    ? SU 2013 Custom Toolbars
    36 Posts 15 Posters 11.0k Views 15 Watching
    • KrisidiousK
      Krisidious
      @dan rathbun said:
      Yes .. no more multi-column toolbars. Only single column toolbars are compatible with the new toolbar framework.
      It is in the Release Notes for v2013 (... did you read them ?)
      What do you mean no two column toolbars? I have them.
      By: Kristoff Rand
      • BoxB
        You can have them, but you can't dock them as two.
        Nope I lie, you can dock them.
        But I think the main complaint is they change to single column themselves when docked.
        • KrisidiousK
          Krisidious
          Ahhh... I see. Yeah. Annoying. I don't dock but top and bottom.
          By: Kristoff Rand
          • Alan FraserA
            Alan Fraser
            The fix, for the "can only dock in a single column" problem (it's not a bug...it's just that double-width columns are simply incompatible with the new toolbar flexibility)...is to create new toolbar called Large Toolset 2 (or whatever) and drag every second icon off the large toolset onto that one. Then you can dock them side by side looking exactly the same as before.
            I put in a Feature Request for your new icon/toolbar layout to be able to be saved to an external file that can survive a complete re-install of the program...'cos if I'm going to all this trouble, I only want to have to do it once.
            3D Figures
            • P
              Panga
              Thanks for the info, did not find the time to read it fully !
              • P
                Panga
                Thanks for the clever tip ! Will try that tomorrow !
                • john2J
                  john2
                  is there any way i can get old icons that used to be in earlier version of sketchup in the toolbars of 2013 version?
                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                  • kenK
                    ken
                    I was attempting to make my custom version of tool bars. I noticed that I could not move the edge style tools into my custom tool bar.
                    Is this my problem, or a bug?
                    Ken
                    • Chris FullmerC
                      @John - I don't know of any way to do that.
                      @Ken - The custom toolbars only work with the default, non-ruby toolbars of SketchUp. I'm guessing Edge Tools is a plugin. So that one is not customizable.
                        JuanV.Soler
                        you can customise your ruby plugins with the Toolbar editor and they will dock as well
                        404 Not Found
                        (sketchucation.com)
                        • kenK
                          ken
                          I was referring to the "Edge Style" toolbar which is a native toolbar. Sorry about the confusion.
                          Thanks for your quick reply. Also, just a quick observation, you will need to replace the surf board with a snowboard.
                          Ken
                          • Chris FullmerC
                            Hey Ken, sorry, I looked under "Edge Style" and didn't see a toolbar, so I assumed it was a custom toolbar. IF you are referring to the "Styles" toolbar though, that one should be completely customizable. Are you still unable to customize it?
                            • kenK
                              ken
                              Yep, I can't move the icon to another toolbar or move other icon to this toolbar.
                              Thanks for your reply
                              Ken
                              • majidM
                                majid
                                but as we usually use lots of ruby plugs, it is strongly recommended to manage add-ons in an easier way....
                                • demD
                                  dem
                                  anybody know how make plugins toolbars on two rows, like its possible for default panels in SU2014?Capture.PNG
                                    Like this? Just push the end of the bar toward the center. I don't think you can make it spread across two rows at the top of the screen, though. I suppose you could split the tools between two custom toolbars using Aerilius' Toolbar Editor.
                                    • demD
                                      dem
                                      its working at the top only. I need two vertical columns in one toolbar, making own and dont want saparate it( too many toolbars
                                      maybe this feature provided in the ruby 2.0 for 2014 engine?
                                        Ah. I see. No.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          You cannot make them multi-row nor multi-column when docked. but you can when floating.
                                          The "Large Tool Set" is now hard-wired as a 2 column vertical toolbar when docked.
                                          We cannot have multi-row nor multi-column toolbars since SU 2013. These were contributing to the "toolbar shuffle" havoc. So part of the fix, for SketchUp 2013, was only single-row or single-column toolbars when docked.
                                          SO then Trimble cheats and breaks the rule for it's OEM "Large Tool Set". HEhehe. 😉
                                          I'm not here much anymore.
                                          • B
                                            blackdogsketch
                                            Hey sfto1, the information from the Knowledge center there is slightly inaccurate. The "Customize Toolbar" window was renamed to simply "Toolbars". So it is the window that comes up when you select View > Toolbars.
                                            The "Command" tab that is listed does not actually exist, so the following steps it outlines are correct. I'll file this as a bug in our documentation. Thanks!
                                            And three years later, we still have the exact same misleading documentation. Worse, using CTRL and drag to copy tools from another toolbar to the custom toolbar does not work! It does nothing. Using ALT and drag MOVES the tool so that it is no longer available on the original toolbar. Why is there no master menu of command icons that can be used for selections (as on a Mac)???
                                            After trying for some time, I am unable to get any commands from an original toolbar onto my new Custom Toolbar without deleting them from the original.
                                            Pardon my frustration. if anyone knows a way to get commands onto a custom toolbar I'd really appreciate hearing about it.
                                            • 2 / 2
