    [Plugin] Helix along curve
    100 Posts 58 Posters 171.9k Views 58 Watching
      In fact that is only the C calculate methodwho don't work ! ๐Ÿ˜ฒ
      (for the French)
      • Gus RG Offline
        Gus R
        Fantastic plugin. Thanks.
        www.instagram.com/gusrobatto/
        www.facebook.com/gusrobatto
        • O Offline
          OlfLab
          A very nice and useful plugin.
          However, I have a question. Is there any way to change the orientation of the tube, as with the plugin "FollowMe and keep"?
          • 3 Offline
            3dalbertsoft
            hi, for the moment the plugin does not have this option, I'm thinking of including this in an upcoming update, for now you can use "Helix along curve" composite with "FollowMe and keep"
            • Alan FraserA Offline
              Alan Fraser
              Great job 3dalbertsoft. Where was this plugin when I was still modelling house phones with cords? ๐Ÿ˜„
              3D Figures
                dacastror
                https://sites.google.com/site/dacastror/archivos/colgado.jpg
                made with helix along curve
                  dacastror
                  https://sites.google.com/site/dacastror/archivos/colgado 2.jpg
                    tulacong
                    thank for man
                    • tridemT Offline
                      tridem
                      ๐Ÿ˜ฎ this plugin is spectacular ... how could I missed it? ๐Ÿ˜„
                      ๐Ÿ‘
                      • erikBE Offline
                        erikB
                        Great plug-in ! ๐Ÿ‘
                        thanks,
                        erikB
                          tulacong
                          omy good ... thank you
                            james_mcl
                            Can this plugin be used for screw threads?
                            Any help would be appreciated.
                              Yes! Look Minute 5.04 ! ๐Ÿ˜‰
                              • gillesG Offline
                                gilles
                                Have a look there:
                                http://sketchucation.com/forums/viewtopic.php?p=240238#p122571
                                  glasstronomic
                                  Hi 3dalbertsoft,
                                  Thank you very much for this great plugin!
                                  On a related issue, I am desperately trying to find a way to model, in SU, a conical helix where the helix maintains a constant and specific pitch angle to the conical surface. It is also known as a conical log spiral. Can anyone help me?
                                  The helix I am describing would have the coils get closer together as they approach the apex of the cone. Here is an example:
                                  http://www.satimo.com/sites/www.satimo.com/files/imagecache/product_view/Conical spiral_0.jpg
                                    james_mcl
                                    Thanks Pilou and Gilles for the information posted. it was very helpful.
                                    • 3 Offline
                                      3dalbertsoft
                                      glasstronomic these options will be added in upcoming updates, for now the closest it say Pilou the min 5
                                        Cerboney
                                        Hi all,
                                        Please could somebody tell me how to install that plugin step by step ? Because it doesn't work for me. I install it but there is an error message when I open Sketchup. I use Google Sketchup 8 in French on Windows 8.
                                        Thank you guys
                                        Cerboney
                                          What's the error message? ๐Ÿ˜’
                                            How have you 'installed it' ? ๐Ÿ˜•
                                            What are the errors?
                                            I suspect they relate to missing files ??
                                            This plugin's archive [ZIP file] looks like the attached image.
                                            Copy those two items into the Plugins folder, keeping the contents in the same relationship.
                                            That is one .rb file and the plugins's subfolder [containing other code files, images etc].
                                            You need FULL read/write security permissions to the main Plugins folder...
                                            ['Compatibility Files' issues and the 'VirtualStore' beckon otherwise ๐Ÿ˜’ ]
                                            Also set SketchUp.exe to 'Always Runs as Administrator'...
                                            There are may posts covering these aspects in great detail...
                                            • 3 / 5
