    ? SU 2013 Custom Toolbars
    36 Posts 15 Posters 10.8k Views 15 Watching
    • Dan RathbunD
      Dan Rathbun
      Yes .. no more multi-column toolbars. Only single column toolbars are compatible with the new toolbar framework.
      It is in the Release Notes for v2013 (... did you read them ?)
      I'm not here much anymore.
      • KrisidiousK
        Krisidious
        What do you mean no two column toolbars? I have them.
        By: Kristoff Rand
        • BoxB
          You can have them, but you can't dock them as two.
          Nope I lie, you can dock them.
          But I think the main complaint is they change to single column themselves when docked.
          • KrisidiousK
            Krisidious
            Ahhh... I see. Yeah. Annoying. I don't dock but top and bottom.
            By: Kristoff Rand
            • Alan FraserA
              Alan Fraser
              The fix, for the "can only dock in a single column" problem (it's not a bug...it's just that double-width columns are simply incompatible with the new toolbar flexibility)...is to create new toolbar called Large Toolset 2 (or whatever) and drag every second icon off the large toolset onto that one. Then you can dock them side by side looking exactly the same as before.
              I put in a Feature Request for your new icon/toolbar layout to be able to be saved to an external file that can survive a complete re-install of the program...'cos if I'm going to all this trouble, I only want to have to do it once.
              3D Figures
              • P
                Panga
                Thanks for the info, did not find the time to read it fully !
                • P
                  Panga
                  Thanks for the clever tip ! Will try that tomorrow !
                  • john2J
                    john2
                    is there any way i can get old icons that used to be in earlier version of sketchup in the toolbars of 2013 version?
                    Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                    • kenK
                      ken
                      I was attempting to make my custom version of tool bars. I noticed that I could not move the edge style tools into my custom tool bar.
                      Is this my problem, or a bug?
                      Ken
                      • Chris FullmerC
                        @John - I don't know of any way to do that.
                        @Ken - The custom toolbars only work with the default, non-ruby toolbars of SketchUp. I'm guessing Edge Tools is a plugin. So that one is not customizable.
                          JuanV.Soler
                          you can customise your ruby plugins with the Toolbar editor and they will dock as well
                          404 Not Found
                          (sketchucation.com)
                          • kenK
                            ken
                            I was referring to the "Edge Style" toolbar which is a native toolbar. Sorry about the confusion.
                            Thanks for your quick reply. Also, just a quick observation, you will need to replace the surf board with a snowboard.
                            Ken
                            • Chris FullmerC
                              Hey Ken, sorry, I looked under "Edge Style" and didn't see a toolbar, so I assumed it was a custom toolbar. IF you are referring to the "Styles" toolbar though, that one should be completely customizable. Are you still unable to customize it?
                              • kenK
                                ken
                                Yep, I can't move the icon to another toolbar or move other icon to this toolbar.
                                Thanks for your reply
                                Ken
                                • majidM
                                  majid
                                  but as we usually use lots of ruby plugs, it is strongly recommended to manage add-ons in an easier way....
                                  • demD
                                    dem
                                    anybody know how make plugins toolbars on two rows, like its possible for default panels in SU2014?Capture.PNG
                                      Like this? Just push the end of the bar toward the center. I don't think you can make it spread across two rows at the top of the screen, though. I suppose you could split the tools between two custom toolbars using Aerilius' Toolbar Editor.
                                      • demD
                                        dem
                                        its working at the top only. I need two vertical columns in one toolbar, making own and dont want saparate it( too many toolbars
                                        maybe this feature provided in the ruby 2.0 for 2014 engine?
                                          Ah. I see. No.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            You cannot make them multi-row nor multi-column when docked. but you can when floating.
                                            The "Large Tool Set" is now hard-wired as a 2 column vertical toolbar when docked.
                                            We cannot have multi-row nor multi-column toolbars since SU 2013. These were contributing to the "toolbar shuffle" havoc. So part of the fix, for SketchUp 2013, was only single-row or single-column toolbars when docked.
                                            SO then Trimble cheats and breaks the rule for it's OEM "Large Tool Set". HEhehe. 😉
                                            • 2 / 2
