    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • ShyamscoolS Offline
      Shyamscool
      @dave r said:
      Try disabling Vray and see if that changes the behavior of RoundCorner. That has been the solution for numerous others and Vray is known to wreak havoc with other plugins.
      Dave,
      i had RC working on su7+vray 1.6beta.... ill give your suggestion a shot
        I was just telling you what a number of people have found to be the cause of plugins not working. Vray has been causing problems for a lot of users with more than just the Round Corners plugin.
          Shyamscool
          ... earlier on another system, vray1.6+ su8+win7 gave bugsplat. Is SU7 the only stable place to run vray 1.6 for now??
          well you suggested to disable vray and i accidentally uninstalled it.... however even that didnt work...
          😞 its actually depressing
            Shyamscool
            but hey! i uninstalled vray and RC still didnt work...
            rc Su13 vray 1.6 win7 issue
            • fredo6F Offline
              The cause of the crash between Vray 1.6 Beta and RoundCorner has been identified. So I guess there will be an update of Vray 1.6 anytime soon.
              There are other reasons for problems with RoundCorner
              1. Wrong installation or missing LibFredo6
              2. The Plugins directory is not in full Write access mode. The Access rights are needed due to a remaining trace and the implicit savings of parameters.
              In all cases, epening the Ruby console before launching RC may show the kind of problems and thus guide toward a solution.
                Shyamscool
                Sweet! now i need to learn how to launch ruby control...hello google
                sometimes i wish this was the matrix and I could just download all info in my head.
                  Not Ruby "Control". Try Window>Ruby CONSOLE
                    Shyamscool
                    yes yes yes! fixed it!
                    first one was
                    Error: #<Errno::EACCES: Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Fredo6Trace.txt>
                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/LIBFREDO6_Dir_49/Lib6Core_49.rb:713:in
                    so u have to go n give permission to every file? I thought giving permission to the main plugin folder solved it all.. any way, now back to installing vray 1.6. hope it works.. if not i have to disable it in the extensions menu every time I model, right?
                      So you didn't set full permissions to .../SketchUp 2013/Plugins until now and now it works?
                        Shyamscool
                        i did that for the SketchUp 2013 plugins folder but not the individual extension folders and files inside it..
                          When you give FULL security permissions to the Plugins folder for all who are listed then these changes should ripple down to all contained subfolders and files...
                          How are you setting these permissions ?
                            Your Windows installation must be different. I didn't have to do that with any folders installed inside Plugins.
                            • N Offline
                              naginarch
                              Thanks alot . Its very usefull plugins
                                Shyamscool
                                hmmm yeah maybe stuff is always the difficult way for me 😞..booo
                                any way.. installed vray 1.6 again, as soon as i click on the green click, BUGSPLAT!
                                guess we just have to wait for the next release of 1.6
                                  No surprises there.
                                    Shyamscool
                                    the usual.. right click, properties, security, admin/ users way... isnt that right?
                                      Yes... BUT did you give FULL permissions in turn to everyone on the list ?
                                      • fredo6F Offline
                                        NEW RELEASE: RoundCorner v2.4c - 06 Jul 13
                                        RoundCorner 2.4 is a major technical release implementing the new naming conventionsintroduced by LibFredo6 5.0.
                                        RoundCorner footprint will now be based on one file and one subfolder, as shown in the footprint below:
                                        There is no functional changes in RoundCorner 2.4. However, this new version because circumvents some problems of security restrictions that were often met with version 2.3.
                                        • fredo6F Offline
                                          @juanv.soler said:
                                          thanks for your work
                                          Did it work OK for you?
                                            JuanV.Soler
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 73
                                            • 74
                                            • 42 / 74
