    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • ShyamscoolS Offline
      Shyamscool
      @dave r said:
      So you didn't set full permissions to .../SketchUp 2013/Plugins until now and now it works?
      i did that for the SketchUp 2013 plugins folder but not the individual extension folders and files inside it..
      • TIGT Online
        When you give FULL security permissions to the Plugins folder for all who are listed then these changes should ripple down to all contained subfolders and files...
        How are you setting these permissions ?
          Your Windows installation must be different. I didn't have to do that with any folders installed inside Plugins.
          • N Offline
            naginarch
            Thanks alot . Its very usefull plugins
              Shyamscool
              hmmm yeah maybe stuff is always the difficult way for me 😞..booo
              any way.. installed vray 1.6 again, as soon as i click on the green click, BUGSPLAT!
              guess we just have to wait for the next release of 1.6
                No surprises there.
                  Shyamscool
                  the usual.. right click, properties, security, admin/ users way... isnt that right?
                  • TIGT Online
                    Yes... BUT did you give FULL permissions in turn to everyone on the list ?
                    • fredo6F Offline
                      NEW RELEASE: RoundCorner v2.4c - 06 Jul 13
                      RoundCorner 2.4 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.0.
                      RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
                      There is no functional changes in RoundCorner 2.4. However, this new version because circumvents some problems of security restrictions that were often met with version 2.3.
                      • fredo6F Offline
                        @juanv.soler said:
                        thanks for your work
                        Did it work OK for you?
                          JuanV.Soler
                            JuanV.Soler
                            yes 👍
                            its working OK with the new release located as you told
                              tawny
                              Really nice plugin, thanks
                              • fredo6F Offline
                                @artchi said:
                                The opportunity to do offset is not uniform, and is different for each person?
                                http://f3.s.qip.ru/17QY0OfBP.png
                                Unfortunately, RoundCorner only supports symetrical rounding, in particular because its primary objective is to round corners with 3 or more edges.
                                For custom rounding of single edges, I would suggest you have a look at ProfileBuilder by Whaat.
                                • ARTchiA Offline
                                  ARTchi
                                  The opportunity to do offset is not uniform, and is different for each face?
                                  • JQLJ Offline
                                    JQL
                                    Fredo,
                                    Thanks for all your hard and useful work.
                                    Recently I installed latest version of roundcorner and also installed Libfredo. I'm using additional folders and Roundcorner is installed in an additional folder even if Libfredo is in Sketchup 2013 Pro plugins folder. The plugin works fine so far. However I get this message when I open SU:
                                    "You must install Libfredo5.0 or higher to run Fredo6_RoundCorner"
                                    As I said Libfredo is installed and the plugin is working, but the folders of the plugin and library are different...
                                    Of course I can live with the problem and I can even move the files to be together... but I like to keep all plugins I can, on a shared folder.
                                    Thanks and best regards,
                                    JQL
                                    www.casca.pt
                                    Visit us on facebook!
                                    • fredo6F Offline
                                      @JQL
                                      It is NOT recommended to have LibFredo6 and the other plugins like RoundCorner in different directories.
                                      It's even not guaranteed it works (for now, but also for the future)
                                      So please put them together in a single directory.
                                      • JQLJ Offline
                                        JQL
                                        Fredo,
                                        Thanks for the info.
                                        Even if I'm used to have additional folders for plugins, now and then I still have to put some plugin into the main folder. So I'll move the plugin to be in the same folder as library.
                                        Besides that I would like to know if your recommendation is relative to your plugins only, or your advice is that ALL plugins from every developer should be in main folder for plugins?
                                        If so I'll leave only the plugins being tested in an alternate folder.
                                        Thanks again and best regards,
                                        JQL
                                        www.casca.pt
                                        • fredo6F Offline
                                          All my plugins are compatible with an alternate Plugins directory but can of course be put in the SU Standard plugin directory as well. Simply LibFredo6 and the plugins should be in the same folder.
                                          In your case, if you set up an alternate plugin directory, feel free to put LibFredo6 and my plugins there.
                                          Some plugins hard-code the location of the Plugin and must be instlled in the standard SU Plugin directory. But there are less and less. However, it is good to check.
                                          • JQLJ Offline
                                            JQL
                                            Thanks Fredo, will do!
                                            www.casca.pt
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 74
                                            • 75
                                            • 38 / 75
