    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 875.7k Views 144 Watching
    • fredo6F
      @solo said:
      How do I do the libFredo6 trace thing?
      Go to menu Windows > LibFredo6 Settings... > Trace Log files.
      You'll get a dialog box. Select the current or most recent trace file.
      Do an expand and check if there are statements in Red.
      You can then export the file from there and post it.
      • soloS
        Nothing in red.
        >>>> 1369346329.538;LibFredo6.rb;62;  in `log'
        DATE / TIME; Thu May 23 16;58;49 -0500 2013
        SKETCHUP VERSION; 13.0.3759
        RUBY_PLATFORM; i386-mswin32
        LOG FILE; LibFredo6Trace_13_1369346329538.txt
        >>>> 1369346329.538;LibFredo6.rb;103;  in `startup'
        LibFredo6; Starting up LibFredo6.rb
        >>>> 1369346329.538;LibFredo6.rb;118;  in `startup'
        LibFredo6; Beginning of loading Cycle***+
        >>>> 1369346329.548;LibFredo6.rb;129;  in `startup'
        LibFredo6 Core; LIBFREDO6_Dir_49/Lib6Core_49.rb successfully loaded
        >>>> 1369346329.771;Lib6Core_49.rb;642;  in `load_full_rubies'
        LibFredo6 4.9c; Ruby files loaded         [213 ms]
        >>>> 1369346329.871;Lib6Core_49.rb;642;  in `load_full_rubies'
        ToolsOnSurface 1.6c; Ruby files loaded         [80 ms]
        >>>> 1369346329.921;Lib6Core_49.rb;613;  in `load_bootstrap_rubies'
        TopoShaper 1.0b; Bootstrap Ruby files loaded         [0 ms]
        >>>> 1369346329.931;LibFredo6.rb;139;  in `startup'
        LibFredo6; End of loading Cycle***-
        >>>> 1369347588.651;Lib6Core_49.rb;642;  in `load_full_rubies'
        TopoShaper 1.0b; Ruby files loaded         [30 ms]
        • fredo6F
          But then, do you get the message box at startup of SU?
          • soloS
            Yup, see image.
            • fredo6F
              Very weird. It looks like you have a probleme with installation of LibFredo6, which the trace does not show.
              I have to check and come back
              • C
                chris87
                @chris87 said:
                @fredo6 said:
                Chris,
                I mean when you are within TopoShaper and have the display of your screenshot, right click and tell me what is the contextual menu.
                Visible on my screenshot :
                right click
                toposhaper ---- > générer terrain (maillage carré)
                best regards
                If you want to say that another particular contextual menu exists
                he/it doesn't function for me
                best regards
                  matt.gordon320
                  Hi Fredo,
                  Thanks again for the awesome plugin (as usual). I was wondering if you (or anybody else) could have a look at this topo to see where I've gone wrong with it. We graded this in the office, and the whole thing is working great except for the rear portion, where there is a bit of a sheer cliff. I wanted to see if you have any thoughts on how I could approach this area on TopoShaper, or whether there's a better way to use it, or if there's something wrong with the terrain itself.
                  Matt
                  Topo Master_For Fredo.skp
                  • fredo6F
                    Matt,
                    I had a look. In the area you mention, the issue is that your contours correspond to an overhang. This is not something TopoShaper can handle correctly.
                    More generally, I think you can do with less contours, as anyway the shape of the terrain is driven by the grid resolution.
                    • P
                      Panga
                      Hi Fredo,
                      First feedback on Toposhaper. Nice tool but I'll have two request in order to make it near to perfection :
                      1. Is that possible that Toposhaper can handle guide points with contours simultaneously to generate terrains ? I often have points and contours to define my terrain and that was a big limitation in native sandbox.
                      I tried to edit my points (components) where I replaced the point by a little cross but Toposhaper ignores them as they are too small in comparison of other contours.
                      1. Next, as we have in Artisan, is that possible to have a crease tool in Toposhaper. I often have a closed contour in border of my terrain and I would like that Toposhaper keeps exactly that contour to define terrain border.
                      Hope I'm clear...I'll do more feedback soon.
                      Thanks again Fredo.
                      • fredo6F
                        This is possible. Point of altitudes could be based on Construction points and small cross components. Simply, the algorithm may not give perfect results if you have too many. Points should be more to mark hill tops, but not as a substitute of iso-contours.
                        In the meantime, use circles which have roughly the size of the mesh cells.
                        I did the implementation actually just to see, with adjustable creases. The major problem is that the mesh does not follow the contours and therefore you will not obtain the desired result. One evolution I was planning to do is to constrain the mesh to a few contours designated by the user (hence the small editor in the Preview mode). Then it is easy to make them creases and influence the neighboring slope.
                        That will be for future releases, not immediately, as I am doing some repackaging of my scripts.
                        • pbacotP
                          I wish just to upload this example made from survey contours (as produced by a civil engineer in California) for reference as you like. It also contains sections I made with "create group from slice" and set to scenes for overlay in Layout (shown in previous post way back on first page).
                          Old Coach topo.zip
                            JGA
                            Fredo,
                            Thanks for sharing & providing the excellent documentation to go with it.
                            Regards,
                            JGA
                            • jemagnussenJ
                              jemagnussen
                              Hi Fredo,
                              Working with Win 7 and SU 2013, downloaded toposhaper and LibFredo6 4.9c and have problem staring this. I get errors when starting SU 2013:
                              Error Loading File bootstrap_TopoShaper.rb
                              uninitialized constant TopoShaper::T6
                              Error Loading File TopoShaperAAMixin.rb
                              Error Loading File TopoShaperAlgo.rb
                              uninitialized constant TopoShaper::TopoShaperAlgo::TopoShaperContour_mixin
                              Error Loading File TopoShaperCleanser.rb
                              Error Loading File TopoShaperDialogs.rb
                              Error Loading File TopoShaperTool.rb
                              Error Loading File __loader.rb
                              undefined method `effective_load' for nil:NilClass
                              Any ideas on what to do?
                              Best regards
                              Jesper
                              HP ZBook 15, Windows 10 64 bit
                              Intel Core i7-6820HQ @ 2.70GHz
                              32 GB Ram
                              NVIDIA Quadro M2000M
                              • fredo6F
                                Jesper,
                                You simply did a wrong installation and does not end up with the footprint required, as described in the first post. probably coming from your unzipping operation.
                                I would suggest you install once for all the SCF Plugin Store and then install plugins (TopoShaper and many others) from there, as you don't have to interact yourself with the unzipping operation.
                                • bulbaB
                                  bulba
                                  thanks a lot
                                  still learning now
                                  • T
                                    tomislavm
                                    thank You!
                                    • F
                                      filipeefilipe
                                      am I ignorant?
                                      Why is this plugin better than sandbox?
                                      Filipe from Brazil
                                        miikka1978
                                        Thanks for this excellent plugin!
                                        One question. I have a terrain with contours which is 3000x3000m. I have been using TopoShaper for creating terrain, but I have been running problems when changing the grid size from 50x50 to 100x100. TopeShaper always gets stuck in 63% (calculating boundaries). Has anybody else had similar problems?
                                        • fredo6F
                                          If you can, could you open the Ruby console when you do the test 100x100 just in case there is a message displayed.
                                          Otherwise, may be the best is to post or PM the model.
                                            miikka1978
                                            I just checked Ruby console but there was nothing. I will PM the model.
                                            • 22
                                            • 23
                                            • 6 / 23
