    [Plugin] Helix along curve
    100 Posts 58 Posters 165.1k Views 58 Watching
      dacastror
      https://sites.google.com/site/dacastror/archivos/colgado 2.jpg
        tulacong
        thank for man
        • tridemT Offline
          tridem
          😮 this plugin is spectacular ... how could I missed it? 😄
          • erikBE Offline
            erikB
            Great plug-in ! 👍
            thanks,
            erikB
              tulacong
              omy good ... thank you
                james_mcl
                Can this plugin be used for screw threads?
                Any help would be appreciated.
                  Yes! Look Minute 5.04 ! 😉
                  • gillesG Offline
                    gilles
                    Have a look there:
                    http://sketchucation.com/forums/viewtopic.php?p=240238#p122571
                      glasstronomic
                      Hi 3dalbertsoft,
                      Thank you very much for this great plugin!
                      On a related issue, I am desperately trying to find a way to model, in SU, a conical helix where the helix maintains a constant and specific pitch angle to the conical surface. It is also known as a conical log spiral. Can anyone help me?
                      The helix I am describing would have the coils get closer together as they approach the apex of the cone. Here is an example:
                      http://www.satimo.com/sites/www.satimo.com/files/imagecache/product_view/Conical spiral_0.jpg
                        james_mcl
                        Thanks Pilou and Gilles for the information posted. it was very helpful.
                        • 3 Offline
                          3dalbertsoft
                          glasstronomic these options will be added in upcoming updates, for now the closest it say Pilou the min 5
                            Cerboney
                            Hi all,
                            Please could somebody tell me how to install that plugin step by step ? Because it doesn't work for me. I install it but there is an error message when I open Sketchup. I use Google Sketchup 8 in French on Windows 8.
                            Thank you guys
                            Cerboney
                              What's the error message? 😒
                                How have you 'installed it' ? 😕
                                What are the errors?
                                I suspect they relate to missing files ??
                                This plugin's archive [ZIP file] looks like the attached image.
                                Copy those two items into the Plugins folder, keeping the contents in the same relationship.
                                That is one .rb file and the plugins's subfolder [containing other code files, images etc].
                                You need FULL read/write security permissions to the main Plugins folder...
                                ['Compatibility Files' issues and the 'VirtualStore' beckon otherwise 😒 ]
                                Also set SketchUp.exe to 'Always Runs as Administrator'...
                                There are may posts covering these aspects in great detail...
                                  Cerboney
                                  Hi thank you TIG for your help, it works thanks to your explanations. I think I copied only the .rb file in the folder "Plugins" of Sketchup.
                                  Bye
                                    dacastror
                                    playing
                                      dacastror
                                      the helix is closed properly!
                                      • F Offline
                                        fcohen
                                        Thank you for this plug-in. Very useful! I am looking to hire a contractor to take my hand-drawn sketches of a mens watch project (details at http://www.votsh.com) and create SketchUp files. Please email me fcohen at votsh.com for details on the contract. Thanks! -Frank
                                        • 3 Offline
                                          3dalbertsoft
                                          I have verified that helix along curve works in sketchup 2014, you can install and use without problems
                                          • H Offline
                                            Harry K
                                            I don't seem to be able to get it to install properly. Running OSX 10.8.5. Am placing files in Library/Application Support/Sketchup 2014/Sketchup/Plugins.
                                            Any ideas?
                                            • 3 / 5
