    1.5k Posts 477 Posters 4.1m Views 477 Watching
      When you give FULL security permissions to the Plugins folder for all who are listed then these changes should ripple down to all contained subfolders and files...
      How are you setting these permissions ?
        Your Windows installation must be different. I didn't have to do that with any folders installed inside Plugins.
        • N
          naginarch
          Thanks alot . Its very usefull plugins
          • ShyamscoolS
            Shyamscool
            hmmm yeah maybe stuff is always the difficult way for me 😞..booo
            any way.. installed vray 1.6 again, as soon as i click on the green click, BUGSPLAT!
            guess we just have to wait for the next release of 1.6
              No surprises there.
              • ShyamscoolS
                Shyamscool
                the usual.. right click, properties, security, admin/ users way... isnt that right?
                  Yes... BUT did you give FULL permissions in turn to everyone on the list ?
                  • fredo6F
                    NEW RELEASE: RoundCorner v2.4c - 06 Jul 13
                    RoundCorner 2.4 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.0.
                    RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
                    There is no functional changes in RoundCorner 2.4. However, this new version because circumvents some problems of security restrictions that were often met with version 2.3.
                    • fredo6F
                      @juanv.soler said:
                      thanks for your work
                      Did it work OK for you?
                        JuanV.Soler
                          JuanV.Soler
                          yes 👍
                          its working OK with the new release located as you told
                          • T
                            tawny
                            Really nice plugin, thanks
                            • fredo6F
                              @artchi said:
                              The opportunity to do offset is not uniform, and is different for each person?
                              http://f3.s.qip.ru/17QY0OfBP.png
                              Unfortunately, RoundCorner only supports symetrical rounding, in particular because its primary objective is to round corners with 3 or more edges.
                              For custom rounding of single edges, I would suggest you have a look at ProfileBuilder by Whaat.
                              • ARTchiA
                                ARTchi
                                The opportunity to do offset is not uniform, and is different for each face?
                                • JQLJ
                                  JQL
                                  Fredo,
                                  Thanks for all your hard and useful work.
                                  Recently I installed latest version of roundcorner and also installed Libfredo. I'm using additional folders and Roundcorner is installed in an additional folder even if Libfredo is in Sketchup 2013 Pro plugins folder. The plugin works fine so far. However I get this message when I open SU:
                                  "You must install Libfredo5.0 or higher to run Fredo6_RoundCorner"
                                  As I said Libfredo is installed and the plugin is working, but the folders of the plugin and library are different...
                                  Of course I can live with the problem and I can even move the files to be together... but I like to keep all plugins I can, on a shared folder.
                                  Thanks and best regards,
                                  JQL
                                  www.casca.pt
                                  Visit us on facebook!
                                  • fredo6F
                                    @JQL
                                    It is NOT recommended to have LibFredo6 and the other plugins like RoundCorner in different directories.
                                    It's even not guaranteed it works (for now, but also for the future)
                                    So please put them together in a single directory.
                                    • JQLJ
                                      JQL
                                      Fredo,
                                      Thanks for the info.
                                      Even if I'm used to have additional folders for plugins, now and then I still have to put some plugin into the main folder. So I'll move the plugin to be in the same folder as library.
                                      Besides that I would like to know if your recommendation is relative to your plugins only, or your advice is that ALL plugins from every developer should be in main folder for plugins?
                                      If so I'll leave only the plugins being tested in an alternate folder.
                                      Thanks again and best regards,
                                      JQL
                                      www.casca.pt
                                      • fredo6F
                                        All my plugins are compatible with an alternate Plugins directory but can of course be put in the SU Standard plugin directory as well. Simply LibFredo6 and the plugins should be in the same folder.
                                        In your case, if you set up an alternate plugin directory, feel free to put LibFredo6 and my plugins there.
                                        Some plugins hard-code the location of the Plugin and must be instlled in the standard SU Plugin directory. But there are less and less. However, it is good to check.
                                        • JQLJ
                                          JQL
                                          Thanks Fredo, will do!
                                          www.casca.pt
                                          • K
                                            kyel808
                                            hey hello i try to use "round corner" in sketch up 8 on mac everything works fine apart from the plugin window beeing stuck on either the side or top bottom of the sketchup window which would be okay but its so small i cant really see anything of whats going on. is there a way to un attach it so i can freely move it around or just make it a bit bigger so i can see on where to klick? thanks a lot in advance
                                            added a screenshot so you guys can see what i mean by small 😄 http://s22.postimg.org/gtchosoo1/Bildschirmfoto_2013_08_07_um_00_28_54.png
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 74
                                            • 75
                                            • 38 / 75
