    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • fredo6F Offline
      The cause of the crash between Vray 1.6 Beta and RoundCorner has been identified. So I guess there will be an update of Vray 1.6 anytime soon.
      There are other reasons for problems with RoundCorner
      1. Wrong installation or missing LibFredo6
      2. The Plugins directory is not in full Write access mode. The Access rights are needed due to a remaining trace and the implicit savings of parameters.
      In all cases, epening the Ruby console before launching RC may show the kind of problems and thus guide toward a solution.
      • ShyamscoolS Offline
        Shyamscool
        Sweet! now i need to learn how to launch ruby control...hello google
        sometimes i wish this was the matrix and I could just download all info in my head.
          Not Ruby "Control". Try Window>Ruby CONSOLE
            Shyamscool
            yes yes yes! fixed it!
            first one was
            Error: #<Errno::EACCES: Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Fredo6Trace.txt>
            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LIBFREDO6_Dir_49/Lib6Core_49.rb:713:in
            so u have to go n give permission to every file? I thought giving permission to the main plugin folder solved it all.. any way, now back to installing vray 1.6. hope it works.. if not i have to disable it in the extensions menu every time I model, right?
              So you didn't set full permissions to .../SketchUp 2013/Plugins until now and now it works?
                Shyamscool
                i did that for the SketchUp 2013 plugins folder but not the individual extension folders and files inside it..
                  When you give FULL security permissions to the Plugins folder for all who are listed then these changes should ripple down to all contained subfolders and files...
                  How are you setting these permissions ?
                    Your Windows installation must be different. I didn't have to do that with any folders installed inside Plugins.
                    • N Offline
                      naginarch
                      Thanks alot . Its very usefull plugins
                        Shyamscool
                        hmmm yeah maybe stuff is always the difficult way for me 😞..booo
                        any way.. installed vray 1.6 again, as soon as i click on the green click, BUGSPLAT!
                        guess we just have to wait for the next release of 1.6
                          No surprises there.
                            Shyamscool
                            the usual.. right click, properties, security, admin/ users way... isnt that right?
                              Yes... BUT did you give FULL permissions in turn to everyone on the list ?
                              • fredo6F Offline
                                NEW RELEASE: RoundCorner v2.4c - 06 Jul 13
                                RoundCorner 2.4 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.0.
                                RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
                                There is no functional changes in RoundCorner 2.4. However, this new version because circumvents some problems of security restrictions that were often met with version 2.3.
                                • fredo6F Offline
                                  @juanv.soler said:
                                  thanks for your work
                                  Did it work OK for you?
                                    JuanV.Soler
                                      JuanV.Soler
                                      yes 👍
                                      its working OK with the new release located as you told
                                        tawny
                                        Really nice plugin, thanks
                                        • fredo6F Offline
                                          @artchi said:
                                          The opportunity to do offset is not uniform, and is different for each person?
                                          http://f3.s.qip.ru/17QY0OfBP.png
                                          Unfortunately, RoundCorner only supports symetrical rounding, in particular because its primary objective is to round corners with 3 or more edges.
                                          For custom rounding of single edges, I would suggest you have a look at ProfileBuilder by Whaat.
                                          • ARTchiA Offline
                                            ARTchi
                                            The opportunity to do offset is not uniform, and is different for each face?
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 73
                                            • 74
                                            • 42 / 74
