    Rotating a Point to Meet a Face
    21 Posts 7 Posters 2.2k Views 7 Watching
      I wasn't being rude. My apologies if you took it that way.
      • kenythedudeK
        kenythedude
        I've obviously just misinterpreted you then; no apology needed.
        I'm still stuck on this one though 😞
        • gillesG
          gilles
          With Fredo scale rotate tool:
          1 set the axis for rotation
          2 draw reference direction (on vertical edge of your face)
          3 pick target point (on the edge you want to touch the other face)
          4 rotate to the face.
          Took me a minute to work it out
          Really?
          I'd like to see how you did it.
          • massimoM
            massimo Moderator
            Here is an image of the workflow with the tool that Dave suggested.
            • kenythedudeK
              kenythedude
              Gilles, allow me to clarify: it took me a minute to think I'd worked it out. Turns out the problem it a lot more complicated than I had initially thought! I'm still trying to work out how to do it.
              Massimo, I cannot, for the life of me, get the ornage line to come up! Now, I know this can't be a plugin age issue because I only installed SketchUp on my work computer a few days ago and went searching for all the plugins I need, which are all up to date.
              Is there a trick to getting the orange edge?
              • massimoM
                massimo Moderator
                Of course that only works if the two rectangles have the same width (like the image you posted). Try to hover along the target rectangle's edge while rotating and you'll find it.
                • kenythedudeK
                  kenythedude
                  Yeah, that just isn't happening. πŸ˜•
                  I honestly don't know why...
                  • pbacotP
                    for me it works rotating to the edge, not a face and in either case there is no inference tag. It sort of snaps, that's the only way to tell. And the line doesn't bisect the plane untill you draw over it... for me.
                    • jeff hammondJ
                      maybe try it with just lines at first?
                      some more info here regarding usage:
                      404 Not Found
                      (sketchucation.com)
                      • kenythedudeK
                        kenythedude
                        As far as I can tell, I've duplicated everything exactly as you guys have done it, but I must be doing something wrong. I'm getting a snap for "Endpoint" "On Edge" "Parallel To Edge" - nothing works.
                        Thanks for trying guys πŸ˜•
                        Edit: Yeah Massimo, I tried just edges too; no luck I'm afraid.
                        • kenythedudeK
                          kenythedude
                          Yeah, I think something is messed up with my plugins directory or something, because I'm not getting a lot of the snaps and inferences I should be... I'm going to go check that out.
                          • BoxB
                            Check your modelling scale, snap and precision.
                            If you are trying to work too small and your snap to precision is set too high inferencing can get screwed up.
                            • kenythedudeK
                              kenythedude
                              Well, I ripped out all the Fredo related plugins and all their relevant bits, then re-inserted freshly downloaded versions; lo and behold, it works! I'm confused as to why, because as far as I can tell, the plugins' file path structure is exactly the same as before.
                              In any case, thank you everyone for your help!
