    Plugin to create a progress bar
    23 Posts 12 Posters 5.7k Views 12 Watching
      Squall290586
      I change the plugin, i create a new module with a new method.
      The link is be updated (version 1.02)
        Aerilius
        we usually use an author module and then a module name of our choice ( Utils is a very generic word). Like
        module Squall
          module Utils
          Squall290586
          @aerilius said:
          module Squall
          >   module Utils
          >   end
          > end
          Indeed, i change all my class and i prefixe all that by the module Squall.
          • Chris FullmerC
            One reason to not add methods to existing SketchUp space is because in the future, SketchUp itself might decide to add that same method. Then you'll be conflicting.
              @squall290586 said:
              I change the module sketchup with a new method it's not an existant method.
              It's very important?
              I recommend you read this: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                Squall290586
                Thanks for this link, I will to read that carefully 😄.
                  Squall290586
                  A new version of my progress bar is available (Version 1.1).
                  After severals tests, I modify the generation of the web page using jQuery JS framework.
                  And now, a processing management is available to execute the processes one by one.
                  • L
                    LFloissac
                    Hi Gregory,
                    "Félicitations" (I'm French too) for your plugin.
                    I'm using SU Pro - 8.0.14346 and your plugin ProgressBar v1.29
                    I've tried to use your plugin and obtain the following message: "Run aborted. Error: progress_bar.rb:48:in `set_file': can't convert nil into String"
                    the code used to call the plugin is from your example (see above). Do you have a suggestion ?
                    require 'progress_bar.rb'
                    pb = Squall::ProgressBar.new(200);
                    pb.onCancel() {puts "cancel"};
                    pb.process() {
                    i = 0;
                    loop{
                    pb.progress();
                    i += 1;
                    break if(i == 200);
                    sleep(0.5)
                    • G
                      glro
                      @lfloissac said:
                      Hi Gregory,
                      pb.process() {
                      i = 0;
                      loop{
                      pb.progress();
                      i += 1;
                      break if(i == 200);
                      sleep(0.5)
                      line 48 of progress_bar.rb is
                      "@dialog.set_file(Sketchup.find_support_file("progressBar.html", "/Plugins/ProgressBar/html"))"
                      maybe it is related to the "progressBar.html" file
                      I downloaded version 1.29 too, and the code works perfectly on my computer: a progress bar does appear on my screen
                      • G
                        glro
                        [quote="Squall290586"]
                        And for finish, this is a little example:
                        	pb = Squall;;ProgressBar.new(200);
                        	pb.process() {
                        		i = 0;
                        		loop{
                        			pb.progress();
                        			i += 1;
                        	 		break if(i == 200);
                        	 		sleep(0.5)
                        i just downloaded v 1.29, installed it, and typed the code above in a ruby editor; it works fine
                        I am not sure about how to use this plugin in a plugin of mine, though...
                        I guess that i have to type this code in mine, and adjust the increase of "i" parameter according to my process; it is correct?
                        or could you give a few words of explanation?
                        thank you
                        • L
                          LFloissac
                          Thanks, it was a path "/Plugins/ProgressBar/html" problem.
                          It works now !
                          • H
                            Hooch
                            Hey, i actually writing a plugin for SketchUp and implemented the progressbar. On windows this works fine and as expected, but now i tried to port this plugin for mac and the progressbar causes bugsplats. In my opinion the using of a second thread causes (the single threaded?) SketchUp to crash. Did anyone mentioned this before or has someone a workaround for this problem?
                            • tt_suT
                              tt_su
                              Are you using Ruby threads? Threads in Ruby 1.8 are green threads, meaning not native threads.
                              Can you elaborate on how you implemented a progressbar?
