    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • fredo6F
      @solo
      Strange, because there is nowhere bTopoShaper in my code (I checked).
      I hope it does not come from a corruption of the files or the zip archive.
      Could you go to the LibFredo6 Trace Log and check if you see an error. If so, it is usually more documented.
      • soloS
        @fredo6 said:
        @solo
        That's a typo, there is no b. 😄
        How do I do the libFredo6 trace thing?
          go to C:\Users#####\AppData\Local\Temp
          Look for LibFredoTrace-##-#########.txt
          • soloS
            >>>> 1369346329.538;LibFredo6.rb;62; in `log'
            DATE / TIME; Thu May 23 16;58;49 -0500 2013
            SKETCHUP VERSION; 13.0.3759
            RUBY_PLATFORM; i386-mswin32
            LOG FILE; LibFredo6Trace_13_1369346329538.txt
            >>>> 1369346329.538;LibFredo6.rb;103; in `startup'
            LibFredo6; Starting up LibFredo6.rb
            >>>> 1369346329.538;LibFredo6.rb;118; in `startup'
            LibFredo6; Beginning of loading Cycle***+
            >>>> 1369346329.548;LibFredo6.rb;129; in `startup'
            LibFredo6 Core; LIBFREDO6_Dir_49/Lib6Core_49.rb successfully loaded
            >>>> 1369346329.771;Lib6Core_49.rb;642; in `load_full_rubies'
            LibFredo6 4.9c; Ruby files loaded         [213 ms]
            >>>> 1369346329.871;Lib6Core_49.rb;642; in `load_full_rubies'
            ToolsOnSurface 1.6c; Ruby files loaded         [80 ms]
            >>>> 1369346329.921;Lib6Core_49.rb;613; in `load_bootstrap_rubies'
            TopoShaper 1.0b; Bootstrap Ruby files loaded         [0 ms]
            >>>> 1369346329.931;LibFredo6.rb;139; in `startup'
            LibFredo6; End of loading Cycle***-
            >>>> 1369347588.651;Lib6Core_49.rb;642; in `load_full_rubies'
            TopoShaper 1.0b; Ruby files loaded         [30 ms]
            • fredo6F
              Go to menu Windows > LibFredo6 Settings... > Trace Log files.
              You'll get a dialog box. Select the current or most recent trace file.
              Do an expand and check if there are statements in Red.
              You can then export the file from there and post it.
              • soloS
                Nothing in red.
                • fredo6F
                  But then, do you get the message box at startup of SU?
                  • soloS
                    Yup, see image.
                    • fredo6F
                      Very weird. It looks like you have a probleme with installation of LibFredo6, which the trace does not show.
                      I have to check and come back
                      • C
                        chris87
                        @chris87 said:
                        @fredo6 said:
                        Chris,
                        I mean when you are within TopoShaper and have the display of your screenshot, right click and tell me what is the contextual menu.
                        Visible on my screenshot :
                        right click
                        toposhaper ---- > générer terrain (maillage carré)
                        best regards
                        If you want to say that another particular contextual menu exists
                        he/it doesn't function for me
                        best regards
                          matt.gordon320
                          Hi Fredo,
                          Thanks again for the awesome plugin (as usual). I was wondering if you (or anybody else) could have a look at this topo to see where I've gone wrong with it. We graded this in the office, and the whole thing is working great except for the rear portion, where there is a bit of a sheer cliff. I wanted to see if you have any thoughts on how I could approach this area on TopoShaper, or whether there's a better way to use it, or if there's something wrong with the terrain itself.
                          Matt
                          Topo Master_For Fredo.skp
                          • fredo6F
                            Matt,
                            I had a look. In the area you mention, the issue is that your contours correspond to an overhang. This is not something TopoShaper can handle correctly.
                            More generally, I think you can do with less contours, as anyway the shape of the terrain is driven by the grid resolution.
                            • P
                              Panga
                              Hi Fredo,
                              First feedback on Toposhaper. Nice tool but I'll have two request in order to make it near to perfection :
                              1. Is that possible that Toposhaper can handle guide points with contours simultaneously to generate terrains ? I often have points and contours to define my terrain and that was a big limitation in native sandbox.
                              I tried to edit my points (components) where I replaced the point by a little cross but Toposhaper ignores them as they are too small in comparison of other contours.
                              1. Next, as we have in Artisan, is that possible to have a crease tool in Toposhaper. I often have a closed contour in border of my terrain and I would like that Toposhaper keeps exactly that contour to define terrain border.
                              Hope I'm clear...I'll do more feedback soon.
                              Thanks again Fredo.
                              • fredo6F
                                This is possible. Point of altitudes could be based on Construction points and small cross components. Simply, the algorithm may not give perfect results if you have too many. Points should be more to mark hill tops, but not as a substitute of iso-contours.
                                In the meantime, use circles which have roughly the size of the mesh cells.
                                I did the implementation actually just to see, with adjustable creases. The major problem is that the mesh does not follow the contours and therefore you will not obtain the desired result. One evolution I was planning to do is to constrain the mesh to a few contours designated by the user (hence the small editor in the Preview mode). Then it is easy to make them creases and influence the neighboring slope.
                                That will be for future releases, not immediately, as I am doing some repackaging of my scripts.
                                • pbacotP
                                  I wish just to upload this example made from survey contours (as produced by a civil engineer in California) for reference as you like. It also contains sections I made with "create group from slice" and set to scenes for overlay in Layout (shown in previous post way back on first page).
                                  Old Coach topo.zip
                                    JGA
                                    Fredo,
                                    Thanks for sharing & providing the excellent documentation to go with it.
                                    Regards,
                                    JGA
                                    • jemagnussenJ
                                      jemagnussen
                                      Hi Fredo,
                                      Working with Win 7 and SU 2013, downloaded toposhaper and LibFredo6 4.9c and have problem staring this. I get errors when starting SU 2013:
                                      Error Loading File bootstrap_TopoShaper.rb
                                      uninitialized constant TopoShaper::T6
                                      Error Loading File TopoShaperAAMixin.rb
                                      Error Loading File TopoShaperAlgo.rb
                                      uninitialized constant TopoShaper::TopoShaperAlgo::TopoShaperContour_mixin
                                      Error Loading File TopoShaperCleanser.rb
                                      Error Loading File TopoShaperDialogs.rb
                                      Error Loading File TopoShaperTool.rb
                                      Error Loading File __loader.rb
                                      undefined method `effective_load' for nil:NilClass
                                      Any ideas on what to do?
                                      Best regards
                                      Jesper
                                      HP ZBook 15, Windows 10 64 bit
                                      Intel Core i7-6820HQ @ 2.70GHz
                                      32 GB Ram
                                      NVIDIA Quadro M2000M
                                      • fredo6F
                                        Jesper,
                                        You simply did a wrong installation and does not end up with the footprint required, as described in the first post. probably coming from your unzipping operation.
                                        I would suggest you install once for all the SCF Plugin Store and then install plugins (TopoShaper and many others) from there, as you don't have to interact yourself with the unzipping operation.
                                        • bulbaB
                                          bulba
                                          thanks a lot
                                          still learning now
                                          • T
                                            tomislavm
                                            thank You!
                                            • 22
                                            • 23
                                            • 6 / 23
