    ? SU 2013 Custom Toolbars
    36 Posts 15 Posters 11.0k Views 15 Watching
    • Chris FullmerC
      Hey Chris, that is not supported. What you would have to do is write a ruby script and create a toolbar that way for those tools.
      • Dan RathbunD
        Dan Rathbun
        @krisidious said:
        and while we're at it... how do we put a native command that has no button into a custom toolbar? like a perspective button or a hide rest of model button?
        I asked that some of these commands would be given buttons and that a Commands panel be created similar to the one that SketchUp Viewer has.
        It would be a Feature Request for the future I suppose.
        I'm not here much anymore.
        • KrisidiousK
          Krisidious
          thanks guys...
          By: Kristoff Rand
          • P
            Panga
            I also have a question about Toolbars : Is it still possible to make two columns large toolbars (I mean to columns of icons) ? This was very usefull to display the large toolset on the left side of the screen. I tried to replicate this in 2013 but each I'm docking the toolbar, it transforms in a one column toolbar. Any idea ?
              Any idea ?
              Even the first column overpass the screen's bottom?
              • P
                Panga
                Yes Pilou,
                The problem is that the one column toolbar does not show all icons !! Unless I'm using small icons. But it also depends on screen resolution...After more tests it seems impossible to have a two columns toolbar...what a pity !
                • Dan RathbunD
                  Dan Rathbun
                  Yes .. no more multi-column toolbars. Only single column toolbars are compatible with the new toolbar framework.
                  It is in the Release Notes for v2013 (... did you read them ?)
                  • KrisidiousK
                    Krisidious
                    What do you mean no two column toolbars? I have them.
                    By: Kristoff Rand
                    • BoxB
                      You can have them, but you can't dock them as two.
                      Nope I lie, you can dock them.
                      But I think the main complaint is they change to single column themselves when docked.
                      • KrisidiousK
                        Krisidious
                        Ahhh... I see. Yeah. Annoying. I don't dock but top and bottom.
                        By: Kristoff Rand
                        • Alan FraserA
                          Alan Fraser
                          The fix, for the "can only dock in a single column" problem (it's not a bug...it's just that double-width columns are simply incompatible with the new toolbar flexibility)...is to create new toolbar called Large Toolset 2 (or whatever) and drag every second icon off the large toolset onto that one. Then you can dock them side by side looking exactly the same as before.
                          I put in a Feature Request for your new icon/toolbar layout to be able to be saved to an external file that can survive a complete re-install of the program...'cos if I'm going to all this trouble, I only want to have to do it once.
                          3D Figures
                          • P
                            Panga
                            Thanks for the info, did not find the time to read it fully !
                            • P
                              Panga
                              Thanks for the clever tip ! Will try that tomorrow !
                              • john2J
                                john2
                                is there any way i can get old icons that used to be in earlier version of sketchup in the toolbars of 2013 version?
                                Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                • kenK
                                  ken
                                  I was attempting to make my custom version of tool bars. I noticed that I could not move the edge style tools into my custom tool bar.
                                  Is this my problem, or a bug?
                                  Ken
                                  • Chris FullmerC
                                    @John - I don't know of any way to do that.
                                    @Ken - The custom toolbars only work with the default, non-ruby toolbars of SketchUp. I'm guessing Edge Tools is a plugin. So that one is not customizable.
                                      JuanV.Soler
                                      you can customise your ruby plugins with the Toolbar editor and they will dock as well
                                      404 Not Found
                                      (sketchucation.com)
                                      • kenK
                                        ken
                                        I was referring to the "Edge Style" toolbar which is a native toolbar. Sorry about the confusion.
                                        Thanks for your quick reply. Also, just a quick observation, you will need to replace the surf board with a snowboard.
                                        Ken
                                        • Chris FullmerC
                                          Hey Ken, sorry, I looked under "Edge Style" and didn't see a toolbar, so I assumed it was a custom toolbar. IF you are referring to the "Styles" toolbar though, that one should be completely customizable. Are you still unable to customize it?
                                          • kenK
                                            ken
                                            Yep, I can't move the icon to another toolbar or move other icon to this toolbar.
                                            Thanks for your reply
                                            Ken
