    2013 Sketchup Pro Problems
    10 Posts 4 Posters 571 Views 4 Watching
      seasdes
      I find that lines are missing when I create a Group Solid Section by context clicking on a section plane. What do I need to do to stop this from occuring?
      The model looks ok to me.
      Walter
      Resulting Section group
      View of model
      Sketchup file
      Using Sketchup Pro 2019
        You don't suppose it could be due to the fact there's no intersection between the wall and the floor?
          seasdes
          Thanks Dave. I dont think so because all of the walls are capped at the top and bottom.
            The caps at the top and bottom haven't got anything to do with the section plane, though.
              But as Dave says... some of the slabs/walls intersect, some pass through each other and some are not intersected so there is no line where there faces cross one another ?
                seasdes
                Thanks Dave & TIG. Looks like I will need to go through the model with a fine toot comb.
                I will report back. It would be nice if there was a quick fix.
                  I don't mean any disrespect but I think the best fix is to draw the thing better in the first place. πŸ˜‰
                    seasdes
                    Your right. However I started drawing it in 3D cad then imported it into SU. It would have been quicker to start from scratch again.
                      I understand that. It's a shame but it often seems like it's easier and better to start from scratch in SketchUp than to try using an imported file.
                      • pbacotP Offline
                        Selecting problem areas and intersecting faces with models might get you part way there.
