    Rotating a Point to Meet a Face
    21 Posts 7 Posters 2.0k Views 7 Watching
    • kenythedudeK Offline
      kenythedude
      I have been nothing but courteous to you, Dave, so I don't understand your tone. At no point did I say anything to warrant your rudeness. I am legitimately requesting help using the best descriptive language and images I can and I have been met with a condescending attitude.
      I have tried to do exactly what you outlined, but I cannot achieve the result you have. It's hard to tell from the screenshot you've posted, but when I get something that looks like that, zooming in reveals that the faces are either slightly overlapping or not quite touching, no matter how hard I try. I initially thought your solution was viable but realised that, at close examination, it wasn't quite there.
      I genuinely appreciate you taking time to try and help me out, but either I'm misunderstanding your instructions or I'm using the tool wrong, and I don't think either is the case after trying it every-which-way.
      I apologise if I've come across as ungrateful or contrary, that wasn't my intention.
        I wasn't being rude. My apologies if you took it that way.
          kenythedude
          I've obviously just misinterpreted you then; no apology needed.
          I'm still stuck on this one though 😞
          • gillesG Offline
            gilles
            With Fredo scale rotate tool:
            1 set the axis for rotation
            2 draw reference direction (on vertical edge of your face)
            3 pick target point (on the edge you want to touch the other face)
            4 rotate to the face.
            Took me a minute to work it out
            Really?
            I'd like to see how you did it.
            • massimoM Offline
              massimo Moderator
              Here is an image of the workflow with the tool that Dave suggested.
                kenythedude
                Gilles, allow me to clarify: it took me a minute to think I'd worked it out. Turns out the problem it a lot more complicated than I had initially thought! I'm still trying to work out how to do it.
                Massimo, I cannot, for the life of me, get the ornage line to come up! Now, I know this can't be a plugin age issue because I only installed SketchUp on my work computer a few days ago and went searching for all the plugins I need, which are all up to date.
                Is there a trick to getting the orange edge?
                • massimoM Offline
                  massimo Moderator
                  Of course that only works if the two rectangles have the same width (like the image you posted). Try to hover along the target rectangle's edge while rotating and you'll find it.
                    kenythedude
                    Yeah, that just isn't happening. πŸ˜•
                    I honestly don't know why...
                    • pbacotP Offline
                      for me it works rotating to the edge, not a face and in either case there is no inference tag. It sort of snaps, that's the only way to tell. And the line doesn't bisect the plane untill you draw over it... for me.
                      • jeff hammondJ Offline
                        maybe try it with just lines at first?
                        some more info here regarding usage:
                        404 Not Found
                        (sketchucation.com)
                          kenythedude
                          As far as I can tell, I've duplicated everything exactly as you guys have done it, but I must be doing something wrong. I'm getting a snap for "Endpoint" "On Edge" "Parallel To Edge" - nothing works.
                          Thanks for trying guys πŸ˜•
                          Edit: Yeah Massimo, I tried just edges too; no luck I'm afraid.
                            kenythedude
                            Yeah, I think something is messed up with my plugins directory or something, because I'm not getting a lot of the snaps and inferences I should be... I'm going to go check that out.
                            • BoxB Offline
                              Check your modelling scale, snap and precision.
                              If you are trying to work too small and your snap to precision is set too high inferencing can get screwed up.
                                kenythedude
                                Well, I ripped out all the Fredo related plugins and all their relevant bits, then re-inserted freshly downloaded versions; lo and behold, it works! I'm confused as to why, because as far as I can tell, the plugins' file path structure is exactly the same as before.
                                In any case, thank you everyone for your help!
