    [Plugin] Helix along curve
    100 Posts 58 Posters 173.2k Views 58 Watching
    • T
      tulacong
      omy good ... thank you
        james_mcl
        Can this plugin be used for screw threads?
        Any help would be appreciated.
          Yes! Look Minute 5.04 ! 😉
          • gillesG
            gilles
            Have a look there:
            http://sketchucation.com/forums/viewtopic.php?p=240238#p122571
            • G
              glasstronomic
              Hi 3dalbertsoft,
              Thank you very much for this great plugin!
              On a related issue, I am desperately trying to find a way to model, in SU, a conical helix where the helix maintains a constant and specific pitch angle to the conical surface. It is also known as a conical log spiral. Can anyone help me?
              The helix I am describing would have the coils get closer together as they approach the apex of the cone. Here is an example:
              http://www.satimo.com/sites/www.satimo.com/files/imagecache/product_view/Conical spiral_0.jpg
                james_mcl
                Thanks Pilou and Gilles for the information posted. it was very helpful.
                  3dalbertsoft
                  glasstronomic these options will be added in upcoming updates, for now the closest it say Pilou the min 5
                  • C
                    Cerboney
                    Hi all,
                    Please could somebody tell me how to install that plugin step by step ? Because it doesn't work for me. I install it but there is an error message when I open Sketchup. I use Google Sketchup 8 in French on Windows 8.
                    Thank you guys
                    Cerboney
                      What's the error message? 😒
                        How have you 'installed it' ? 😕
                        What are the errors?
                        I suspect they relate to missing files ??
                        This plugin's archive [ZIP file] looks like the attached image.
                        Copy those two items into the Plugins folder, keeping the contents in the same relationship.
                        That is one .rb file and the plugins's subfolder [containing other code files, images etc].
                        You need FULL read/write security permissions to the main Plugins folder...
                        ['Compatibility Files' issues and the 'VirtualStore' beckon otherwise 😒 ]
                        Also set SketchUp.exe to 'Always Runs as Administrator'...
                        There are may posts covering these aspects in great detail...
                        • C
                          Cerboney
                          Hi thank you TIG for your help, it works thanks to your explanations. I think I copied only the .rb file in the folder "Plugins" of Sketchup.
                          Bye
                            dacastror
                            playing
                              dacastror
                              the helix is closed properly!
                              • F
                                fcohen
                                Thank you for this plug-in. Very useful! I am looking to hire a contractor to take my hand-drawn sketches of a mens watch project (details at http://www.votsh.com) and create SketchUp files. Please email me fcohen at votsh.com for details on the contract. Thanks! -Frank
                                  3dalbertsoft
                                  I have verified that helix along curve works in sketchup 2014, you can install and use without problems
                                  • H
                                    Harry K
                                    I don't seem to be able to get it to install properly. Running OSX 10.8.5. Am placing files in Library/Application Support/Sketchup 2014/Sketchup/Plugins.
                                    Any ideas?
                                      What does this mean specifically? Did you just drop the downloaded ZIP file into the Plugins folder? If so, that won't work indeed because you didn't actually install the plugin.
                                      If you did that, move the zip file back out of the Plugins folder to somewhere else. Maybe Downloads. Then right click on the zip file and choose Get Info. There change the extension from .zip to .rbz. In SketchUp click on the SketchUp menu and choose Preference>Extensions. Click on Install Extension. Navigate to the file and click Open. Click Yes and OK as they show. The plugin should now be installed correctly.
                                      If you did anything else, go to the Plugins folder and delete any and all related files before making the .rbz file and installing it.
                                      Most plugins are available through the Sketchucation Plugin Store--link at the top of the page or the Extension Warehouse. You don't have to do all these gymnastics to install plugins with them but you should at least install the SCF Plugin Store.
                                      • H
                                        Harry K
                                        Mac OSX automatically unzips, but the extension was wrong (tbs, rb), so I added the "z" AND the system also hides the library so you can't navigate to it via preferences > extensions.... But I found a way to "unhide" the Library. I was then able to choose the extension...only to be greeted with "unable to open..."
                                        Is there a Plan B?
                                          You don't need a plan B. You need to follow plan A.
                                          AGAIN:
                                          -Remove the files you inserted into the Plugins folder because you've done it wrong.
                                          -Make sure you have permissions set to Read and Write for the Plugins folder.
                                          -Find the ZIP file and rename it from .zip to .rbz. DO NOT OPEN THE ZIP FILE. DO NOT TOUCH ANYTHING INSIDE IT.
                                          -Open SketchUp.
                                          -Go to the SketchUp menu--left of File and click on Preferences.
                                          -Select Extensions from the list in the Preferences window.
                                          -Click on Install Extension.
                                          -Navigate to where you downloaded and saved the zip file (which is now a .rbz file).
                                          -Select it.
                                          -Click Open
                                          -Click Yes and OK as they present themselves.
                                          -Close the Preferences box.
                                          The plugin should now be installed.
                                          • H
                                            Harry K
                                            Ahhh. My browser was auto-unzipping the download. Changed that and it worked like a charm.
                                            Many thanks for your patience.
                                            • 4 / 5
