    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • fredo6F
      Jesper,
      You simply did a wrong installation and does not end up with the footprint required, as described in the first post. probably coming from your unzipping operation.
      I would suggest you install once for all the SCF Plugin Store and then install plugins (TopoShaper and many others) from there, as you don't have to interact yourself with the unzipping operation.
      • bulbaB
        bulba
        thanks a lot
        still learning now
        • T
          tomislavm
          thank You!
          • F
            filipeefilipe
            am I ignorant?
            Why is this plugin better than sandbox?
            Filipe from Brazil
              miikka1978
              Thanks for this excellent plugin!
              One question. I have a terrain with contours which is 3000x3000m. I have been using TopoShaper for creating terrain, but I have been running problems when changing the grid size from 50x50 to 100x100. TopeShaper always gets stuck in 63% (calculating boundaries). Has anybody else had similar problems?
              • fredo6F
                If you can, could you open the Ruby console when you do the test 100x100 just in case there is a message displayed.
                Otherwise, may be the best is to post or PM the model.
                  miikka1978
                  I just checked Ruby console but there was nothing. I will PM the model.
                  • fredo6F
                    I answered the PM.
                    The problem is due to an artificial rectangular hull which you includes in the terrain. This prevents to calculate the correct concave hull and therefore the zone of influence of contours.
                    PS: By the way, your model is quite complex, but apparently Toposhaper could deal with it
                    • bobpineoB
                      bobpineo
                      Toposhaper screen captureHello Fredo
                      Love your script!
                      Can't tell you how long I have hoped for something like this.
                      I am having a problem with a large topo map I am working on.
                      As illustrated in the attached image, when I go to preview created mesh there are lines that do not correlate with my topo set.
                      When I generate the mesh, i get this type of deviation.
                      Can you suggest what might be going wrong?
                      many thanks in advance.
                      Best.
                      Bob Pineo
                      Result on mesh
                      Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                      • bobpineoB
                        bobpineo
                        Fredo,
                        Thought it would be helpful if you had topos in case you wanted to run script yourself.
                        Here is a link to Dropbox.
                        https://www.dropbox.com/s/0brplieftg8p27v/just%20raw%20mesh%20for%20TIG.skp
                        Best.
                        BP
                        • fredo6F
                          @bobpineo,
                          Your contour map is extremely large, with close to 30,000 edges, 750 contours, 400 automatic junctions, but also extremely dense, since contours are separated by a very small distance.
                          It's a miracle that TopoShaper (and Ruby underneath) can do something with it!
                          There are a number of problems that I detected:
                          1. do not simplify the contours. There are only 12 simplified, but the contour map is so dense that the simplification creates overlaps with adjacent contours.
                          2. watch out some automatic junctions at the periphery. Some are overlapping.
                          3. there seems to be a bug in Toposhaper, because I observe some shadow straight contours in the Preview mode (but not in the Cleanser mode). I keep your model and will have a closer look at it. It may be related to the calculation of the Concave hull.
                          I run the generation with a 100 x 69 and obtained a result which is not too bad. But with the density of the contours, I think that the sampling should be over 300 x 200 to exploit the high definition of the contours.
                          I can't tell you what to do exactly to avoid some of the artefacts you may observe, except maybe to remove some contours and try again.
                          • bobpineoB
                            bobpineo
                            Thanks Fredo.
                            Yes you are right, this was a dense a map, but I thought I would get as high a resolution as possible because I thought the denser mesh would provide finer resolution for up close shots.
                            The way I solved the problems showing up when I ran the plugin was to open the sketchup file twice, and arrange each one on my split screens. I ran Topo Shaper on one file, and where I noticed a particular problem on one of the contours I would spend some time on it figuring out what was going on.
                            In some cases there was an odd remnant that had to be removed, in other case I just deleted that entire line.
                            in the end, and once the problems where identified and fixed the mesh was created without any trouble.
                            Thanks so much for this plugin, its been wonderful.
                            Best.
                            BP
                            • L
                              ly871108
                              The Chinese version by GUANJIN is too bad ,and lots of Chinese friends ask me to translate the TOPOSHAPER in Chinese again.It spends me a lot of energy and time.This one must be the best Chinese version.Enjoy it!Thank You!
                              Here is a contrast:LY's and GUANJIN's.
                              You will find the truth.
                              SketchUpBAR LY871108
                              • fredo6F
                                Bob,
                                Glad to see that you finally found some workarounds.
                                My experience with the few contour maps I have been using for testing is that the resolution of the contours should always be put in perspective of the required mesh definition. Toposhaper is based on interpolation, which means that intermediate contours below the resolution of the mesh won't really be useful. In the case of your terrain, I think you needed a resolution above 300 x 200 to exploit all the details of your contours.
                                I still think there are some bugs left in TopoShaper and your contour map will be useful for me to track them (and hopefully fix them in a next release).
                                • bobpineoB
                                  bobpineo
                                  Thanks so much Fredo.
                                  Best.
                                  BP
                                    DOD3R
                                    Thanks for this plugin, really helps a lot.
                                    I was trying to do some landscape design and used toposhaper to make faces in my cad underlay, but all triangles did get unsmoothed. Is there any way how to prevent that ?
                                    my landscape with unsmoothed triangular edges
                                    • fredo6F
                                      I guess you just need to select the terrain as a group and then soften / smooth it via the SU dialog box.
                                        DOD3R
                                        hi,
                                        i am sorry my question wasn't precise enough. I want to all triangulated edges to be smoothened, but i want to keep my drawing edges visible. And i want to be able to select surfaces and read the area of streets gardens etc.
                                        If i use your suggestion all edges will be smoothened.
                                        Is there any setting that can do that or some workaround ?
                                        thank you for this great plug in
                                        D.
                                        • pbacotP
                                          Not sure what you did but the native (well, SandBox IS a plugin) SU way would be to create the terrain surface and then drape (Sandbox tools) your line work onto it. That way the line work will show as edges on a smoothed terrain.
                                            DOD3R
                                            Brief description what i did.
                                            import dwg (mostly in one plane)
                                            run toposhaper
                                            what i hoped for = have a surface generate over dwg lines with separate surfaces for different parts of dwg. Like street, lawns, pavements would be one surface with selectable areas.
                                            • 22
                                            • 23
                                            • 6 / 23
