery....
                                      Hope it works now.
                                      • kenK
                                        ken
                                        @fredo6 said:
                                        Fredo6
                                        Ken
                                        Hope it works now.
                                        Boy is my imagination running wild now.
                                        Again thanks
                                        Also,TIG, thank you. Never hurts to be reminded to double check the obvious. I also suffer from the "fast finger" syndrome.
                                        • T
                                          the fox8000
                                          When i put the files in my folder and open sketchup it says (Error Loading File ZLoader__OnSurface.rb no such file to load -- LibFredo6.rb)
                                          How do I fix it?
                                            Go back and read the first post of this thread. And then install LibFredo6 like it says to do.
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 113
                                            • 114
                                            • 33 / 114
